Question about Ricoh Office Equipment & Supplies
I cannot send or recieve fax
I cannot send and receive fax
    New Friend:
    Problem Solver:
  • 12 Answers
Did you check your phone line using an analog phone, to start with? Do you hear a dial tone? Hope you're not connecting your machine to a digital line :)
Posted on Mar 24, 2014
  • 105 Answers
SOURCE: Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
Posted on Oct 05, 2008
Ajkill
  • 2035 Answers
SOURCE: HP6450 says fax log is full and cannot recieve or send.
  1. Press the Setup button (c01361401.giftools ).
  2. Press the Right arrow button (c01185072.jpg> ) until Tools displays on the control panel, and then press OK .
  3. Press the Right arrow button (c01185072.jpg >) until Fax Log displays on the control panel, and then press OK .
  4. Press the Right arrow button (c01185072.jpg> ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
  5. Press the Cancel button (c01235250.gif ) to exit.
Posted on Jan 20, 2009
SOURCE: Not receiving fax on my Lexmark X6570 coming from a computer
on a lexmark if someone send you a fax ,first the machine has to be in fax mode ,then when the phone start ringing you have to press the start button or #9 button
Posted on Jul 27, 2009
SOURCE: I can not send or recieve faxes. Ran fax test
you need to find a telephone with 2 conductors and not 4. I tried it and it worked. Cable phone service does not use VOIP it actually uses services similar to the telephone company. Instead of converting the analog signal of the phone somewhere down the street at the switch it converts it to digital at the cablemodem and sends it at different frequency on the cable. It then goes to the cable company and hooks into the regular telephone system.
Posted on Sep 05, 2009
MUKHTAR
  • 2022 Answers
SOURCE: I can't recieve faxes with my HP Laserjet 3015
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Posted on Mar 19, 2010
Testimonial: "Thanks. I wasn't sure why you suggesested setting the ring #, but changing the setting to auto was right on."
Can I send and receive faxes?
u need to have a modem that can send receive fax, then install faxing software in computer, install dell drivers then setup modem, and send recieve program, to send fax u scan n save then use fax program to use image sometimes it may scan and send at same time? read manual with program
Aug 22, 2015 | HP Photosmart 3210 Printer
I can send fax but not recieve fax
Check your Ink cartridge if it is fully empty means it will not print received faxes so it will save in memory
Feb 04, 2013 | HP Officejet 4215v All-in-One Printer
Fax can not recieve. It sends okay. Hp fax 1010
Most likely the machine has been set to "manual receive" from either "fax/tel" or "automatic" receive. check your manual to check/ change the setting.
May 26, 2009 | HP 1010 Plain Paper Inkjet Fax
Cannot recieve or send faxes
Check out the Easy Setup Instructions available here. If you can neither send nor receive faxes, you may not have the phone line connected to the correct port, see page 34 of the guide. Also check what receive mode the machine is set for. Pages 42 and 43 explain the different options and how to change the receive mode.
Mar 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Can't receive faxes but can send them okay
The easiest thing to check is the recieve mode setting. most of the time when this happens the machine is set on manual recieve. Set it to automatic recieve and you should be fine.
Oct 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Fax will not recieve
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
Nov 03, 2007 | Brother FAX-575 Plain Paper Thermal
Fax was set for two line use, now is using only one - how do we change the settings?
This is an older discontiued model as I can recall. Simply just plug the phone line into L1 and leave L2 unconnected. The one that can send will also automatically recieve (L1). L2 settings are prohibit TX and send/ recieve.
Aug 08, 2007 | Canon LaserClass 9000L Plain Paper Fax
32 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
