Atx smps strtup problem
My smps is starts and stopps suddanly
  • 27,725 Answers
What is smps is it an application ?
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing and replacing the PC power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect ,boot up a computer hard drive
WARNINGBefore you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Test all leads that attach to your hard drive power and data cables IDE ,SATA
the leads from yourMOTHERBOARD TO YOUR HARD DRIVEmake sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
Make sure all leads that are attached to your dvd \ cd floppy drives have secure connections and are not faulty or just replace them they could be faulty.
Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error.
Even something as small as a faulty electrical or fan lead can cause you problems
Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in.
Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
Another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit.
If you can get your computer stable enough
scroll to bottom toolbarbottom of screen right click select task manager
applications you will see whats running if you see anything you dont need running select end now
also under processes see what is ticking over again if you see something you do not need to be running end nowor you might uninstall that program and some unnecessary programs
not having enough computer ram can cause memory dumps
If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always for a guarantee on any ram modules when purchasing them or buy working pairs if possible.
You might have a virus or malware.
Download at least one of these of course it will depend on your operating system.
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
Posted on Mar 24, 2014
No power coming on intel desktop motherboard d845
Check the power supply to the motherboard i.e the SMPS, if it is working the fan of the SMPS will rotate. If the SMPS is ATX you can check it without connecting it to the motherboard. Unplug all the SMPS power connectors from the motherboard and then short circuit the green and the black wire of the 20pin connector of the smps, if the SMPS is working the fan of the SMPS will rotate. If the SMPS is in good condition and working, than it might be a problem in the internal circuit of the motherboard.
Check the process here:-
http://www.jestineyong.com/?p=267
Jul 19, 2010 | Intel D845GVSR Motherboard
Regarding 250W SMPS
250 watt is low under any circumstances, I'd upgrade atleast to a 450 or higher, around 650watt to be extra safe.
Jul 06, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
HOW CAN WE SOLVE LOAD PROBLEM OF ATX SMPS
First, I am not very good with acronyms, so what is an ATX SMPS.
I have a feeling it is an ATX style Power Supply which cannot handle a load. What are we talking about per voltage rail and where do you think the drain comes from?
Mar 27, 2010 | ASUS PSU | A-45GA 450W RT (A45GA) Power...
How to use ATX-250-12z SMPS with 24 pin
Chances are that 250w power supply is not going to power a motherboard with a 24 pin connector, but you can try.
You will need to purchase a 20 to 24 pin adapter cable.
Google Search Terms: 20 to 24 pin adapter
Oct 27, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Do not start
First remove smps power suply unit box from cpu.
Then ground pin and check is it on you have to ground 4-5 pin blck and green.
Then if it is on then smps is ok.then pull cmos cell from motherbord for 10 minutes make sure cmos cell give voltage.Remove pci cards from pci slot is any.
connect ATX power supply to motherbord then check.
But if smps is not turn on then it has some issue.
Change fuse of smps if still not on then you have repair it or change.
Let me know if you need further assistance.
Thanks.
Oct 26, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Pc not switching on even after changing smps. even fan not switching on in smps
Dear,
You can test you smps simply by shorting any of the back wire and green wire. this will switch on your smps withour connecting with mother board. IF it the fan rotate, SMPS is ok.
If you need more trouble shooting on SMPS you have to measure the volate on each wire after powering on.
More info http://www.smpspowersupply.com/connectors-pinouts.html
Oct 13, 2009 | E-Machines 230W Micro ATX Power Supply,...
Power problem in intel d865gvhz
Pull cmos cell from motherbord for 10 minutes.
So all motherbord settings defaults.
Then reconnect ATX power supply connector from smps to motherbord.
If still face same issue then you need to change or repair your SMPS.it is in back top side of cpu cabinet.
Try with other smps if still same issue then your motherbord has some issue.
You can trouble shoot this issue with above step follow 1 by 1 .
Let me know if you need more assistanse.
Thanks.
Aug 26, 2009 | Intel D865GVHZ Motherboard
I have acer extensa 5630ez. turned it off on wednesday and it wont trun back on.
Is it getting any power to the pc? Are any lighs coming on or anything? If not, your power supply will need to be replaced
Aug 07, 2009 | E-Machines eMachines Desktop PC
After a BIOS flash 2nd LAN is not working
I would try this uninstall the lan card driver shut down the machine, remove the lan card from PC. start the machine let it strtup fully then close down the machine again and put back in the lan card and reinstall the driver.
Dec 09, 2007 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Computers & Internet Logo
David Payne
David Payne
