Question about Pelonis WM-HO202C Oil Filled Radiator Heater
Radiator lights up but will not produce heat.
The radiator light comes on but will not produce any heat on any of the settings. Can you suggest what it might be causing this?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Burnt thermo fuse or element. be sure to connect any wires tightly if you replace thermo fuse. test it with a mulimeter should show less than 1 ohm.
Posted on Mar 24, 2014
My 1998 pontiac firebird service engine light came on and my OBD11 scanner produced 2 trouble codes PO125 ( insufficient coolant temperature for closed loop fuel control.the 3800V6 engine over heating and...
service the engine.. change oil ,filter plugs etc
did you clear the faults before each read
Diagnose Buick 3800 Engine
unusual code that
P0125 is the OBD-II generic code for the engine computer, or Engine Control Module (ECM), not detecting enough heat in the cooling system before the fuel management system can take control. The ECM has a predetermined value after you start your vehicle to expect a certain coolant temperature
P0125 OBD II Trouble Code Insufficient Coolant Temperature for Closed Loop...
ecm runs the engine cooling fans
3800V6 engine over heating and heater produces cold air
try these
EGR vale not working
overheating
inlet manifold gasket leaking
water pump fins corroded
soft radiator hoses
try a new radiator cap
internal heating
heater control tap stuck
directional actuator flaps stuck
Apr 16, 2017 | Cars & Trucks
2004 hyundai sonata over heating no leaks
You've looked in all the right places so far, and presuming the water pump is operating correctly (fan belt adjusted) and there is sufficient oil to lubricate motor, I'd suggest checking your ignition timing. If the timing is too far advanced i.e.firing too much before top dead centre-BTDC, then a motor is inclined to over-heat. Another cause of over heating is a lean fuel mixture. Examine spark plug electrodes - they should be brown to light tan colour. Light grey to white indicates lean burn and subsequent over-heat.
Take care around a hot engine.
Feb 24, 2012 | Hyundai Motor 2004 Sonata
Honeywell HZ-709 oil filled radiator heater-all controlls work but no heat produced. Possible reason?? Thanks
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
Dec 07, 2009 | Honeywell HZ-709 Oil Filled Radiator...
No heat when stopped
Take off the radiator cap when the engine is cool, if the radiator is low replace the cap and fill the rad up to the top.
Dec 10, 2008 | 2005 Chevrolet Monte Carlo
DASHBOARD RADIATOR INDICATOR LIGHT COMES ON WHEN ENGINE IS COLD
you might need to get the water level sensor checked, it may be faulty
Nov 28, 2008 | 1999 BMW 318 ti
Engine heating up after turning off
Do the fans on the radiator run when it heats up?
Aug 23, 2008 | 2000 Jeep Grand Cherokee
1997 toyota 4-runner, My battery dash light is on. The battery is good.
The battery light on at the dash indicates a problem internal in the alternator. Normally, when the alternator is producing sufficient voltage (14.4 VDC), the light stays off. When the alternator is NOT producing sufficient voltage, the light comes on. Check the voltage at the battery with a voltmenter with the engine running. If you have less than 12 volts, you both need an alternator.
Aug 09, 2008 | 1996 Toyota 4Runner
Pelonis WM-HO202C Oil Filled Radiator Heater Logo
384 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
