Question about HP OfficeJet 6110 All-In-One InkJet Printer
My Officejet V40 keeps wanting to align the cartridges (but won't print anything but the alignment page). How can I get past this?
    President:
  • 3,085 Answers
Replace both ink cartridges with new ones.
Posted on Jun 15, 2009
Need help: our HP officejet v40 will not print.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 06, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
Hp officejet v40. new cartridge but missing blue when printing
Sounds like your cyan print head is clogged. You can try to get it flowing yourself by rubbing the print head with a wet paper towel. If you press the print head on a dry paper towel you should see three distinct lines of color. If you still don't see the cyan, try letting the print head rest on the wet paper towel on a surface that ink can be cleaned up from or one you don't care about staining. If the cyan still won't flow, you should go back to where you purchased it and return it for a new one.
Jan 12, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
Press enter to align cartridges stays on and printer will not print. Print job goes to error.
KEEP A PAGE PRESS ENTER WILL PRINT AN ALIGNMENT SHEET SCAN THE PAGE AND THEN IT WILL WORK
Sep 18, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Hp officejet v40 printer
I'm not sure if this will help but I aligned my cartridge's 5 times then the red exclamation point light stopped to do this hit the setup key #5 (maintenance) then hit # 2 follow instructions... to print full menu settings ..setup #1 then # 4 follow instructions
Jun 15, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
How do i access the print cartidges on my hp officejet v40?
Below is a link to the Setup Guide. Click on it and see steps 12 and 13.
V40 Setup Guide
Dec 07, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Message on fax reads "remove and check color cartridge"
i,ve replaced my set top box remote with a universal one but it does not operate it can you suggest anything !
durabrand cg5660-m set top box & the new remote is total control 4. can you help
Nov 04, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Printing
The printer hp officejet v40xi is asking for a cartridge alignment. When I press enter the printer does nothing want take paper or engage the paper nothing
Aug 12, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP OfficeJet V40 Won't Print
You Need to change the Ink Carttridge. it has either Dried from lack of use or you have run ou tof ink.
you may need to clean the Jets as well a simple Q-tip with some rubing alchol would work.
You could also try the Printers Cleaning Utility, but either way you'll need to replace the cartridges
Andres
Apr 28, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 6110 all in one
I know this sounds dumb, but alignment pages use the color cartridge to make black print. Are you sure your black cartridge is working? and what does the windows test page come out looking like?
Aug 29, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
331 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
