Question about Xerox Phaser 7100N - Printer - color - laser - A3, Tabloid 11 in x 17
Fuser unit on time fail
010-338
How can i fix a ricoh afecio Sp 4310N error sc542?
SC542 is a fuser warm-up error, the text below is from the manual:
When the fusing unit is not running after the main switch has been turned on or recovering, the increment of
the heating roller temperature per three seconds is 17°C or less. If this condition is detected five times
consecutively, SC 542 is defined.
The heating roller temperature does not reach the ready temperature while 150 seconds after the heating lamp
has been turned on.
So either the heater lamp has failed, the temperature sensor has failed, or the control board has failed.
Possible causes:
• Heating roller fusing lamp broken
• Defective heating roller thermistor
• Defective BCU
1Check if the heating roller thermistor is firmly connected.
2. Replace the fusing unit.
3. Replace the BCU.
If you replace the fuser unit, you may still need to reset the SC error.
Feb 03, 2018 | Ricoh Office Equipment & Supplies
Fatal error 923, 922
-922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
If this is the first time you have seen the error, turn the printer off and on.
-Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine.
- 923 Fuser Error indicates that the fuser unit is getting too hot while printing or when the printer is idle. Make sure that nothing is stuck inside the fuser unit that can cause the fuser unit to overheat. To check for any stuck sheets of paper in the fuser unit:
Locate the rear door and open it. The rear door opens and drops down towards you.
Look into the back of the printer. See if there is any paper or any other item stuck there that could be causing the fuser unit to overheat.
If you cannot find anything jammed up or broken in the back of the printer, open the upper front cover of the printer and remove the toner cartridge. Look into the printer from the front. See if you can see anything jammed into the back area of the printer.
If nothing appears to be jammed in the printer, the fuser unit or the main power supply of the printer will probably need to be replaced to fix this problem.
Mar 14, 2011 | Xante Ilumina Digital Color Press Printer
I have a continous smudge on the right side of the page when printing on a 2420dn. I have replaced the cartridge with no success.
Your Fuser Film is the most likely cause. These do more often than not, fail prior to the fusing unit needing to be replaced. The test for this is to print a page then shut the printer off when the page is about 1/2 way thru the printer. Just kind of time it from the time it feeds the paper to when the paper exits the printer. Cut this time in half and use that as a guide to when to shut the printer off. Once you do this open up the printer where the toner cartridge is and remove the cartridge. If the page is about 1/2 printed then look at the edge where the smudge usually is. If it is not there then you know it is the fuser. You can either order in a new fuser unit or see if a local repair company will do just a fuser film for you. This is what I do. The fuser film plus labor is about $100.00
The fuser unit plus labor is around $250
Also if the fuser is at fault you will sometimes see part of the image from the top part of the page will get reprinted farther down the page in the area where the smudge is.
Good Luck and Thank You for using Fixya.
May 20, 2010 | HP LaserJet 2420 Printer
My Brother HL-1440 Laser printer is not printing. Whenever I try to print something there is a sound coming from the printer with a high tone, then a low tone. This is the first time I have experienced...
this is normally a symptom of the Fuser unit failing within the printer. our company uses nothing but Brother printers and i have seen this error a few times.
on very rare occasions its not the fuser and unplugging the power lead and leaving it for ten minutes will resolve the problem. if you have already tried this however the problem your getting is to-do with the Fuser unit within the printer being broken..
unfortunately from past experiences a replacement fuser unit for one of these laser printers is actually more than the cost of a new laser printer...
a quick google search revealed this site who are offering fuser replacements for $119.00
http://www.precisionroller.com/fuser-assemblies---units-for-brother-hl1440/products.html
hope this helps.
Apr 28, 2010 | Brother HL 1440 Laser Printer
How to refill oil Fuser at unit at Ricoh Aficio 2232c/2238c
These machines use oil supply units located on top of the fuser unit. They are not refillable order another and replace... continueing to run this machine without fuser oil will cause the fuser to fail and copies to look terrible
Dec 17, 2009 | Ricoh Aficio CL7000 Laser Printer
Replaced fuser and toner units now only prints black pages
Printing on a laser printer has 3 steps:
1. electro-statically charging the "drum", at various tiny "pixels",
to identify where the toner-powder should be placed.
2. feeding toner-powder onto the charged drum.
3. making the fuser produce heat to "bake" the ink onto the printer.
So, a failing unit or failing electronics would "charge" *ALL* of the drum,
thus putting black ink EVERYWHERE onto the page.
Take the printer to a qualified technician.
Nov 13, 2009 | Epson EPL-N3000 Laser Printer
Light flashing Service req E537
E537 specifies that the fuser unit has failed and will require replacing. Before that try removing the fuser, cleaning the electrical contacts and refitting it a couple of times - it could just be dirty contacts or incorrectly seated. To do this, turn off the printer, open the top back cover (if the printer has been turned on the fuser may be hot so be careful). There are two "latches" on top of the fuser which need to be rotated to the unlocked position (look for the arrows pointing to the padlock symbols). Next look at the L/H side at the front of the fuser, there is a little pale plastic "paddle" that needs to be rotated up to allow the removal of the fuser. (NB - on older printers this is a solid piece of plastic held in by a screw, you will need to remove this!) The fuser unit will now lift straight up and out of the printer using the two top latches to lift it. Refitting is a straight reversal of the above. If this fails then visit Epson.com for contact details of a parts stockist near you or just google "Epson C1100 fuser unit" to find an on-line supplier. Hope this helps.
Jul 07, 2009 | Epson Aculaser C1100 Printer
Samsung sf5100 fax shows "fuser error" and I cannot receive faxes but can send ok
The fuser unit will need to be replaced. It's possible that the heat lamp or thermostat of the fuser has failed, but getting those individual items could be difficult. The fuser unit should still be available from a Samsung repair center. Search on line for your nearest authorized dealer. You will continue to be able to send regardless of the fuser.
Jul 07, 2009 | Samsung SF-5100 Plain Paper Laser Fax
C6000 error code
Hi
Error C6000 is displayed when your machine fails to reach the correct temparature at a specific time.
This is a Fuser Unit Problem, try to reset it by--
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
If the reset doesn't work then get your unit checked for fuser unit and fuser unit heat issues.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
Xerox Phaser 7100N - Printer - color - laser - A3, Tabloid 11 in x 17 Logo
168 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
