Question about Clarion Car Audio & Video
Clearion eq how to hook up the right way
Where is pre out im having trouble hooking up amp and eq
You have to use the TAPE 2 (or monitor) on the receiver. It will take two sets of RCA cables. Both the receiver and the EQ will have an input and an output.
  • Run the output/REC (from TAPE 2) to the input on the EQ.
  • Then, run the input from the receiver (TAPE 2 again) to the output on the EQ.
The EQ will have another 2 sets of RCA jacks to hook up a second tape deck (because you used the jacks on the receiver for the EQ). You don't have to hook anything to these if you don't want to, or don't have a second tape deck.
The receiver will have a monitor button, which most of the time is labeled as TAPE 2/MONITOR. Select whatever input you want to use (CD, Tuner, Aux, etc.), then press the MONITOR/TAPE 2 button. When that is on, the EQ will be in the audio chain - you'll be able to use the EQ to adjust the sound. If you turn the MONITOR off it will take the EQ out of the audio chain - the EQ settings won't affect the sound.
Keep in mind, the EQ will also have a button to select the TAPE 2 input. If you have a second tape deck hooked up to the EQ, this is how to use it. Make sure that the tape input is off on the EQ, if you aren't listening to that second tape deck.
Mar 09, 2016 | Audio Players & Recorders
How do I hook up my older model Onkyo AMP (model# TX-20) to my ADC equalizer
use tape out from the amp to line in on the eq (observe left and right)than line out on the eq to tape in on the amp----whenever you select tape monitor and the eq is on your sound is equalized --enjoy
Sep 08, 2010 | Audio Players & Recorders
Im trying to connect a bsr xr eq to my avr687 denon receiver
If you want the EQ to affect the iPod music only, you can hook up the iPod output to the EQ input, then the EQ output to your receiver's AUX input (or DAT input, or whatever you're using to listen to iPod music.
If you want the option of using EQ for other signals as well, then you hook up the EQ to the TAPE inputs/outputs (TAPE OUT goes to EQ input, and EQ output goes to TAPE IN)
If you hook it up this way, then you have to select MONITOR or TAPE MON to get the equalized signal.
Apr 15, 2010 | Denon Audio Players & Recorders
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
Hook EQ to my mixer
I assume you want to put the EQ on the mains output of the mixer -- is that correct?
Just run the left/right out from the mixer to the left/right in on the EQ, then run the left/right out on the EQ to your amp.
May 27, 2009 | Behringer ULTRAGRAPH PRO FBQ3102 Turntable
Hookup
If ur using it for cd player u take the Right Out an Left Out put it in to Eq Right In an Left IN An next to it there is Right Out Left Out an to the reciver you put Right In an Left In Do that with dvd,tape....
what ever it is your trying to hook up
Right is Red
Left is White
Oct 15, 2008 | Onkyo HTR500 Receiver
Jvc kd-g720, hook up eq
yea but you will only have control on the low side of the eq. your beter off using that eq for your mids and highs
Oct 02, 2008 | JVC KD-G720 CD Player
Hi. i want to add a graphic eq to my pioneer receiver (home audio).
if the Eq has enough jacks to run every thing, that would go In to Eq an out to receiver, you were told correctly, for example cdplayer out - to Eq In - Eq- out to Receiver in
Nov 29, 2007 | Spectrum Technical Hifi EQ-B5100...
Equalizer hook up.
only hook up to tape monitor or else u wont get an audio signal . .....also hook all equipment to amplifier not eq ...it goes tape cd tuner and any type of external equipment to amp.then find tape 2 it sould be called tape moniter and have a separet botten for u to select it goes record to eq and play from eq
Aug 27, 2007 | Spectrum Technical Hifi EQ-B5100...
Cannot hook eq to my receiver
The speakers will not sound right. You dont have two tape monitors on this receiver? You can simply use the tape otput to the EQ input, and then the Tape monitor input to the EQ output leads. Good Luck
Jun 09, 2007 | Bose 901 VI Main / Stereo Speaker
Car Audio & Video Logo
35 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
