It was phone freezed.. please offer me some unlocking codes
I suggest you can get the unfreeze code from Prounlocking.com and remove the freeze.After that you can get the respective unlock code for your Samsung Star Duos 2 GT C6712 and remove the network unlock easily.
SOURCE: phone freeze unlock code
UNLOCK MOTOROLA SYNC
DO NOT TRY MORE THAN TWICE ... u can only do 3 attempts .. if the third don't work u will freeze your phone
Unlocking the Sync Instructions
The idea is that you are changing your phone's 8-digit unlock code to all zero's.
(1)Turn off your phone and remove the sim card.
(2)Then power the phone back on.
(3)Enter the following numbers on the keypad: *2767*3855# this will restart your phone,
(4)When your phone has restarted and powered back on you will enter the following into the keypad *7465625*638*00000000*00000000#
If your phone says wrong password, turn your phone off and put in an
unaccepted Sim Card into the phone (A sim card from another Service
Provider) and then start the process over again. If it says wrong
password even with the wrong Sim card, then you have reached your
second attempt, Do NOT try it again. Instead, go to Ebay and purchase
an unlock code.
(5)NEXT ENTER #7465625*638*00000000#
(6)AND THEN *#7465625# to check the locks....all locks should now be inactive or Off
If you find that some of your locks are still turned on, now
that you know your phone's unlock code, (00000000) you can use the
following codes to unlock individual locks on your phone (Where you see
the word Code you will put in your new unlock code, which is now
00000000:
#7465625*638*Code# = Disables Network lock
#7465625*782*Code# = Disables Subset lock
#7465625*77*Code# = Disables SP lock
#7465625*27*Code# = Disables CP lock
#7465625*746*Code# = Disables SIM lock
#7465625*228# = Activa lock OFF
you need first to have the phone unlock by taking it to a mobile store, then also have them firmware reflash on the phone.
SOURCE: Samsung u900 phone freeze
I hate to be the bearer of bad news but phone freeze is pretty much the end of the line. That is a security feature in the base firmware. If a security code is entered incorrectly too many times, the phone completely locks up. At that point, it is pretty much useless.
Samsung has implemented this so that you have to send it back to them.
Unless you know someone that can reflash the main firmware, its bricked.
Please be fair and at least rate as helpful, because there really is no "fix ya" solution available for phone freeze.
