Question about Marantz SR4003 Receiver
Marantz sr4003 standby - Marantz SR4003 Receiver
Was given a marantz sr4003 reciever but told it has a video problem what to do?
Either live with it or replace unit since repair is not cost effective.
Sep 04, 2016 | Marantz Audio Players & Recorders
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
How to reset marantz sr4003
marantz SR 4003 how to reset (hard reset ) remove power plug from power .Take cover off locate ic 12 (24 c eeprom) short pin 5 to ground while plugging the power in .Unit will show clear on fl screen .if the unit trips again check channels.
Jan 04, 2012 | Marantz SR4003 Receiver
I have one Amp;SR4003.if i on the amp;its showing standby light only.which stage defective.pls give me ans; Regards ...
hi,
check the power supply voltages 5v, +-15v. also check the power on relay driver side. also check is there is any dry soldering in power supply stage. check the output amplifiers is there is any transistor faulty. for any further assistance feel free to contact through fixya.
ok
Dec 23, 2010 | Marantz SR4003 Receiver
Hi, my Marantz sr8001 is on standby mode, can you show me how to reset standby mode. Thanks
Mine is doing the exact same thing! All I want to do is get it OUT of standby mode!
Sep 13, 2010 | Marantz SR8001
Marantz SR4003
Hip shot: No one let's you record digital audio onto analog equipment (yet).
On looking at Page 26 of the manual, that is verified. (See the Notes). Use only the analog audio and it will probably work for you. The A/D switch decides which you will use.
Jan 28, 2010 | Marantz SR4003 Receiver
Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Oct 17, 2009 | Marantz SR8001
Input signals Marantz SR4003
There are four digital connectors on the back of the unit: 2 optical and 2 coaxial. They are marked a s 1 2 3 4. 1 and 2 are optical, 3 and 4 - coaxial. Also you have front optical connector marked as F.
You can connect 5 digital sources to your receiver. For example, connect your DVD to input 2 (optical) by optical cable and connect your DSS to input 3 by coaxial cable. Assign DVD to digital 2 and DSS to digital 3 in input setup menu.
Aug 14, 2009 | Marantz SR5001
Marantz SR8001fail to standby mode, will not reset
Test all your speaker impedances and check for shorts on both wiring and speakers. Use a digital multimeter. If you still have an issue, disconnect all speakers and test receiver. If you still have a problem, post a comment and I can help some more.
Aug 07, 2009 | Marantz SR8001
Marantz SR4003 Receiver Logo
43 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
