Question about Samsung SCH-a930 Cellular Phone
Is there reset button at the back os sch-w720
The small cover at the back is that a reset button
How to remove a battery on a samsung flip cell phone SCH-u36 ?
Just follow the discussion in the owners manual here: http://www.samsung.com/us/support/owners/product/SCH-U365HAAVZW
The battery cover on the back of the phone protects the battery.
Removing the battery cover
1. Hold the phone firmly and locate the Cover Release Latch.
2. Firmly "pop" the cover off the phone.
Installing the battery cover
Align the cover and press it into place, making sure it snaps securely.
Jul 25, 2014 | Samsung Verizon Gusto 2 SCH-U365 Prepaid...
Forget the code for enter parent lock i no remember the code for leap frog
Instructions
    • 1Put the screwdriver into the screw hole in the small panel on the back of the Leapster. Remove the screw, and open the panel.
    • 2 Remove the batteries from the Leapster and discard them. Find the small "reset" button behind the panel cover. The reset button should be black or red
    • 3 Press the reset button with the pointed object. Hold the button down for about three to five seconds.
    • 4 Put fresh batteries into the battery chamber. Make sure the flat side of each battery connects with the springs in each battery channel. Screw the panel cover back into place.
    • 5 Press the Leapster's "on/off" button. When the Leapster comes on, enter the country informationicon1.png and the player's name.
    • 6 Press the "hint" button, which opens a pop-up help menu. Press the "A" button. Use the stylus to touch the center of the small crosshairs on the screen to calibrate the touch screen.
Read more: http://www.ehow.com/how_8430044_reset-leapfrog-leapster.html#ixzz33FgzCf1j
May 31, 2014 | Toys
Samsung sch-u340 wont start up
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 07, 2012 | Samsung SCH-u340 Cellular Phone
How to unlock samsung w720 korea anycall unlock
helloi want samsung w720 cdma Reset user password
Nov 03, 2010 | Cell Phones
Stuck on MITS screen, will not start windows mobile
try a hard reset i tell u how:
1.press and hold the reset button
2. dont let go yet! push the power slider down at the same time
3. let go of the reset button, wait a few seconds then let go of power slider and it should work
else u may need 2 get a new phone or try a firmware upgrade
Jan 17, 2009 | Samsung SCH-i730 Pocket PC
My samsung SCH-i730 is stuck on the white loading screen
You may have to do a major reset on it. First remove and replace the battery and turn it on again. If that doesn't fix it, there is a tiny reset button on the bottom near the connector. You will need to push it in with a small point such as a paper clip wire.
Jan 03, 2009 | Samsung SCH-i730 Pocket PC
Reset button
Are you looking for the Trouble Reset Button? It is behind the top back cover on the Controler PCB, it is a Small BLACK button... Good Luck What code are you resetting?
Nov 11, 2008 | Office Equipment & Supplies
SCH-u740
ok one last shot i can think of is if you take the back cover off remove the battery and the sim card. if there is a reset button it should be there. that is all i can think of. one other thing is did she maybe hit the keypad lock by accident?
Aug 30, 2008 | Samsung SCH-u740 Cellular Phone
How do i reset my cell phone
To Reset the SCH-A930 Handset, to Factory Default Settings, follow the steps below:
  1. While in standby mode, press the OK button for Menu
  2. Select Settings & Tools, using the navigation keys
  3. Select Phone Settings (5)
  4. Select Security (5)
  5. Enter the lock code, the default password is the last 4 digits of cell phone number, unless it has been changed
  6. Select Reset Phone (4)
  7. Select Yes, using the navigation keys
  8. Press the OK button to confirm resetting the SCH-A930 handset to factory default settings
Dec 17, 2007 | Samsung SCH-a930 Cellular Phone
Samsung SCH-a930 Cellular Phone Logo
18 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
