Question about Lexmark T632 Laser Printer
Which power cord do I use with T632? 110v or 220v?
I bought a used Lexmark T632 at a bankruptcy auction for home use. It had obviously been used, but the only power cord that came with it was a new, unused 220v cord. Is this what has to be used with it? Or can I use a standard 110v?
  • Lexmark Master
  • 3,204 Answers
Check on the back of the unit it will have a power sign somthing like this 110v~240v if it has this then yes you can if not and just 220v mains only then it can only be used on this voltage. same for other like 110v. most are multi voltage but companies can buy none multi voltage systems so if they are stolen they can only be used in an area with that voltage.
Posted on Mar 24, 2014
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
Try to look the description if it is for 220 or 110 and it is 100-220 its ok for both
2 Suggested Answers
wayneard
  • 1901 Answers
SOURCE: I just bought a used Lexmark X1240. The only
Yes, it needs a power cord. Refer to this Setup Guide:
X1200 Series Setup Guide
See step 2.
You can order it from Lexmark. See:
Power Cord 21B0106
If you are not in the US or Canada, Comment back and we'll track the correct one down.
Thanks for using Fixya.
Posted on Nov 25, 2009
Rainbow e2 type 12 120v , accidentally plugged into 220v, would barely power up, possibly controller board defective?
probably need both as the extra 100 volts would burn the board and the motor
it is never advisable to buy electric equipment from another country because of the voltage differences but even then the plugs are made different so that the cord will not plug directly into the power outlet.
Aug 12, 2015 | Rainbow Vacuums
Power cord for Janome MC11000 sewing machine
You need to require parts from Janome, Contact them here
Jul 18, 2008 | kawasaki PVS1080
Need to restore Casio te-4000f to factory settings. Advice?
The instruction manual is here. There is a way to reset the reporting data, if that is what you want. I don't see a way to reset all settings back to factory defaults, though.
Feb 11, 2012 | Computers & Internet
Lexmark E450dn will not power on, power cord is working
This issue may be due to one of the following:
  • An incorrectly set power switch.
  • An improperly functioning power outlet, surge protector, or power supply backup.
  • A poorly connected power or data cable.
  • A defect with a third-party (i.e. non-Lexmark) option such as a memory card.
  • An incorrectly connected or malfunctioning optional paper tray.
  • A malfunctioning printer component.
Please try the following steps:
Step Action 1 Make sure the power switch is in the "on" position. If it is, power off the printer. 2 If your printer's power cord is plugged into a surge protector or uninterruptible power supply (UPS), unplug it and connect it directly to a grounded wall outlet. Some of these devices can interfere with consistent electrical flow and cause the printer to fail to power up properly. 3 Disconnect the power cord from the back of the machine and then reconnect it. Make sure the power cord is plugged in all the way. 4 Disconnect any data cables (parallel, USB, Ethernet) from the rear of the printer. Any defect in a data cable may cause an electrical short circuit that could cause a loss of power to the printer. 5 Turn the printer on, this time with only the power cord connected and plugged directly into a grounded wall outlet. 6 If the printer still fails to power up, power off the printer once more. Verify that the outlet is working properly by connecting another device to it to see if it receives power. You can also try plugging the printer into a different grounded outlet. 7 If possible, try another printer power cord. 8
Verify that the printer is the correct voltage type for the environment in which it is being used. A 110V (low-voltage) printer will not work properly in a 220V (high-voltage) environment, and vice versa.
  • NOTE: Look at the rear of the printer and locate the electrical specifications sticker. Verify that the voltage rating on the sticker is the correct voltage for your printing environment (i.e. 110V or 220V).
9
Remove any third-party (i.e. non-Lexmark) options, such as memory cards, as they may interfere with proper printer functioning. Also remove any paper-handling options such as an optional second paper tray. 10
Attempt to power on the printer once more with all options removed, having verified that other devices work from that power outlet.
If there is still no power, the printer may require service to fix the issue. Please contact Lexmark Technical Support or a local service provider.
Oct 14, 2011 | Lexmark E450dn Laser Printer
My Lexmark X9350 All-in-One doesn't turn on.
Actually, the printer's power cord should be plugged in to a power source having 110-220V output. The power supply (the black box behind the printer where the power cord is attached) converts that power to 30V. Basically, if your wall outlet has power output of 110-220V, you won't need a transformer to convert that to 30V. That's the job of the printer's power supply. Hope this helps. If you need more clarification, place a comment so I can get back to it. Thanks.
Apr 16, 2010 | Lexmark X9350 All-In-One InkJet Printer
See step 2.
Power Cord 21B0106
Nov 25, 2009 | Lexmark X1240 All-In-One InkJet Printer
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KDS RAD-5 monitor set up
THE POWER SUPPLY PLUGS INTO A WIRE STICKING OUT OF THE END THAT PLUGS INTO THE COMPUTER
Apr 15, 2008 | KDS RAD-5GS 15" Flat Panel LCD Monitor
Lexmark T632 Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
