I have a Rowe R80 jukebox and after moving it it has no sound through the speakers I am in New Zealand
The needle fell of and I put it back on and put back records that fell out. everything works as it should but the sound only comes out faintly in the left top speaker. sometimes there is a hum in right top speaker. I am in New Zealand and cannot find anyone to look at it. all help appreciated.
  • switchie_nz Mar 24, 2014
    This is a jukebox not a cd player dont know why it went into cd players. sorry
    Filmmaker:
    Uploaded 5 video answers.
  • 26 Answers
Well, in addition to all the fine suggestions that are here, I would like to add the simple and easy things that may have happened during the move.
IF YOU ARE NOT GETTING A LOUD POP WHEN THE MACHINE IS POWERED ON.......
1) Make sure that the wires on the terminals below are still connected to the screws. There is one ground and one each for left and right. The lower the tap the lower the (max) volume of the jukebox.If they are not connected there will be no sound.
I have a Rowe R80 jukebox and after moving it it h - 84c9065c-b7c6-4417-be21-0be7a6e74b41.jpg
There is a jumpers on the terminal strip where the volume control connects. Make sure that these connections are correct and tight. Also make sure that the jumpers did not fall off.
If you are getting the loud pop in the speakers when the power is turned on .....
Check the plug on the side of the mechanism, just below the back of the tone are.(looks like a little tube socket) Check to see that it is connected to the mech and the CORRECT PLACE on theI have a Rowe R80 jukebox and after moving it it h - bf77613e-82a3-4e37-b8fe-cc80f4d4dbcb.jpghis end in the wrong place. bf77613e-82a3-4e37-b8fe-cc80f4d4dbcb.jpg
Check all all your connections against the pic.
I hope this was helpful.
Posted on Jun 25, 2014
  • 25 Answers
Is there a loud pop when you plug in the box, if so the amp is probably fine. Since this happened when moving the box there are a couple of possibilities. 1. Wires pulled off the cartridge. 2. Bad connection from amp to tone arm, usually at the plug on the left side of the mechanism. Try the plug first then look for wires off the cartridge. There should be three wires going to the cartridge 2 signal line and one ground that is common to both sides. The grounds go to the posts marked lg and rg. The right and left do not really have to be on the right posts although it will change which speakers each channel drives. Originally there were connectors that slide onto the cartridge posts. If they are still there you should try to reuse them, if not you will have to solder directly to the cartridge. THIS IS DELICATE WORK! Anyway one of these should fix your problem. Good luck.
Posted on Apr 23, 2014
4 Suggested Answers
SOURCE: rowe r92 sound problem
Moving the wire indicates the speakers are OK. Try reversing the 3 pin plug from the cartridge. If the problem stays on the same channel, it is probably a preamp board issue. If the problem switches channels, you have a bad wire to the cartridge or a bad cartridge.
Posted on Dec 06, 2011
barnes07
  • 16 Answers
SOURCE: NSM Digital Thunder CD Jukebox speakers on right side do not have sound
make sure speaker wires are all pluged in. if that dont wort check the speaker wire it my be broke in between speaker and player, try new wire
Posted on Jul 16, 2012
  • 77 Answers
SOURCE: rowe ami r80 jukebox is exepting selections but keeps reapeating
I don't have a manual handy but it could be a few things, you may need to reinitialize the jukebox, maybe there is a dirty wiper or the control module may be on its way out. I would try to locate a repair manual for it, there might be an old vending company in your area with one.
Posted on Nov 28, 2012
Selections already made on jukebox, how do I clear them
Hello stillwell42,
What model is your Rowe Ami jukebox, there will be an information label on the back or inside the jukebox with the serial number and the model type. We can suggest a solution once we know your model type.
Regards
Alan
Alan Hood
ami-man
UK
Mar 13, 2015 | Audio Players & Recorders
How do you put a rowe cd 51 jukebox on free play
all rwe cd jukeboxes 1 put in service mode
2 push in 84 3 type in 9999 4 press popular
5 put back into play mode
Jan 18, 2013 | Audio Players & Recorders
Rowe ami r80 jukebox is exepting selections but keeps reapeating
Nov 27, 2012 | Audio Players & Recorders
Rowe r92 sound problem
Nov 16, 2011 | Audio Players & Recorders
Record tracking problem
There is a switch, or lever to a switch, that detects the end of the arm travel. For some reason, it is being tripped early. Try to open it up, and see what you can see. It doesn't sound like a broken part, but a dislodged part, maybe. That's all I remember, only had this problem once, years ago.
Mar 14, 2010 | Audio Players & Recorders
I have a 1979 rowe ami jukebox model R65 when i switch it on it plays one record then just spins the record magazine and wont select another record what parts do i need .
Hello Gary,
If your jukebox is ineed a 1979 model it would be a R-83 Fiesta, Claremont or Disco. These jukeboxes curved top to bottom.
I think your jukebox may be the 1981 R-85 Starwood, Starburst or Starlight.
If your jukebox is from the 1979 era upwards then it will be electronically controlled.
You need to send in your boards to a Rowe Ami specialist in the USA you would contact :-
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com
In the UK contact me
Alan Hood
ami-man
Games Unlimited & Datex Systems
Units 4 & 5 Lion Park
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
alan-hood@datex.co.uk
Mar 01, 2010 | Vintage Jukebox External Speakers Shelf...
Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
Oct 23, 2009 | Wurlitzer Jukebox 1015 One More Time...
I have rowe ami jukebox Eagle Laser Star and its amp seems to be dead sin have no sound justa a buzz. Need to find one or how to repair it.
CALL AB JUKEBOX SERVICE--ASK FOR BRUCE--TELL HIM LES FROM RMC VENDING SUGGESTED YOU CALL HIM.-
603-382-6272
Apr 27, 2009 | Wurlitzer Jukebox CD Player
My cd rowe ami jukebox is stuck in scan/transfer mode
You say you do not have the digital display lite up, have you checked all of the breakers on the power supply?
If not do so. Rowe Ami jukeboxes are very prone to dry joints (cold joints in the USA) this is cracking around the soldered pin on the connections to the boards.
If you can solder correctly then check out the printed circuit board on the power supply. I would retest and see if the display now lights after correcting a fault on the power supply.
If that has not made any difference then proceed to the Mechanism Control Board and the Central Control Computer (CCC) and check again for dry joints.
If you can not solder with any confidence then send in your boards to a Rowe Ami specialist for testing/repair.
Regards
Alan Hood
ami-man
UK
Mar 10, 2009 | Wurlitzer Jukebox CD Player
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
907 people viewed this question
 Grubhead
Grubhead
