Question about Samsung SCX-4500 Laser Printer
My printer is giving T2 error
I have just installed a cartridge in the printer but it is giving T2 error
Have T2 error message. What does this mean, It won't print.
This message appears
when the toner is
completely empty, and
your machine stops
printing. Replace or refill cartridge .
Apr 03, 2016 | Samsung ML-1630 Laser Printer
Hp laser jet 2840 Error 59.99
T2 Clutch error: Check the cable
connections to the DC controller. If the error
persists, remove the imaging drum and
check the clutch. If the error persists,
replace the T2 clutch. If the error still
persists, replace the DC controller
May 26, 2012 | HP LaserJet 2840 Printer
Problem in hp cp 2025 color laser printer that printer is giving error message "used black cartridge is in use error
This error typically indicates that the cartridge was moved (e.g. previously installed) from another printer to your printer. The error should not affect your ability to print. If you want to clear the error, replace the affected cartridge with a genuine HP replacement.
Aug 10, 2010 | HP laserjet Cp2025dn color Card Printer
Error message HP Officejet 7310 "remove and check cartridge on right. Removed cartridge, checked it (nothing), installed it back - still same message. Installed new original HP cartridge - still same...
Can you find a friend with a similar HP printer, i.e., one that accepts the same model-number of ink-cartridge? If the cartridge gives the same error-message in the other printer, it's time to responsibly recycle your "dead" cartridge, and give the brand-new cartridge to your friend, for his/her usage.
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Error on printer Connon ip 1000
Error code: 5600
Description: Cartridge displaced error
Symptom: blink in orange 9 times,beep 10 times
try removing and replacing the cartridge
please rate our help to keep the service online
Aug 24, 2009 | Epson Stylus Photo® R2400 InkJet Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Cartridge
we have a link on how to fix your own printer through this link(check for search box further down page)
Jan 28, 2008 | Lexmark X2470 All-In-One InkJet Printer
Samsung SCX-4500 Laser Printer Logo
76 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
