Question about NEAT Office Equipment & Supplies
Neat program won't open
First it was just the computer not recognizing the scanner had paper in it, so I reinstalled the software and now Neatdesk won't even open... It has the options on the top bar and everything, but none of my folders will come up. I click on it and nothing happens.
    Top Expert:
  • NEAT Master
  • 36,394 Answers
Refer this issue directly to NEAT for resolution.
Posted on Mar 24, 2014
  • 139 Answers
SOURCE: won't recognize scanner when installed
First, make sure your computer has been updated to at least Windows XP Service Pack 1....Service Pack 2 is even better. You can check this by right-clicking on my computer and selecting Properties from the menu. If you're using Service Pack 1 or earlier...it would be a good idea to run through the Windows Update process a few times.
Try downloading a new Scan Wizard file from this page on the MicroTek web site. When you do the install, it should remove any previous drivers and clean things up.
If this doesn't help, try to find the Windows Scanner and Camera Wizard...usually located under Start>All Programs>Accessories. It may work even if the MicroTek software doesn't.
Good luck...and I hope this is helpful!
Posted on Jan 14, 2008
  • 349 Answers
SOURCE: Computer does not recognize scanner
ensure that the scanner is compatible with the operating system you have installed on your pc,as some older scanners are not with XP & vista
good luck
Terry
Posted on Mar 06, 2008
  • 237 Answers
SOURCE: C7200 won't scan to computer even though option is there
Update the driver for this equipment: Go to this link:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&h_client=S-S-R295-1&h_pagetype=s-002&h_query=c7200&submit.x=1&submit.y=6
Posted on Feb 13, 2009
  • 10 Answers
SOURCE: ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
Posted on May 27, 2009
SOURCE: Vupoint FS-C1-VP scanner installed
i have vista home and mine worked fine until i installed a web cam and then it just gave up. But now it works great - here is what i did
unpluged both the scanner and the web cam
uninstalled everything to to w/ the scanner and the web cam.
Installed the driver from the CD and restarted my machine
Install the Photo 6 software
plug in the scanner - works like a champ.
have not reinstalled the web cam
Posted on Dec 29, 2009
Neat multi-page
The neatdesk software allows you to rotate the image as desired. Pay close attention to how you load the documents to determine the correct way to load.
Sep 05, 2014 | The Neat Company Neat NeatDesk Desktop...
NeatDesk scanner
paper feeds on printers and scanners can be seriously damaged by thick paper jams. Aside from actually taking the unit apart (which can be daunting) try sliding heavy card stock through the paper path. Don't force it. Sometimes cutting it into a narrow strip (3 or 4 ") helps it slide through.
Mar 05, 2014 | Neat Company NeatDesk Scanner
Blank scan with neat desktop scanner
Connect the scanner to a different computer.
If you get the same result, then the scanner is "dead".
It's moving the scanning-head, but not detecting (or not transmitting) any "non-base-line" information.
Either that, or you have changed the CONTRAST and/or BRIGHTNESS settings to "wash-out" the image -- like looking at a "cream" coloured piece of paper in bright sunlight -- it may look "white".
Feb 03, 2014 | The Neat Company NeatDesk Desktop Scanner...
I'm getting this message "The operation could not be completed. No other information is available about the problem." I had a paper jam..fixed it and now it won't scan anything without that er
1. Quit neat app.
2. Turn off scanner.
3. Unplug scanner from computer and outlet.
4. Wait a minute.
5. Plug scanner into outlet and computer.
6. Start Neat app.
Hope this helped.
Feb 21, 2013 | Neat Company NeatDesk Scanner for Mac
Manual for neatdesk scanner
Checkout the available downloads and video tutorials from the link below:
www.neat.com/support/video-tutorials-and-user-guides
Hope this helps.Thanks!
Jan 05, 2012 | RTO Neat Receipts 00315 NeatDesk Desktop...
Trying to install neatdesk and it come up saying,. config.nrcfg is denied what to do?
It sounds like you don't have sufficient access to install this software. I am assuming you are installing from a CD here so here is what I would do. I would Right click on my CD Drive and click Open and look for the Installer for the software you are trying to install. Right Click on the Installer (May be named Setup.exe, Neatdesk.exe) and select Run as Administrator and that should give you sufficient access to run the setup for your receipt scanner. I hope this has helped you some.
Ryan
Feb 23, 2011 | RTO Neat Receipts 00315 NeatDesk Desktop...
246 people viewed this question
Top NEAT Office Equipment & Supplies Experts
Steve F
Are you a NEAT Office Equipment and Supply Expert? Answer questions, earn points and help others
