Question about Clarion NX602 In-Dash Car GPS Navigation
Sometimes my clarion stereo won't turn on and it needs a couple of tries to hit the power button on
The stereo is brand new and I just had it installed a couple days ago. The stereo turns on but it comes and goes at intervals. Intermittent powering on.
    Champion:
  • 205 Answers
You need to contact clarion and tell them the problem sounds like you have a defective stereo and they should replace it under warranty
Posted on Mar 24, 2014
KaeZoo
  • 156 Answers
SOURCE: clarion dxz545mp doesn't power, does not work.
Check the fuses in the fuse block under the hood. Your clock fuse and radio constant power fuse are combined in this vehicle.
Posted on Jun 11, 2007
  • 78 Answers
SOURCE: clarion db538rmp
this proble is usually caused by the tel mute cable getting trapped as you push the radio in to the dash, pull the radio out of the dash and see if you can see if any cables have gotten caught in the cage
Posted on Nov 26, 2007
starlet4life
  • 89 Answers
SOURCE: clarion radio wiring diagram
Usually the yellow is for ignition switched-red is permanent +...;)
Posted on Sep 27, 2008
  • 34 Answers
SOURCE: Wiring on a Clarion
power wire is red,mem wire is yellow, dimmer will be orange or orange w/ white line in it, and the amp wire will be the one that shows 12volt power only in the on posision (blue) if it has two the other is for power ant.
Posted on Jan 12, 2009
  • 3 Answers
SOURCE: Clarion M5675 won't turn on
Take the stereo all the way out and hook the black wire to the negative terminal and the yellow and the red wire to the positive terminal on a charged car battey. If it still does not turn on you may have fuse in the back of the deck. If not it's probably fried.
Posted on Apr 19, 2009
Instructions bluetooth sync
I'm not sure if this is your problem or not, but I've read of others having problems with pairing various Clarion car stereos to their iPhones because they ultimately failed to complete the connection via the car stereo's Menu feature. I've heard of this for the Clarion FB288RBT and for the Clarion CZ302A, for instance. Since I don't know your model number, I can only give you general info, but it might work!
The key problem seems to be that people don't know that they need to enter the car stereo's Bluetooth menu, NOT just the iPhone's Bluetooth page.
So, first set up your connection on the iPhone:
Settings > Bluetooth > On
Look for your device. Select it in the list that opens up.
Select your car stereo model number.
If you need a password, try the default password of "0000."
You should be able to tell if you got a successful pairing at this point, but you still won't be able to place a call until you enter the Menu feature on your car stereo unit.
On your stereo, to make a call, enter the Bluetooth menu:
Press the SRC button (far left hand side, perhaps?) to switch the car stereo's source to BLUETOOTH. (The SRC button is a power button, but it also toggles the audio source!)
Press the Menu button to select a way to make an outgoing call.
After pressing the Menu button, I THINK you'll be able to see various options by rotating the Volume knob at this point. To confirm any selections, you can probably press the Volume knob.
Whereas the Volume knob will rotate and press to view and confirm selections, I'm guessing (because I don't know your specific unit) that you would then use the Band button to dial your selected number, to transfer a call between Handsfree and mobile, to answer a call, or to redial a number (use a long press for this last one -- 1 second).
And then the Menu button is used to end a call or to reject an incoming call.
I hope this helps. Without knowing your model number, it's hard to be specific.
Aug 04, 2014 | Apple iPhone Smartphone
Machine turns on but won't start
this means that the door is not shut check to make sure the door button is still there its behind the door on the frame you should see a little black button sticking out if its not there you need a new door switch if its there try pushing the door button a couple times really fast sometimes this button gets stuck if that doesnt work its probably your door lock
Aug 27, 2012 | Kenmore 44102 Front Load Washer
I got a clarion vz409 car stereo an it locked completely
I just had the EXACT same problem, and 5 hours searching on the web got me nowhere. I set the lockout code, but it will not unlock, and now its locked up. then I called clarion. Turn the deck on with the screen out, then hold the power and play button to bring back up the password screen. Default is 0000 but if that does not work, enter 4356 and it will Unlock!
Aug 19, 2010 | Car Audio & Video
My new Clarion CMD6 stereo won't stay powered up.
If all power and ground are good to go then the unit needs to be fixed. Being that it is more likely to "see" moisture, it may have water shorting out the circuits.
Jul 03, 2009 | Car Audio & Video
Apr 19, 2009 | Clarion M5675-RET CD Player
How can I get the code for the radio of a volovo 850?
The first step is to try and remove the radio to see if the code has been written on the casing. This is sometimes done with Volvo.
You will also need to provide the model number printed on the front of your stereo as Volvo branded units are often Clarion or another major brand that has been re-branded Volvo.
Regards
Marc
Apr 17, 2009 | 1996 Volvo 850
The face on my clarion arx7570z does not light up.
I have a brand new faceplate for the ARX7570z. You are welcome to have it. I have no use for it. Mail me at waltertnet@netscape.net.
Feb 03, 2009 | Clarion ARX7570z
Is this considered clipping in marine boat stereo help!!!!
if your radio is puiing more power your ground might not be good enough, use the same spot but remove the ground and rough it up a little on the base with some sand paper or add a metal o ring to get a better ground.
Jul 30, 2007 | iLO XM-MP3-CD Car Stereo
Clarion NX602 In-Dash Car GPS Navigation Logo
122 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
