Question about T-Mobile Dash Smartphone
Cannot pick up the phone!
Every time the phone ring i cannot pick it up, when i try calling the calling screen doesn't show up. it only show call status at the bottom-right of the screen. But it ring! so can you help me please!!!
  • 425 Answers
Re: Cannot pick up the phone!
Probably the answer botton of your phone doesnt work anymore...
first reason is the contacts get dirty inside or get corroded due to perspiration or it get wet... another reason is it loss its connections...
if you can open your fone try cleaning the keypad mat or have it repair by technicians if you cant open it...
Posted on Oct 31, 2007
0 characters
3 Points
Blackberry has blank screen but rings when someone
Try this, it solves the problem for Blackberry Bolds:
Aug 08, 2009 | RIM BlackBerry Pearl 8100
HTC touch phone crazy problem
Scan your mobile for Viruses. and check the setup for the line access
Mar 21, 2008 | HTC Touch P3450 Smartphone
Phone doesn't ring for an incoming call
pls reset ur device for some reason the call handling software has been corrupted dont worry just backup ur data and reset the device as follows
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to for latest Rom update download and update backup ur data first
pls rate me fixya if i solved ur problem
Feb 28, 2009 | HTC P4350 Smartphone
Blackberry Pearl 8100- Contact picture/name does not show when certain contacts call.
You might try performing a backup in the Desktop Manager, then performing a device wipe. You can wipe the device by going to Options > Security Options > General Settings. Press the menu key, then select Wipe Handheld.
After the device is wiped, then use the BlackBerry Desktop Manager to restore the data back to the BlackBerry. Then test it out and have someone contact you.
Oct 01, 2008 | RIM BlackBerry Pearl 8100
try installing this Hotfix
Hot fix for resolving ring tone and system sound loss problem in HTC Touch Date: 2008-08-28     CategoryHotfix
In some cases, there may not be any ring tone and system sounds on the HTC Touch when the device has not been soft reset after a few weeks of usage. Performing a soft reset will resolve this problem. You can also download this hot fix and install it on your device to prevent this problem from reoccurring.
May 26, 2008 | HTC Touch P3450 Smartphone
My IPAQ hw6515d has no sound.
When I call out i can't be heard by the person am calling. or when i playback music there is no sound. but when i recieve a call It it rings, then nothing can be heard when i pick up the call. please help.
May 21, 2008 | HP iPAQ hw6515 Pocket PC
Remember the Motorola Q is more of a computer than a phone. Think of it like Windows Vista :(. I use the Q and love it. But I have run into this problem several times. There are a few things to try before taking your phone back. First, remove the battery and then put it back in. Second, replace the battery (power is everything). Third, try using Task Manager to kill any programs that you are no longer using. Do this on a regular basis. Fourth, refer to the manual for proper battery care. Fifth, try selecting the "Home Service/Wireless Manager" button on your home screen. Then choose phone to turn the service on. Then choose phone to turn the service back on. Resetting the service in this way is often helpful. Good luck.
Mar 03, 2008 | Motorola Mobility Moto Q
Phone often misses calls
*228 updates your phone, give it a try
Jan 07, 2008 | Motorola Mobility Q9m Smartphone
Ring time too short
try resetting your phone to its factory settings...
Dec 19, 2007 | Samsung SGH-U600
T-Mobile Dash Smartphone Logo
65 people viewed this question
Top T-Mobile PDAs Experts
Martin Murray
Are you a T-Mobile PDA Expert? Answer questions, earn points and help others
