Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
The fridge side by side door. Freezer & fridge stop working I can hear the motor trying to go but doesn't cool
On my unit the fan popped off I snapped back on and everything went back to proper function on freezer and fridg. Also cleaned coils.
Posted on Jul 16, 2010
  • 999 Answers
When you say motor I assume compressor. No start compressors can be an electrical component like the start relay or the compressor itself. Eric
Posted on Jun 14, 2009
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
Jenn air refrigerator jcd2389ges freezes fridge
Bea, try this. UNPLUG the refrigerator for 12 hours and keep the fridge and freezer doors open. You might lose some food. NOW you will find some water under the fridge. clean that and now power up the fridge. Make sure you hear the motor working. Your fridge will start cooling. Keep at recommended temp.
Mar 07, 2014 | Jenn-Air JCD2389G Side by Side...
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Refrigerator not cooling. doesn't seem like fan is blowing. freezer still working
all that happens is the cold air from the freezer gets blown into the fridge section by the evap fan motor brhind the inside back wall of the freezer so if you open the freezer door and don't hear the fan blowing i would say that yes you do have a bad evap fan motor and that's why the fridge section is warm.next time send the brand name and model number so i can help you better
Sep 17, 2011 | Refrigerators
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
Side by side , fridge & freezer both stopped cooling last night, cleaned every thing this morning, unplugged for about 2 hours, plugged in and can hear fan running, but fridge and freezer do not seem...
did you feel the compressor runing?if not , need to check have power to the compressor. if power ok. i think the start relay or capacitor is bad. but make sure the condensor not drity. sometime it cause the problem. good luck
Jan 09, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Fridge & freezer are cooling on bottom but not
when you open the freezer door do you hear the fan blowing?sounds like the air isn't moving,there's also a damper on the fridge side,the door opens to let the cold air in and then closes,make sure the door is opening,you can take the cover off and put an ice cube on the twirled up metal part to close it and put your hand on it to open it to see if it's working
Mar 21, 2010 | Frigidaire FRS26H5AS Side by Side...
Both Freezer & Fridge compartments not cooling
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath. If that don't work you may be low on freon change fan motor
Aug 12, 2009 | Refrigerators
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
143 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
