Question about Frigidaire FRS6HR35K Side by Side Refrigerator
Frigidaire Side-By-Side not dispensing water and possibly ice
I have a Frigidaire side by side refrigerator (model FRS6HR35KWO) that has suddenly stop dispensing water. The problem seem to occur between Friday and Sunday because the last time I used the water dispenser (the previous Thursday, it worked fine). Because there was no water coming out, I thought it was a filter issue (the refrigerator doesn't have a filter light) so I replaced it. The water dispenser still doesn't work. I can hear the water inside the refrigerator moving and my hose moving about behind the refrigerator as it always does but the water is not reaching the outside door dispenser. When I remove the filter from the inside of the refrigerator and press the water dispenser lever on the door, the water dispenses inside the refrigerator (where the filter would be attached) with no problem. Once I put the filter back on and try to dispense water, I can hear it working but no water comes out. I'm using a Frigidaire Pure Source filter RG-100. I've used this filter for years and haven't had a problem before.
  • James R.
    James R. Mar 24, 2014
    Update: It appears the ice makes is still making ice as i heard some ice drop earlier this morning. The ice maker is still dispensing ice, however the water is still not dispensing and pooling in the water filter inside the refrigerator itself. When I unscrew the filter (to dump the water that has pooled) there is a vacuum seal like sound (the same sounds I get when I'm purging the line when a new filter is installed. Then all that pooled water starts coming out.
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Posted on Mar 24, 2014
Testimonial: "Yeah I saw the loop of water lines when I took the bins out earlier but I couldn't tell whether or not the lines were frozen. There's a whole bunch of lines zip tied together behind the most top cripser drawer. If these lines inside the refrigerator are frozen, what's the best way to unfreeze them? I don't have an accessory like a hair dryer to use to break that frozen blockage down."
  • James R.
My refrigerator water dispenser stopped suddenly yesterday. Water connection is good, filter is 3 months old, switch clicks on main panel. Have held switch down for a while. ???? Help please
Is the ice still dispensing? If you still are able to dispense ice then its possible that the water storage tank is frozen. The water tank is located in the back of the refrigerator section behind the crispers so they can sometimes freeze. You can try turning up the refrigerator section 1 setting warmer. If that doesn't fix it it's possible the solenoid for the water side on your inlet valve is bad.
Oct 07, 2010 | GE GSS22JER Side by Side Refrigerator
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire FRS3R3JB stopped making ice and dispensing water.
I have been studying your model most of the morning. The only thing I could come up with that would cause this is an electronic dispenser control. It may be defective.In the control the power is converted to DC and the water control valve work off of DC voltage. I am putting you with the best his name is Brian. His website and blog are different. Website==> http://www.technicianbrian.com/
And here is where most of his help is directed ===>
LINK TO --> TechnicianBrian
one of my sites===>http://appliancepartsandtechnicalservices.blogspot.com/
If you have any problems let me know, Sea Breeze
Jun 20, 2009 | Frigidaire FRS3R5EMB Side by Side...
My water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Water dipsenser not dispensing any water
ONLY TWO POSSIBILITIES I CAN THINK OF IF ITS NEW COULD BE FREEZING IN THE DOOR LINER
IF NOT PROBOBLY NEEDS A NEW VALVE
Feb 18, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
Frigidaire side by side MRS22WNGD0 stopped dispensing ice and water
Even you find the problem you should need special equipment.Better call a technician.This link may help you:
http://www.appliance-parts-warehouse.com/frigidaire-parts/Frigidaire-Refrigerator-Parts/Frigidaire-Parts-MRS22WNGD0.cfm
Nov 18, 2007 | Refrigerators
Frigidaire FRS6HR35K Side by Side Refrigerator Logo
332 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
