Question about Weslo Bike
Pedal fell off because of stripped arm what do i do?
Pedal fell off because of stripped metal arm
Pedal stripped
You will need to have that crank arm replaced. They do make repair threads, but the price to install is just as much as replacing the crank arm. Your local bike shop can provide the correct parts.
Mar 28, 2014 | Schwinn Cycling
Stripped bicycle pedal
Better replace the pedal and most probably the crank arm as well. Sometimes a new pedal can cut the threads true again on the crank arm but the crank arm may need replacement too, depending on the damage. Remember to fit the correct side pedal. The pedal threads differ between left and right and pedals are usually marked "L" or "R".
Jan 04, 2014 | Huffy 26" Womens DS-7 Dual Suspension...
How do I fix a bike pedal that fell off and is stipped?
If the pedal post is stripped get a new pedal. If the crank side of it is stripped you can just replace the crank and put new pedals on it.
Aug 12, 2012 | Shimano Cycling
The only way my brakes lights will go off is to take the fuse out. They stay on all the time. Even with the ignition off. Help
THE BRAKE LIGHT SWITCH IS FAULTY OR OUT OF ADJUSTMENT LOOSE FELL OUT THE BRACKET.CHECK UNDER THE DASH WHERE BRAKE PEDAL ARM IS YOU SHOULD SEE A PLUNGER STEM LIKE SWITCH TOUCHING BRAKE PEDAL ARM.IF NOT SWITCH FELL OFF SUPPORT BRACKET.IF BRAKE SWITCH STILL IN PLACE MORE LIKELY BRAKE LIGHT SWITCH IS FAULTY.
Aug 29, 2011 | 1995 Nissan Pickup
The pedal assembly on my blackwater somehow got stripped always had problem with pedals coming off
If the thread on the crank arms that hold the pedals are stripped, you will need a new set of cranks. That is definitely a job for the bike shop. Make sure the pedals are snug in the arm, Right side pedal has right-hand thread, left side (looking down when you are on the bike) has a left-hand (reverse!) thread.
Jul 10, 2011 | Huffy Blackwater Men's 26-Inch Mountain...
Piece of plastic fell off brake pedal rear brake light stays on sometimes
the piece of plastic that fell off may be from brake light switch. it is located in back of brake pedal arm, on the top. the switch may just need a little adjustment or replaced. have a good day !!
Dec 17, 2010 | Honda Civic Cars & Trucks
Gave my 10 year old son a 20" huffy axis this past Wednesday for an early Christmas present. The pedal fell off Friday! How do I put it back on? The pedal, as well as the thing that screws into the...
Your pedal falling off is never a good thing, nor is the entire crank arm assembly.
For this one you are best taking it into your local bike shop and have them take a look at why both of these fell off. There are a number of reasons, from stripped thread to missing bolts and nuts to improper assembly. None of these are a good scenario with a childs bike, or any bike for that matter.
Alternative, and my personal suggestion - Take the bike back to where it was purchased and exchange for a new one. These parts should not fall off after years of riding let alone 2 days, and would constitute a warranty and safety issue.
I WOULD NOT RECOMMEND CONTINUING TO RIDE THIS BIKE, SINCE YOU DO NOT KNOW WHAT ELSE WAS IMPROPERLY ASSEMBLED.
Nov 29, 2010 | Huffy 20in Boys Axis Bike
Bike pedal fell off on a brand new huffy how do i put it back on
If, the threads aren't stripped, you can put it back on by getting a pedal wrench, and standing in front of the bike, now take the wrench and turn it towards you (clockwise) to tighten. But, if you rode with it loose, then you need a new crank arm. If, the store put it together go back to them but if you did, it is not a defect and you have to pay for one.
Oct 05, 2010 | Cycling
My son has the Huffy rock out bike. The pedal fell off, and so I was sent the whole single arm crank and new pedals. I have no owners manual, and no assembly instructions whatsoever. Along with the crank...
The reason the pedal fell of is because of a bad set up. Who assembled the bike? If, you did, guess what! You did not tighten the pedal to the crank arm to begin with. If, Walmart or other discount store did it, have them fix it. You have to understand. you bought the bike without professionals putting it together and sometimes that is a problem when you don't have the knowledge of what you are doing. You have to pay one way or another. When you let a kid ride a bike that is not assembled correctly you are endangering them. My advice is :Get it fixed right.
Sep 16, 2010 | Huffy Cycling
Weslo Bike Logo
35 people viewed this question
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
