Question about Standard Horizon Matrix Ais Gx2150 Vhf Radio/ais Receiver And Gx2000 Radio, White
I want to know thw correct wire connections to connect my Matrix GX2150 AIS VHF to a Garmin 421s Chartplotter
What are the correct wire color to color connections required to connect to a Garmin 421s Chart plotter. The Garmin has 2 ports available for connection.
2 Suggested Answers
  • 4090 Answers
SOURCE: standard horizon 155c not acquiring signal
If the signal is good statement seems to imply that it is working, perhaps this is my misinterpretation of what you mean by this.
Signal refers to the abi;ity to connect to satellites
4 are requied for triangulation.
If the unit is fully charged and not connecting , then it is quite possible that the unit has a damaged SIIRF chip or whatever chip was used in your model to acquire satellite connection. The cost of repair is costly, it means total replacement of the M/Board.
Never start car with the unit connected into DC car power, spikes will damage the chip
Posted on Jun 30, 2009
My Garmin 421s works perfect but sonar goes off with notification that the tranducer is off. A tap on the case would partly restore service. What is the cause of this failure?
Short in system. if in warranty send to manufacturer. If not open the case and see if any components and wiring are damaged or wire came lose from mother board.
Jun 11, 2016 | Garmin Gpsmap 421s Chartplotter with Dual...
My Garmin 421s will not power up any answers
Sounds like you need to contact Garmin.
They are great folks and very helpful.
http://www.garmin.com/us/support/
Here's a link to follow. You will see contact phone #'so on rhetoric right hand side of the 0age.
Oct 15, 2014 | Garmin GPSMAP 421/421s GPS Chartplotter...
Need to reconnect a c-80 system. I think the MFD, radar, GPS, and depthsounder are connected via Seatalk
I think your best bet here would be to post your query on the Raymarine forum.
There are actual technicians over there to look after you.
http://forum.raymarine.com/
Hope this helps you out.
Aug 01, 2017 | Raymarine C80 GPS Receiver
Where do I find a 6 pin serial to usb adapter for the Garmin 421s? I can't find one anywhere on line. Does Garmin sell one? It's Saturday and Garmin's help center is closed. Their on line...
The 6 pin DIN plug found on the GPSMAP 421s data/power cable (Garmin part number 010-10918-00) is used for the sonar input.
Data transfer from the GPSMAP 421s is easily transferred by memory card.
Information about data transfer on the 421s is at about 50 seconds into this video.
http://www.youtube.com/gpscity#p/search/6/8ddIgvCAUmI
Real time NMEA data can be transferred using Garmin part number 010-10918-00 wired to a DB-9 serial connector (Instructions are on the cable).
It then can be adapted to USB using a serial to USB adapter.
http://www.gpscity.com/gilsson-serial-to-usb-port-4in-adapter-for-pc-and-mac.html
Sep 17, 2011 | Garmin 421S GPS Receiver
Can it take ais?
A Standard-Horizon CP180 Chartplotter can recieve information from an external AIS device with a NMEA data wire connection. The cable from the NMEA output of the AIS would be connected to "Port 1" (Page 18 of the CP180 user manual) on the CP180 and then the CP180 menu settings configured to show AIS targets, data, etc. (Page 21 on the CP180 user manual)
Nov 19, 2010 | Standard Horizon Cp180 Chartplotter
Connecting Garmin GPS 152 to VHF Radio Silva S15
Hi!
From the S15 owners manual (Page 46):
http://www.bluemoment.com/manuals/silva_s15.pdf
The RED wire is GPS data,
The green wire is GPS ground.
Hope this helps and good luck!
May 08, 2010 | GPS
Integrating AIS, Radar, Autohelm 7000 and flux gate compass.
ActiSense makes a programmable multiplexer that should do this for you. It is called an ActiSense NDC4 USB. Not sure is the Standard requires a separate compass signal, but if not, and the Standard can use a standard 38000 baud AIS data stream, the NDC4 will work for you. 847-746-0100
http://www.blueheronmarine.com/Actisense-NDC-4-USB-NMEA-0183-Multiplexer-with-USB-Port-6334
Jan 30, 2010 | Standard Horizon Cpv550 Gps Chartplotter...
I have a SI-TEX black box receiver and I'd like to connect it to a Garmin GPS chartplotter. The SI-TEX black box receiver instructions at one point say:"If the GPS has a NMEA output (or NMEA REF) connect...
Yes, the NMEA- output (I think you lefy uot the "-" in your questoin), anyway, the NMEA - or NMEA negative or NMEA ref is hooked to battery supply ground.
Dont forget to program the Garmin to look for 48,000 baud data.
Jan 10, 2010 | Boating
Chartplotter (Garmin 450s) won't talk to VHF DSC radio (Icom IC M
As advised, reset to factory settings. Then re-entered custom settings as required. Seems OK now. Many thanks.
David Godfrey
Jun 16, 2009 | Garmin GPS
I have a Simrad CP32 mk2 chartplotter ,when VHF radio is switched to channel 10 no communication is possible due to heavy interference. Even a hand held radio independent of all electrical connections has...
I have a Garmin 182C and I get interfernce on VHF channels 21,22 and 83 the moment I turn on the Garmin. I have tried changing radios, antennas, placed separate poer and aground lines and nothing helps. Garmin gives me the run around.
Feb 23, 2009 | Boating
Standard Horizon Matrix Ais Gx2150 Vhf Radio/ais Receiver And Gx2000 Radio, White Logo
50 people viewed this question
Top Standard Horizon Radio Communications Experts
eradiostore
eradiostore
Norm Pearl
Are you a Standard Horizon Radio Communication Expert? Answer questions, earn points and help others
