Question about Dryers
Bosch dryer beeps
Dryer beeps twice upon pressing start/stop button. Tried disconnecting from mains for half minute, tried pressing start-stop button 10+ seconds, tried pressing timer button 10+ seconds. Filters clean, heat exchanger rinsed.
  • Myrt Vogel
    Myrt Vogel Mar 24, 2014
    Appliance is condenser dryer model WTE86382 ("Maxx 7 Sensitive"). User manual has no mention of child lock, though various forum searches lead to believe double beep means just that - a child lock. No error code is displayed. Bosch home appliance website has no mention of button combination to either activate or deactivate child lock.
    Problem Solver:
  • 13 Answers
Two Beeps on my Bosch WTE84100au Condensing Dryer means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Posted on Jun 07, 2015
  • 3,187 Answers
My old one used to do the beep beep its the door dryer fluid is low or the salt tank is running out. salt in the bottom and drying fluid in the door.. hope this helps.
Posted on Mar 24, 2014
  •  Russ Hill
    Russ Hill Mar 24, 2014
    oh right lol sorry got the wrong thing entirely was on dish washers lol sorry there is a child lock its what locks the door when in use. its when the door is opened when in use, some lock and some dont but if the door is opened the motor and heat element for the dryer should stop.. there is also a clogging system you may have a back log off fabric fluff build up in the pipe. i'm not getting alot of info on this model keeps coming up in belgium. i am also noticing there is a over loaded switch that will tell you when it is over loaded this could make it beep beep to if the sensor has failed in some way . as long as does stop when the door opens and no other faults are being show it should be fine. but i would have the filter and the out pipe checked to make sure its not blocked.
  •  Russ Hill
    sorry over load sensor is the weight in the drum with your items. in.
  • 7 Answers
SOURCE: Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Posted on Oct 25, 2008
Healeyman
  • 1198 Answers
SOURCE: maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Posted on Apr 28, 2009
  • 6 Answers
SOURCE: dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Posted on Jul 30, 2009
  • 51 Answers
SOURCE: WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Posted on Feb 02, 2010
SOURCE: Dryer stops and bips - message F03
03 indicates as a rule that the alloted drain period has elapsed. Usually it is a pump failure or a blocked (or partially blocked) drain out system? You say you have cleaned out all the hoses and replaced the pump, well now it's best you just run a test to see how quickly the machine empties? In fact it should be less than 60 seconds and if it's slower than that I guess you've got a button or something blocking the drain outlet somewhere and acting as a gate valve no doubt.
The other thing you could check whilst your at it is the air chamber at the back of the tub. White clear plastic bottle above the motor, if that is gunged up you could get spurious error warnings like F03?
Posted on Feb 27, 2010
I have a GE dryer model #DCVH660EH3BB, it powers on but when I press the start button it beeps twice at me and won't start the cycle. The lint trap and vent have both been thoroughly cleaned.
From the manual...
Problem
Cannot make a selection and the dryer beeps twice.
Possible Cause
The DRYNESS LEVEL, TEMP or OPTION that you are trying to select is incompatible with the chosen dry cycle.
Link to your manual, troubleshooting starts on page 24.
ShopYourWay GE Residential Dryer ShopYourWay
Jul 22, 2016 | GE Dryers
My bosch maxx 7 sensitive dryer is not working - no lights are lit up, door is closed, filter is clean, container is empty, just beeps twice when i pusch start
Well I would recheck the water reservoir is fully inserted ....the door has no debris inside the lock....the bottom filter is cleaned not just the door filter.if this still not fixes then try a reset by switching off at socket then whilst holding start button without releasing for at least five seconds turn on power and listen for a click.sometimes a sensor is stuck and not relaying proper status.
Feb 22, 2015 | Bosch Dryers
Instructions for oxo model 1061978
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Feb 17, 2013 | Oxo Hardware & Accessories
The dryer starts and works for about five minutes and then stops and starts beeping.
Is the fluff filter clean? if not it could be causing it to overheat and shut off.
Dec 22, 2012 | Miele T7744C Dryer
My dryer Bosch maxx 7 doesn't work
That is a bad motor. It is overheating and the overload is shutting it down. Check to see if there is lint buildup on the motor. If not, you will need a new motor.
Nov 04, 2012 | Dryers
Both of my ink cartridges went out at the same time and i only replaced the black. now it has an error saying it will not print because i need to replace the color ink cartridge. but i'm trying to...
It depends on the model that you have. You can try one of the following to reset the ink counter and the printer will show a full color cartridge.
This is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
1. Disconnect the power cable.
2. Hold down "On/Off" button.
3. Reconnect the power cable.
4. With the power button still down, press the "Stop/Reset" button twice.
5. Release the "On/Off" button.
6. The printer is now in "factory mode".
- wait until "idle" is displayed.
7. Press the right arrow button (next to the "OK" button) repeatedly until "Shipping Mode 3" is displayed.
8. Press the "OK" Button
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470).
10. A test page should print.
11. Open the cover.
- the cartridges should position themselves at the far left - the cartridge removal location.
12. Disconnect the power cable.
13. Remove both cartridges.
14. Close the cover.
15. Reconnect the power cable.
16. Press the "On/Off" button once.
17. Wait until a "Replace Cartridges" message is displayed.
- insert cartridges.
18. Wait until the printer is operating in its normal mode. The display shows the normal start menu (ie: Copy).
The ink levels have been reset.
- check by going to printer>properties>maintenance>view printer status
this is what i had to do to get it to work with canon mp460
2. Hold down power button
4. With the power button still down, press twice the "Cancel/Stop" red button
5. Release the power button
6. The printer is now in factory mode...(wait about 30 seconds until it says "idle")
7. Press the down arrow (next to the "OK" button) until it says "Shipping Mode 1"
9. Now with it displaying "Without Cleaning" press the power button
11. Now open cover
12. Disconnect the power again
13. Take both cartridges out like normal
14. Close cover
15. Reconnect power cable
16. Press power button
17. Replace cartridges
MP-160 is different from MX300 so I tried my best with it...
The main solution is to reset the entire printer:
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button
Aug 30, 2011 | Office Equipment & Supplies
I refill the cartridge of my canon mp496 printer.I print images and everithing is ok but the ink lamps are orange .I don't know what to do ! Please ,help me !!
One of these reset methods should fix the problem
11. Open the cover.
11. Now open cover
14. Close cover
Jul 01, 2011 | Office Equipment & Supplies
Replaced ink compatable cartridges in my cannon pixma 350 and now its telling me to replace them cause the ink is empty Help
This will reset your cartridges to full settings. I have found these resets to work on many Canon models. Try the top one first.
11. Open the cover.
11. Now open cover
14. Close cover
Mar 27, 2011 | Canon PIXMA MX350 Wireless All-in-One...
Dryers Logo
667 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
