Question about Connex 3300 240-Channels Base CB Radio
Where should I have my rf gain selector hi or lo
Where should I place my rf selector on hi or lo
Rf gain is about local coms if you want your cb to RX far away stuff set it too high but local stuff like friends family that are local then you want too set rf gain to low then only local signal can trigger the squelch ... so the radio will ignore the static and only trigger you when needed ? see what i mean rf gain ye a DX guy will set it high or too listen to people like over 50K away
and let then break the squelch...min
Posted on Nov 23, 2014
My galaxy 33hml has low recsive and the rf gain dont work
have you played around with anything on the inside of the radio??? there are variables on the inside for hi and low power also hi and low modulation RF gain and the such if you turned the wrong one the wrong way,poof thats it. It can still be fixedbut not by you.
Jun 09, 2014 | Galaxy Radios DX-33HML 40-Channels Base CB...
Have to use rf gain control to control volume. no control or very little with af gain control. ft101ee
RF gain is not used to control volume. It's used to adjust the sensitivity of the radio. If you have a station nearby that's very strong that you wish to listen to, turning down the RF gain will help reduce distortion and/or interference. The control for Volume is "AF Gain" (Audio Frequency Gain). You want to use it to set the volume level.
Oct 15, 2013 | Radio Communications
How to adjust the rf gain on a cobra 29
there is a knob on the front of the radio the says RF GAIN. Turn it all the way to the right and you RF GAIN is at its max
May 08, 2012 | Cobra 29 LTD CB Radio
What do i set to get channel 19 to talk to truckers
Hello terry,
Welcome to FixYa.
My name is John, and I will be assisting you with your issue today.
Turn your unit on.
Set the channel selector to channel 19.
Turn your RF GAIN to MAX.
Turn your MIC GAIN to MAX.
Turn your SQUELCH all the way to the left.
Then key the mic and talk to them and enjoy.
Hope this was helpful. Your Comments and Testimony's are always welcomed here.
Thanks for choosing FixYa today, and in the future.
John
Feb 25, 2011 | Cobra 150 GTL DX Base CB Radio
Hi i have a sega megadrive 2 and have only just got it out, but now have a Bush digital TV and the Sega is on (power) but I can't either locate the channel or am confused on how it connects up to the Tv to...
I think those have the old style RF connectors.A coaxial cable with a grey or black box in the connection cable.Plug the coaxial cable from outside into the RF cable.Plug the RF cable into the TV coaxial input(regular cable input).On the back of the Sega,there should be a switch for CH3 or CH 4.Put the TV on the appropriate channel.If the signal looks bad,switch the selector on the Sega and change the TV channel.If you do not have the RF cable there is a place that still sells Sega accessories,but not Sega.They must have contracted with Sega.If you need the site let me know.
Aug 02, 2010 | Sega Megadrive Black Console
Hi any one know any cb repairs near norwich thanks
Dunno about any shops near where you live. There are a few good places online you can send the radio too.
Does this radio have an RF GAIN? if it does this should be all the way up. Also, bring down the squelch.
The RF GAIN on a cb radio is how sensitive your receive is. the more up it is, the further you can hear.
the squelch is used to cut off noise. The higher the squelch is, the strong a signal needs to be to hear it, so you will only hear people close.
Oct 08, 2009 | Radio Communications
One day my RV Coleman ac just quit running on low cool but every other setting works fine. Any ideas?
Is your Air Conditioner run with a wall mounted thermostat or the ceiling pack controls? If it is the ceiling pack controls, then your selector switch has gone bad and needs to be replaced. This is located in the ceiling pack itself and is relatively easy to do. You can easily test it with an Ohmmeter, going through these steps:
To check the selector switch, remove wires from the terminals
and rotate the switch to the proper position and read
continuity as follows:
Terminals Switch Position
L-1-3 Lo Heat
L-1 Lo Fan
L-2 Hi Fan
L-1-4 Lo Cool
L-2-4 Hi Cool
* If you do not wish to remove the wires from each terminal,
disconnect the 9 pin plug from the a/c unit.
Hope this helps,
Jeff
Jun 27, 2009 | Coleman Mach 15 Air Conditioner
Shifting into 4 wheel drive
For 4W Hi either be stopped or moving at a slow rate of speed (<20 MPH) and move your 4WD selector to the 4 Wheel Hi position.
For 4W Lo stop and move the selector from 2W Hi to 4W Hi then push down on the selector and move through N into 4W Lo.
Feb 02, 2009 | 1993 Nissan Pathfinder
How do I use the 4WD on a 1993 Nissan Pathfinder?
Dec 20, 2008 | 1993 Nissan Pathfinder
Connex 3300 240-Channels Base CB Radio Logo
103 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Mitch Davis
Mitch Davis
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
