Hisense lcd turns on and off repeatedly
The model is hl55v89pz when the set is turned on within a random amoun of time from initial start up it will go into a cycle of turning itself off and back on again continuously
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Indication of a loose solder terminal/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 24, 2014
  • 53 Answers
SOURCE: TV shutting off randomly
it looks like a faulty mains board. you need to upgrade the tv software with the latest update. if the tv is not accepting the upgrade then it can be a crook mains board.
hope it helps! please rate my comments :D
Posted on Mar 19, 2009
  • 108 Answers
SOURCE: Sony Bravia turns off by itself
Replace the BU Mount pcb. Sometimes they are called the FB pcb.
Posted on Jan 08, 2009
SOURCE: samsung model LNS4051DX/XAA won't turn on, just clicks
THE PROBLEM IS Faulty parts on PS board , bad press for Samsung
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on http://www.fixya.com/support/t1336881-will_not_turn_or_off , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced.
Posted on Jan 01, 2009
  • 92 Answers
SOURCE: Vizio LCD 37 Inch Turns Off Randomly
This could be a main board or power board issue. replacing main board and/or power board should resolve this problem.
Posted on Jun 16, 2009
I had a similar problem with my 32 inch plasma tv. I called vizio's
1 800 number and the guy said to unplug the tv from the wall and hold down the power button for a minute and then plug the tv back in outlet and turn on. And it works I guess from what I understood from his heavy accent was that the tv retains power and this resets it somehow. hope that was helpfull!!
Posted on Nov 04, 2009
How do you turn up the volume on hisense ledn32d33 without a remote
See if the set has volume controls on it. Some sets have a power switch and volume/channel controls on them.
May 29, 2016 | Hisense Televison & Video
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Hisense TL1700 17 in. LCD Television
Where can I download instructions for utilitech timer
UTILITECH - Grounded in Quality
Digital 2-Outlet Timer (TE06WHBL)
Instruction Manual & Warranty
Before using your timer please read the following instructions carefully.
FEATURES
- Up to 8 ON/OFF events per day/56 ON/OFF events per week
- Option to program individual days or 8 different weekday groups
- Minimum switching period one minute
- Summertime/wintertime change over
- Easy to read LCD display
- Random automatic ON/OFF security feature
- Countdown feature
- Manual override button
- Rechargeable battery back-up (if there is no LCD display, plug
timer into a wall receptacle, this will recharge the battery)
SETTING TIME
Press and hold CLOCK key, then press DAY key to select correct day,
HOUR key to select correct hour, and MIN key to select minutes. When
MIN key is released, time will be set with seconds starting from 0.
Either holding down or repeatedly pressing appropriate button can
advance days, hours and minutes.
Do not set ON and OFF for same time.
PROGRAMMING EVENTS
The timer has the capacity for 8 ON/OFF events per day.
Save program capacity by using available blocks of days.
Blocks of days are:
1. M,T,W,Th,F,S,Su
2. Individual days of the week
3. M,T,W,Th,F
4. S,Su
5. M,T,W,Th,F,S
6. M,W,F
7. T,Th,S
8. M,T,W
9. Th,F,S
For each ON time and each OFF time--DAY, HOURS and MIN must
be set. Press PROG key onceto set first ON time--"ON" and number
"1" appear to left of LCD display indicating to enter first ON time.
Press DAY button to choose required day or blocks of days, then set
hour and minutes using HOURS and MIN buttons. After setting required
ON time, press PROG button to validate entry and move onto first
OFF time--"OFF" and number "1" appear to left of LCD display
indicating to enter first OFF time by using DAY, HOURS and MIN
buttons as above. Press PROG button to validate this entry. Repeat
remaining 7 ON/OFF settings as required. After setting required
ON/OFF settings, press CLOCK button to return display to clock. Timer
is now ready to operate. Check programmed settings by pressing
PROG button repeatedly--each setting will appear on screen.
MANUAL OVERRIDE
To choose permanent Manual ON, permanent Manual OFF,
Auto ON or Auto OFF, press Manual button. Each mode will be
displayed on screen. When choosing Auto ON, timer turns ON until
next programmed OFF time. The programmed settings will only work
on Auto mode. When Auto mode OFF is chosen, timer is OFF until
next programmed activity. (Inverted black triangle on LCD points
to either AUTO or MANUAL indicating which is selected)
COUNT DOWN FEATURE
To enter count down feature, press CLOCK and PROG buttons
simultaneously. Using HOURS and MIN buttons, set count down time.
(Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
Press MANUAL button to start countdown. Output will turn ON until
end of count down. Count down may be paused at any time during
period by pressing MANUAL button. To re-start, press MANUAL button
again. To review time during count down period, press and hold
CLOCK button. Release CLOCK button to return to count down display.
Note: To return to timer mode, press CLOCK and PROG buttons
simultaneously.
RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
With this option selected, timer will switch ON and OFF in a random
pattern at least once in every 8 hours. (This may mean timer will
switch OFF within a set ON period, or vice versa.) Ideal for use with
a light--switching it ON and OFF automatically gives appearance of an
occupied home, but not at exactly the same time every day. To enter
Random mode, press DAY and HOURS buttons simultaneously.
An "R" will appear on display and unit will start random switching.
If no programmed times are set, timer will switch ON or OFF
approximately 1 minute after entering Random mode, then continue
randomly. To turn Random mode OFF, press DAY and HOURS buttons
together again.
SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
To change from wintertime to summertime, press HOURS and MIN
buttons simultaneously. Clock will be set forward one hour and
"S" will appear on display. Repeat same procedure to return to
wintertime.
Note: if unit is purchased during summer, set clock time for one hour
less than correct time, select Auto mode and press HOUR and MIN
keys simultaneously. The unit will then adjust to correct summertime
and "S" will appear on LCD.
RESET
To reset unit for time and programmed ON/OFF settings,
press RESET button.
IMPORTANT SAFETY PRECAUTIONS and
RATINGS
[Contact the manufacturer; I've already wasted too much time typing
this in:
AmerTac
Saddle River Executive Centre,
One Route 17 South, Saddle River, NJ 07458
800-777-0802
www.amertac.com
Made in China
May 05, 2010 | Kitchen Appliances - Others
Hisense LCD remote code
Turn on the TV and point the remote at the TV,press and hold TV and OK at the same time for 2 seconds,all the buttons on the remote will light up,for 2 seconds,after that only the numbers 1-12 will remain lit. Press the CH/PG button to send a series of off commands to your TV,repeat until your TV turns off,press the TV button to save the code and exit,all the buttons will blink 3 times to confirm code. hope this helps..
Mar 27, 2010 | Televison & Video
TV has sound but no picture...
This is a pitcure tube problem, either you buy another picture tube and change it on your TV or if this is under warranty better to send it back to the manufacturer and have this one repair.
Jul 14, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Changed battery in key now it doesnt work 2004 mini built in 11/03
1.) Close all doors
2.) Switch the ignition switch to KL-R (first turn), switch back off within 5 seconds and remove the key
3.) Within 30 seconds, press and hold the unlock button and at the same time, press and release the lock button (3) times. (Must be completed within 10 seconds)
4.) Release both buttons. The doors will lock/unlock to signal a successful initialization.
5.) If additional keys need to be initialized, repeat steps 3-4 within 30 seconds
6.) Switching the ignition to KL-R completes the initialization
May 17, 2009 | 2003 Mini Cooper
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
