Question about Unitech Electronics Co., Ltd TB100-0A62UA7G - Tb100 Ruggedized Tablet
Unitech Tb100 firmware - Unitech Electronics Co., Ltd TB100-0A62UA7G - Tb100 Ruggedized Tablet
How to update tablet firmware
If there is a new version available, follow these steps :
Tap "check update" in "Settings"
Then go to "about" and go to "system update" to check if the firmware is latest.
Steps to update :
1) Go to "Need Help?" page of ASUS official website http://www.asus.com/support to download ZIP file of firmware.
2) click the ZIP file after downloading is completed
3) Connect your tablet with PC via micro USB cable, and copy the ZIP file to the root dictionary of internal storage of tablet
4) Detach micro USB cable from the tablet to make the notification for firmware update popped up on status bar
5) Tap "System Update File Detected.." and follow steps to update firmware
Now your firmware is updated.
Nov 21, 2017 | Tablets & eReaders
Firmware for proscan plt7100g
The only firmware for the PLT7100G is available here: http://www.proscanvideo.com/item.asp?itemnmbr=PLT7100G . The direct link to the firmware is http://www.curtisint.com/html/custservice/manuals/PRO_PLT7100G_FIRMWARE.ZIP .
Unfortunately, this firmware update may not help with the app problem that you are having.
Jun 02, 2016 | Tablets & eReaders
Why does kocaso scan my SD card and reset to factory settings every time I power it on?
You need to reload the firmware as it cannot find working android operating system. It also cannot find the firmware program on the SD card which needs to be blank, when you write the firmware load on a PC.
See instructions here. Support Firmware
Jan 12, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
Where can i download the firmware for my tablet irulu 10.1 "
Only when a brand like irulu offers an update of the firmware, you can download firmware. But I think now you ask for firmware you even can't use new firmware. I think you have bricked your tablet. But to load firmware, your tablet needs to work correct. If during an update (or while rooting) something goes wrong, you can't put in new firmware, because the tablet does not know what to do with the USB connection or with the memory card holder. Only a workshop with the correct tools can put in some firmware.
As soon as irulu has an update of the firmware they will notify registered users they can download the firmware and they also provide a manual, how to do the update. There are always warnings, if something goes wrong during an update, you can end with a bricked tablet. But if it is a regular update, they also tell you who to contact if something goes wrong.
Try to fine a certified irulu repair centre and ask them for help. (and what it will cost)
Aug 25, 2014 | Tablets & eReaders
Forgot password for Craig CMP741e tablet. tried to reset factory settings (holding on button with volume button) but wouldn't do anything
The only way to fix this is by restoring the firmware. There are two different firmware loads for that tablet, depending on the manufacture date. You can download the firmware for the older CM741E from the web site, but the newer firmware you can to get provided by Craig.
You will either need to make a bootable MicroSD card using Phoenixcard, or use a special software called LiveSuit to push the firmware into the tablet.
Oct 06, 2013 | Tablets & eReaders
I need free firmware and drivers for 7 inch dragon touch sentry chinese tablet
You can use the momo9 firmware. 4.0.4 works great.
http://www.virtual-productions.nl/default.asp?page=21
Firmware for the Visual Land Connect 7 Works good too.
Jan 22, 2013 | Tablets & eReaders
CURTIS LT7052 TABLET
1.Go to curtis website and get the new firmware package for your device.
2.Google and download TopNotchTablets_Wopadi7_Firmware_Tools_Package because the driver needed is missing from the Curtis website file
3.get windows to NOT recognize your plugged in via USB tablet via the instructions on the curtis firmware instructions
4.point the installer to the correct driver in TopNotchTablets_Wopadi7_Firmware_Tools_Package
5.open and point the firmware application to the unzipped location of the firmware
6. when you see green in #1 then click update firmware,
Jul 18, 2012 | Tablets & eReaders
Archos 10g2 wont load up
Just flash the default firmware from the manufacturer:
http://arnovatech.com/support/firmware/2/arnova10g2/111010/update.img
http://arnovatech.com/support/updates.html?country=us&lang=en&p=2
Flashing a firmware means installing it in the device protected flash memory, more explanations here: http://www.addictivetips.com/mobile/what-is-meant-by-firmware-stock-custom-roms-and-flashing-guide/
The firmware flashing procedure for your device is detailed on Arnova web site:
http://arnovatech.com/support/firmware.html?country=us&lang=en&g=2
Jun 25, 2012 | ARNOVA 10 G2 8 GB PC Tablet with WiFi...
Unitech Electronics Co., Ltd TB100-0A62UA7G - Tb100 Ruggedized Tablet Logo
56 people viewed this question
Top Unitech Electronics Co., Ltd Tablets & eReaders Experts
Are you an Unitech Electronics Co., Ltd Tablet and eReader Expert? Answer questions, earn points and help others
