Question about Ricoh Office Equipment & Supplies
I was trying to upgrade engine firmware, an error sc672 appeared.The machin now cant boot but shows "E32 insert card 1/1 and reboot".Tried put the card and restart same message apears.
Mfp was also giving sc672 and sc670
  • Ricoh Expert
  • 393 Answers
Wow, sorry service call needed! Upgrading firmware is tricky some times the file name MUST be romdata
Posted on Mar 29, 2014
R4 card menu error
Have you gone to the site that is written on the card? Have you tried a different micro sd card to put firmware on?
Jan 16, 2014 | Nintendo DS Lite Console
On my double din stereo it shows **FYTtek firmware A4 update 1.12** Error... Do you guys know how to fix that? It asks to insert a SD card with this firmware.
Go to the manufacturer's site, download the firmware update and put it on an SD Card and plug it into the head unit, and it should upgrade/reinstall the firmware. It may take a while, so leave it alone until it tells you it has completed. It sounds to me like the process was at one time attempted and interrupted. Hence the error message.
Oct 18, 2013 | Cars & Trucks
Ibm t30 boots with error 1820, unauthorized minipci card, remove and reboot
Updating the BIOS firmware will not lose any data on your hard disk.
If the BIOS update is not installed properly or malfunctions then the T30 may stop working unless you can roll back the BIOS update.
Feb 22, 2012 | IBM ThinkPad T30 2366 Notebook
Blackberry Bold fails to boot up
Try to restore the blackberry without the battery inserted. Google instructions on how to upgrade the BB firmware. Does the device seem to boot normally, but with a white screen? Then it's a broken screen. Does it not seem to boot even after the firmware restore or the restore error out - then it's a broken motherboard. Both can be replaced fairly easily. Here is an Blackberry Repair Guide that shows how to open a Blackberry. If you want somebody else to do it for you go to Blackberry Repair.
May 14, 2010 | RIM BlackBerry Bold 9000 Smartphone
Xbox Live with Netgear WNR834M Router
please follow the steps to fix you issue
1.upgrade firmware on router
link for latest firmware
http://kb.netgear.com/app/answers/detail/a_id/863
follow steps to upgrade firmware on router
1.Log in to the router using a Web broswer. The URL is http://192.168.1.1 ( if you did not change the router’s IP address ).
2.Click Maintenance > Router Upgrade
3.Click Browse and find the file you just downloaded.
4.Click Upload. Do not interrupt the upgrade while the router does this step. The router reboots when the upgrade is done.
5.After the router boots up, log in the router again.
6.You MUST Reset the router to default settings after upgrading the firmware
7.Click Maintenance > Backup Settings
8.Click Erase. The router reboots when the Erase operation is done.
9.If you would like to check that the upgrade was successful, log in to the router again at http://192.168.1.1, and check the firmware version.
10Re-configure the router with the settings you saved in step 1. Optionally, You can use the Smart Wizard configuration assistant on the CD to reconfigure the router.
after all this login to router
under advance you will WAN setup there will NAT ,you need to click on open then apply
regards
prakash
Jan 26, 2010 | NetGear RANGEMAX WNR834M Router...
Service Error 49 FF04
A 49 error is a firmware error, it might be caused by the firmware itself, or by the failure of a printer module.
How to isolate the cause:
- Verify that the problem is not being caused by a specific job, this error can be caused by bad information being sent to the printer.
- Power off and remove any installed EIO devices, (JetDirect Cards, Hard Drives), power on and test.
Cold Reset the printer:
- Power off, remove any optional memory, power on and retest.
- Power off and reseat any memory and firmware modules on the formatter board, power on and test.
- Power off, reseat the formatter board, power on and test.
Check firmware version: on newer machines with flashable firmware upgrade to the latest version. If you are running the latest version reload it, this might fix corrupted firmware. (Some printers have flashable firmware, others use a Firmware DIMM which must be replaced to upgrade.)
If you haven't found the cause yet it's time to start swapping parts:
- Firmware module if it's a DIMM as opposed to being part of the formatter.
- Memory if installed, some printers have to have at least one memory module installed to run, and it must have enough capacity to function, in some cases installing a module that does not meet the minimum requirements of the machine will cause a 49 error
Dec 11, 2009 | HP LaserJet 2430dtn Printer
49.FF09 SERVICE ERROR
Go to http: www.hp.com/support/
lj2410, www.hp.com/support/lj2420, or
www.hp.com/support/lj2430. Click
Download Drivers and Software.
Check for the latest firmware image
version at the bottom of the page. If
this firmware image is newer than the
one installed on the printer and the
printer can receive a firmware update,
download the newer firmware
upgrade.
if this fix does not work try removing memory from machine turn machine on see if issue perssist turn machine off replace memory one piece at a time (if you have more than one installed) testing printer each time if you put in one stick and it works then you put in the second and it doesnt the second stick would be the problem piece.. but usually on this machine upgrading the firmware will solve this issue.
Aug 08, 2008 | HP LaserJet 2430n Printer
My creative Zen 8Gb wont allow more than 597 songs..
I'll run a cleanup on your zen, if that doesn't work then you should format it and re-transfer everything. Additionally, you may want to upgrade your players firmware.
How to enter the Zen’s Recovery Mode for Clean Up, Format All, Reload Firmware, and Reboot:
1. With the Zen off, press and hold the "play/pause" button.
2. Continue to hold until you perform Steps 3 and 4. If you accidentally release the button, start the procedure again.
3. Gently push the end of a thin object (like a pin or straightened paperclip) into the Reset hole. You should be able to feel the release click of the button.
4. Slide the On/Off/Lock switch towards the power button and hold until the boot screen appears on the display.
The Recovery Mode screen appears, and four menu items are shown:
Clean Up: A cleanup of the file system and database files takes place. All (uncorrupted) data should stay in tact. When the cleanup is complete, select Reboot. Your player restarts and starts rebuilding its music library. All files should remain intact unless they were detected as being corrupt.
Format All: This will completely reset the Zen and remove all user stored files on it.
Reload Firmware: This will prepare the Zen to accept a reload, new, or older firmware based on the specific firmware file you download and execute on a computer. Selecting this option will prevent your Zen from being able to boot, so make sure you have the firmware file on you computer and ready to load.
Reboot: This will execute a soft reboot of the Zen's operating system.
How to Clean Up, Delete Temp Files, and Reformat the Zen using Zen Media Explorer:
1. Plug the Zen.
2. Go to Zen Media Explorer.
3. Select "Settings and Information".
4. Select the "Tools" Tab.
5. This page will show you the options to Clean Up, Delete Temp Files, and Reformat the Zen.
(Warning: When reformatting, you will lose all files you put on the Zen)
Jun 19, 2008 | Creative Labs Zen Digital Media Player
IPHONE SHOWING INCORRECT SIM AND ASKING FOR APPROVED SIM
This was attempted on 5.11.2008
Hi I was using ziphone with 1.1.4 firmware and wanted to use Quickpwn 2.1. I restored my Iphone from I tunes by clicking and holding SHIFT then hitting restore in I tunes and after it rebooted it asked me to insert original sim-card. I inserted my pay as you go O2 sim-card, which it was happy with. I went to upgrade to 2.1.1 firmware but it asked me to upgrade to the latest I tunes. After updating I tunes I then uploaded the firmware 2.1.1 I then followed the procedures exactly as explained from QuickPwn, everything worked fine. It came to the end which also unlocked the phone but when putting in the unofficial sim-card, it said “Please insert original sim-card.
Jan 30, 2008 | Computers & Internet
362 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
