I use v69, 100/18 needle, bobbin hook clean no burrs, threaded correctly, upper/lower tension fine but upper thread loops in the bottom. Increased tension and thread breaks. When I use standard tex27 thread, I have no problems. Need Help..
Thread sounds too heavy for this machine, or at least these needles. Thread should occupy about 40% of the side to side width of the needle's eye. See: http://www.gwsms.com/didyouknow.htm
Posted on May 22, 2014
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
SOURCE: bottom thread is looping.
If the thread is looping on the bottom, then your problem is on the top. Pull the thread out of the needle and and put the presser foot down. If the thread pulls thru easily, then you need to rethread your machine making sure the thread is thru the top tension wheel correctly.
Rule of thumb::
Loops on the bottom, Problem on the top
Loops on the top, problem on the bottom.
Posted on Apr 26, 2009
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Posted on Jul 27, 2009
SOURCE: tension problem on Brother ES 2000
I have a Brother CE 4000 Computer sewing machine. I had the same problem when I first used it. I worked with it several hours but to no avail so I decided to stop and wait until my head clear..
I went back a couple of days later. Reread the manual and started over. I discovered my problem was that I was threading the bobbin wrong. Once I threaded it precisely as the manual stated it worked fine.
So this might be your problem. Make sure that the thread on the bobbin is wind on properly. It should be wound evenly. The bobbin must be threaded precisely as the manual says.
Try rethreading the bobbin and the machine
and see if that help.
Posted on Jul 30, 2009
Sep 05, 2016 | Kenmore Sewing Machines
Dec 10, 2007 | Singer 8280 Mechanical Sewing Machine
Apr 25, 2016 | Sewing Machines
Apr 23, 2016 | Sewing Machines
May 30, 2015 | Sewing Machines
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Mar 14, 2011 | Brother SE-270D Computerized Sewing...
May 27, 2010 | Janome 6260QC Computerized Sewing Machine
Feb 10, 2009 | Kenmore 15516 Mechanical Sewing Machine
Dec 31, 2007 | Consew 206RB
Aug 20, 2016 | Brother CS-6000
Jun 12, 2014 | Brother CS-6000
Jun 11, 2017 | Brother CS-6000
Apr 13, 2014 | Brother CS-6000
37 people viewed this question
It's a Tacsew T622R and I also use new needles... Thanks
