Question about Smeg 28 in. P752 Electric Cooktop
When iserting the plug it shows all the keys on but does notwork
It does not turn on and it is electric hob
Why dko all 4 hobs show L?
Gas or electric? What caused the change? My guess is the knobs were removed for cleaning and not reinstalled properly. There is a flat on the valve stem that must match the flat on the Knob when installed.
Jun 07, 2015 | Cooktops
Turn hob on and only get letter L on each hob and will not turn on
child lock is activated , switch on hob press - and + button simultaneously hob will return to normal. if zeros dont appear try pressing and hold - key slightly before pressing +key hold both for a few secs.
Jun 23, 2010 | AEG 23 in. 6410KF-N Electric Cooktop
Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
May 11, 2010 | Baumatic 27 in. B67 Gas Cooktop
Hob is locked
Press the 'Oven light' for about seven seconds...
Jun 06, 2009 | Bosch 24 in. PIE675T01E Electric Cooktop
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob.
Hi I have just had the problem of accidently locking my Neff Hob.
If you hold down the L Lock button for about a minute it unlocks.
Mar 18, 2009 | Neff 23 in. T4343 Electric Cooktop
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Padlock sybol when try to turn on hob
Jan 12, 2009 | Bosch 32 in. PIE875T01E Electric Cooktop
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 29, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Smeg 28 in. P752 Electric Cooktop Logo
56 people viewed this question
Top Smeg Cooktops Experts
Timllfixit
ray gallant
On-Time Appliance
On-Time Appliance
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
