Question about Gomadic 2nd Generation Audio FM Transmitter plus integrated Car Charger for the Apple Nano with Gomadi
INTEX CHARGING ERROR
CHARGING ERROR IS SHOWING ON THE MOBILE SCREEN AFTER CONECTING THE CHARGER
My hkc tablet won't charge when I connect it , red light just blinks while conected , what could this be please?
Either your charger is faulty or there is some problem lies with the on-board power section of your HCK Tab. Change / try with another charger or take that to your near by HCK outlet for power section repair.
Dec 17, 2014 | HKC 8" Tablet Dual Core Processor, HD...
When i conect my charger into mobile than mobil show warning bad conect charger
then you have to change your charger and buy a genuine one or one which doesnt show these signs of bad connect charger try connecting while buying itself..
Oct 06, 2011 | Cell Phones
My w850i is not charging when i plug in the charging mobileis hit
Check the following two things carefully:
1. is your charger working properly?(It may be found faulty)
2. is the charging port OK?
If you say that your mobile shows charging in start, and after few minutes it gives an error "charging error stop charging". Then you should confirm first that its charger is original or not. If it is not a original charger, then you should change it...Good luck :p otherwise go to mobile repairing shop.
Sep 09, 2011 | Sony Ericsson W850i Cellular Phone
Charging error.stop charging my sony ericsson k800i
As if your using sony ericsson K800i some mobile phones as this problem as myself also faced the same problem sony ericsson mobile shows this error if you charge your mobile using connector or unsupported charges.You visit your nearest service center of sony ericsson and ask then to give branded sony ercsson charger for your mobile.After taking that charger you will not face this problem any more..your mobile is just perfect as new.Your connector or charger is having some problem with it. Charger may cost you around 300 rs. var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
Jun 12, 2011 | Sony Ericsson K800i Cellular Phone
Nokia 2626 charger not supported solution
my nokia2626is not charging when we conect charger it show charger not supported kindly help me
Feb 22, 2011 | Nokia 2626 Mobile Phone
Charger conectivity
for black and white sidekick, right? if so, then it sounds like its need to get a new charger to give it a better connection. it has been ages since its outdated a long ago.
Ive never heard of that error message said that before. but, yeah..try use another charger and see if it makes the error message go away.
good luck and let me know.
Mar 07, 2009 | T-Mobile Sidekick
Gomadic 2nd Generation Audio FM Transmitter plus integrated Car Charger for the Apple Nano with Gomadi Logo
44 people viewed this question
Top Gomadic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Gomadic Audio Player and Recorder Expert? Answer questions, earn points and help others
