Timer on zanussi ZBF 560 keeps resetting to 12:00 and buzzing. All timers are showing 0:00
When pressing the middle function button repeatedly, I only get the choice of selecting the top left function (cooking duration) and the bottom right (time)
SOURCE: LTE6234 Whirlpool Twin Thin Timer Broken?
The problem I have with my Whirlpool ThinTwin is that when I pull the washer knob the water does not start filling even though there is water in the apartment unit. The dryer works so i know there is power and not a circuit breaker issue as I have checked that as well.
When I turn the knob and pull in any position nothing happens. Any suggestion would be greatly appreciated.
Posted on Feb 03, 2008
jsrock516
  • 5911 Answers
SOURCE: Timer Replacement
There should be a pull tab on the back side of the timer that you pull to release the timer knob. Most parts come with directions on how to install. I hope this helps you.
Posted on Mar 28, 2008
  • 19 Answers
SOURCE: Ignis Oven functions
Definately the control with 2 lines where the fan kicks in. The grill and oven elements will come on. The fan will disperse the heat from the grill element evenly and more quickly inside the oven. You will need to reduce cooking temperatures by about ten percent though,or youll burn your dinner. Also keep food down ,not too close to grill element at top of oven, middle is fine. Hope this helps. Regards..
Posted on Jun 02, 2008
IFIXALL
  • 868 Answers
SOURCE: Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
Posted on Jun 07, 2008
SOURCE: WCVH6800J GE Front loader timer keeps resetting
The clock timer might be faulty.Need to Replace it.Since the machine is new, it must be under warranty and can be subjected to replacement.Problems with clock timers is common with any washer.Its better when detected early like in this case.Good luck.Please do post your comments.
Posted on Jan 16, 2009
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    How do I program a Noma N1506 timer?
    All Woods timers and manuals
    ttp://waterheatertimer.org/Woods-timers-and-manuals.html
    N1506 manual:
    http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
    N1506 is heavy duty outdoor timer with display screen.
    Plug timer in and display flashes C.
    Set current time: press Time button once and display shows 1 am
    Keep pressing time button until current time with am pm displays.
    Dot in lower right corner corresponds to pm hours.
    To set timer program:
    Press Mode button, display flashes P
    Press Time button until desired ON time displays.
    Press Mode button again and display flashes E
    Press Time button until desired OFF time displays
    When programming is finished, press Mode button and display shows current time.
    To reset timer, unplug timer for 10 seconds and re-program timer.
    Timer must be reset after power outage. Display will warn by flashing C.
    Plug lights into timer.
    If lights have a switch, switch must be on.
    For manual override, press Mode button, and display shows O and lights will be ON until next program change.
    To use timer function, press Mode button until current hour displays.
    Dec 12, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
    How do I set the Woods N1506 timer?
    N1505 timer manual:
    Dec 01, 2010 | Woods Outdoor Lighting Timer
    Model N1506, I need Operation instructions for this Woods Light Timer?
    N1505 timer manual:
    Dec 01, 2010 | Hardware & Accessories
    Oven failer
    You have reset the timer from the auto function, to the manual function.
    You should see a hand symbol showing for manual operation.
    It is a question of pressing the buttons in the correct sequence., or if it is a anologue timer, turning the knob until you see the hand symbol showing.
    Hope this helps.
    Dec 24, 2009 | Zanussi ZBF360X Electric Single Oven
    Zanussi oven timer buzzes at 20.00 then resets to 12.00
    Gave up and bought a new timer module for £66 from espares. Timer board has microscopic components so even if you knew what was wrong it wouldn't be fixable.
    Sep 22, 2009 | Zanussi ZBF360 Electric Single Oven
    I need to find someplace to download the instructions, since mine didn't come with any
    I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
    I hope this helps.
    SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
    FEATURES:
    24 hour stopwatch
    Time-of-day and calendar
    Alarm clock
    BATTERY:
    Replace with LR41 battery
    TO SET TIME AND CALENDAR:
    From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
    Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
    Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
    Press and hold START/STOP SET button to advance digits rapidly.
    Press MODE button once to return to normal time display.
    From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
    TO SET ALARM:
    From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
    Press SPLIT/RESET button to cycle through minutes and hours.
    Press START/STOP SET button to change digits.
    Press MODE button to return to normal time display.
    From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
    TO ARM/DISARM ALARM SOUND:
    From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
    Alarm will sound when indicator shows in upper right corner.
    Release SPLIT/RESET button to return to normal time display.
    TO ARM/DISARM HOURLY CHIME SOUND:
    From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
    Chime will sound when dashes appear along top of display.
    STOPWATCH OPERATION - GENERAL:
    From normal time display, press MODE button once to reach stopwatch timer display.
    After use of any stopwatch feature, press MODE button once to return to normal time display.
    START-STOP (TIME-IN/TIME-OUT) TIMING:
    With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
    SPLIT TIMING:
    With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
    1-2 FAST FINISH:
    Press SPLIT/RESET button for STOP #1.
    Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
    Press SPLIT/RESET button. The stop time for #2 will now be shown.
    Press SPLIT/RESET button to reset the timer to 0.
    Apr 17, 2009 | Watches
    Zanussi Built-In Oven Clock keeps resetting?
    The 1000uF/10V condensator in the timer unit has to be replaced.
    Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
    Zanussi zbf 760
    Gently but firmly pull one of the other buttons out and use that to reset it... you can buy new buttons on ebay
    Oct 03, 2017 | Zanussi ZBF660 Electric Single Oven
    Clock
    Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
    Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
    As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
    May 07, 2007 | Zanussi ZBF660 Electric Single Oven
    Washing Machines Logo
    14 people viewed this question
    Top Washing Machines Experts
