Question about Lexmark Office Equipment & Supplies
Lexmark ms610dn 31.21 error fixya
Only this
How do you reset the imaging unit on a Lexmark MS610dn
This should reset automatically when you purchase a new imaging drum. If it did not,contact Lexmark as they should warranty the new drum unit.
Aug 21, 2014 | Lexmark MS610DN Laser Printer - Monochrome...
LEXMARK MS610DN CHANGE PITCH FROM 10 T0 12
On the Wheelwriter machines, it is the printwheel that determines what pitch you are in. The wheel has holes in it that a part "reads" the holes when the machine is turned on or when the printwheel is changed. You can not manually change pitch.
May 19, 2014 | Lexmark Wheelwriter 1000 Typewriter
My printer Lexmark X4270 is displaying on it's screen always Error #1203. what can I do?
error 1203 is cartridge error, cartridges has a short
1. press power button to turn off your printer
2. unplug your printer to the wall outlet
3. plug in your all in one
4. reinstall your cartridges
if this does not resolve the problem replace your cartridges with new one
for more trouble shooting option :
1. click start> program> lexmark 4200 series> lexmark solution center
2. click the trouble shooting tab on the left side of the screen
i hope this helpful
thank you for using fixya
Feb 03, 2011 | Lexmark X4270 All-In-One InkJet Printer
How to solve the error Lsu Error of lexmark x215.
Hi shirazsoleja
Unplug the power cord and plug it back in..If this doesn't fix the problem call service support in the U.S. or Canada, call 1-800-Lexmark (1-800-539-6275). For other countries/
regions, refer to http://support.lexmark.com.
Hope this helps cheers nikki
Please rate the answer. Thanks for using FixYa.
Jan 15, 2011 | Lexmark X215 MFP All-In-One Laser Printer
Instalation error when trying to insatall lexmark x5470 all in one printer. error is required section was not found in the INF
The mesage you are receiving is telling you that the information required in the inf file on your installation CD is not there, so the installation CD cannot load the lexmark drivers to your PC.
You will have to go to the Lexmark website and report this problem to a technician in their support group. Your link is http://www.lexmark.com/support
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech o
Dec 22, 2010 | Computers & Internet
Printer does not work. is Lexmark x4270 . I replaced cartridge and it shows on panel this message: Error #1203
There are 3 step to repair lexmark 1203 error
If you got lexmark 1203 error then there is a 94% chance that your computer has registry problems. To repair lexmark 1203 error you need to follow the steps below:
* Step 1 - Download a lexmark 1203 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair lexmark 1203 error.
Here are the url of lexmark 1203 error repair tool:http://www.fixerrorquick.com/ttfix-lexma… http://www.fixerrorquick.com/ttfix-lexma…
Jun 29, 2010 | Computers & Internet
Just installed 2 new new ink cartridges now it shows error 1203 HELP
Try following these troubleshooting instructions from Lexmark.
Error 1203 Troubleshooting
Thanks for using Fixya. Hope this helps.
Sep 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
My printer lexmark e352 shows an error code 84 replace fotoconductor unit. How to reset this error code
The above error code refers to :-
The Transfer drum has reached the end of it's life and must be replaced. May require service technician
Press "GO" to clear message and temporarily continue
Hope i helped you.
Thanks for using "Fixya".
Jun 23, 2009 | Lexmark E352dn Laser Printer
Lexmark all in one error
hi deborah,
thanks for using fixya.
The error that you are getting as well as the solution to the error can be found in the device's manual. troubleshooting also includes illustrations on how to get things done.
here is the link from lexmark.
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
hope this helps.
regards,
voodoo
May 16, 2009 | Lexmark X5150 All-In-One InkJet Printer
434 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
