Question about Jenn-Air 30 in. CCG2423 Gas Cooktop
3 of 4 knobs do not compress to turn on gas
While I was cooking dried beans in water, the liquid boiled over and snuffed the flame. The water seeped under the stove top and the clicking sound of the ingnition sparks started. So, I unplugged the stove top to quiet the noise. I sopped up the liquid and replugged the stove and the clicking noise is gone. Now, 3 of the 4 knobs are impossible to turn on. I removed the knobs and noticed the stem does not compress thus, no gas can come through. Please help.
  • 999 Answers
You must replace those controls. Cleaning or loosening them up would be temporary at best and the next time they stick it could be in the open position. Safety first...Eric
Posted on Jun 14, 2009
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
My cook top is beeping nonstop ! i overboiled some whater and it fell on the cooktop. now it is beeping all the time ! what should i do?
You need to contact your dealer. Tell them to fix it or replace it. Boil over water should not affect an induction stove top.
Jan 09, 2012 | De Dietrich Cooktops
Hi, We have a GE profile cooktop (JGP975SEK1SS ). Last night, the boiling water spilled on the bottom right burner, so I turned off the stove. But since then every time we turn on the stove, the two...
Hi shadnaz,
A common issue with water causing the problem. I'd suggest following my below Tip on fixing the problem:
GAS COOKTOP CLICKING PROBLEM...
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it
Aug 08, 2011 | Cooktops
Water boiled over on the Right rear induction side. Stove shut off. Now the Right rear burner doesn't work and flashes and "F" when I set any temperature. Stove thinks I have the wrong type of...
Generally there is a number after the F. It sounds like some liquid got into the electrical, sometimes if you wait about a week for it to dry it will work. If not, you would need to call a service tech
always unplug electricity before attempting to repair on any electrical appliance
Sep 14, 2017 | Electrolux 30" Built-In Electric Cooktop -...
Igniter will not turn off. Makes a clicking sound
Hi, normally what causes the igniter to keep clicking is spilling water or something down into the knob area. The water is causing a short circuit in the switch which is mounted on each burner valve shaft. If unplugging the range for several days to allow drying doesn't fix the problem, then one of the switches will need to be replaced.
Jan 27, 2010 | Magic Chef Cooktops
1 burner flares and sputters
Hello. Chances are that something on the stove boiled over or got poured into that burner. take it off, soak it overnight in water with dishsoap added, then rinse it and let it dry before reinstalling it. Repeat the soaking in soapy water if necessary until the flaring, sputtering and black soot is gone. regards, Joe
Dec 14, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Pot overflowed and then flames from R side and clicking
yes this is commen when you spill liquid on the spark module what happens is it grounds itself out and will continue to spark until it drys out. you should be fine.
Jun 20, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Flame on gas hob not correct.
I'm not sure what you mean by a proper efficient flame. I just recently went through an experience I'll relate to you here. I purchased a GE Profile dual fuel range. I can get more specific if you'd like but here's the point. The highest burner on the range was rated at 17000 BTU's. A friend recommended the range to me and sang it's praises. I took delivery of my new toy and couldn't wait to get a pot on the stove to start cooking a long wait for pasta. Twenty minutes later I was finally seeing bubbles! I spilled the water out and measured 12 cups of water into the pasta pot at room temperature. That's three quarts of water. 20 minutes to see bubbles and never would it come to the expected "rolling boil". My experience has always been with electric ranges and I am new to gas but 20 minutes? Something had to be wrong, right? Wrong! Much research later I've found it is common for natural gas to LP conversion stoves to lose a good deal of their oumph when converted. GE as it turns out is one of the most notorious for a serious degredation in BTU output. After exploring GE's site I found that this same stove running under LP gas is rated(for the highest burner) at 11000 BTU's! No wonder I couldn't boil water! Back to the store it went and I am still in search of a stove that will meet my needs. Don't know if this will help you or if this is the same issue you are dealing with but maybe just maybe. Good luck!
Apr 29, 2008 | Cooktops
Brown Cook Top (24 Inch - TTL03-3 Model)
All gas appliance should be diagnosed by a professional.
Aug 12, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
Igniter will not turn off once burners are lit.
I've had the same problem for 2 years. Today I removed the four burner tops, the 15/16 inch bolt that holds the burners in place, took everything apart (simple connections underneath), completely cleaned and dried eveything. I also cleaned the 4 knobs and making sure the 4 swiches slide up and down freely then dried everything with a hairdryer. Is now works fine but if the problem comes back, I'll simply unplug the cooktop and light it manually. P.S. I stripped one of the large 5/16 inch bolt that had become weak and brittle. - Try using water or some liquid to loosen the bolts as necessary. Good luck, CHEERS!
Oct 13, 2007 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Jenn-Air 30 in. CCG2423 Gas Cooktop Logo
245 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
