Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Power supply board broken
I have atx psu, can i use this as a replacement for the powerboard? what total output voltage do i need?
    Top Expert:
  • Sharp Master
  • 75,424 Answers
To know more about this, you have to download the repair manual to this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 24, 2014
Curtis LCD2425A will not turn on
Good day!!!!
TV won't power ON..
This is the common problem..
Power supply board or main board..
Please try this procedure to determine the faulty parts.
  1. Open the back cover.
  2. Check the input of the power supply board it should have 220vac or 110vac depends on your voltage comes from the outlet.
  3. If you don't have voltage input of PSU..Please or try to replace the power cord.
  4. If you have voltage input on PSU..Please check the output voltage of it..It should have 5vdc for the main board,12 or sometime 16vdc for the audio and 24vdc for the inverter board(back-light).
  5. If you encounter voltage drop on the output..Please check the power supply board if have leak/bulged on the top capacitors..Please replace it with the same type,ratings and value.
  6. If the 3 voltages mention above are normal..Your main board is defective you need to replace it because main board is not for D.I.Y repair due to the surface mount type parts on it..
I hope this solution will be helpful..
Thanks for using fixya...
Sep 12, 2011 | Televison & Video
Bravia wont power on
Good day!!!!
TV won't power ON..
Aug 13, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
When I put the plug into the PSU for my sony tower pc the green indicator light just keeps flashing. Now when I unplug the 24 pin connector from the mother board the light on the PSU is steady green. What...
the PSU has Problem . It is not supplying enough voltage to boot the PC, capacitors inside the PSU are weak or damaged. Its dangerus to open the PSU coz, Capacitors have high voltage currents. If you have the Knowledge of electronics, then open the PSU and detect the Weak or Leeky Capacitors and replace them with new one( this method is for experiment and thrill) . But the replacement new PSU is better , perfect and cheaper then repairing the psu from outside. best of luck
Feb 03, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
Power supply or motherboard problem?
Hi talissap,
The blinking light is telling you something about the PSU. First check any AC mains voltage select switches for proper setting. US should be 115. Second if you have a multimeter, you could test the PSU for voltage. Disconnect all power to all components. remove all components from the board including cpu, memory . Leave the PSU only plugged into the board. Press power. If the fan turns on then it's not the power supply. The brand power supply isn't the best, I've seen where you need to wait for 5-20 minutes for the blinking to stop, at which time it will fire up. Now, if it doesn't power up, then it's most likely the PSU.
Good Luck,
Mark
Dec 08, 2009 | Bestec (ATX-250-12E) 250-Watt Power Supply
Current FSP300-60tha(1) psu needs to be replaced. Is there a recommended replacement model?
Is this a power supply in a desktop computer?
If so, any make ATX switch mode power supply will fit in the desktop case (the mounting holes are standard), just make sure the total output wattage is equal to or greater than the original unit. I suggest you remove the power supply and take it with you to your friendly computer shop when you purchase a switch mode power supply.
Oct 12, 2009 | Acer Computers & Internet
What is the 6 pin
You can replace the power supply in this Dell with a normal ATX power supply. Make sure the total wattage is equal to or greater than the old power supply.
Oct 02, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
There should be 12v coming from the yellow wire and 5v from red. Open PC and use a multimeter to check the voltage output connect negative probe to the power supply casing and the positive to the red and yellow wires from the molex connectors. If the readings are below the mentioned voltages then the PSU is faulty. Note if readings can be round off to the given values then the output is fine. cheers.
Nov 22, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
P4T-E PSU
your connector is of two part.it has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Jan 19, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
