Samsung ML-2150 Laser Printer Logo
A
Anonymous Posted on Mar 24, 2014
Toner low symbol coming, tell me how to reset
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Samsung Master 1,449 Answers
  • Posted on May 05, 2014
Samsung Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614276
Points
3628
If you have toner chip , please change toner chip, than you can see new life toner cartridge
Toner reset for konica pagepro 1500w
some cartridge have electronic chips on them if the chip says empty then the copier say ok replace the toner will not tell the chip it is new
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
Brother 9460 reset toner
Like most laser printers, the toner light comes on early. This gives you time to order new toner. I find it best, since it does not stop the printer from printing, just to have a toner on hand and when your toner is empty replace it. Since this is a mesurement inside the toner cartridge its self, there is no way to reset the warning (other than replace the cartridge).
1helpful
2answers
My konica minolta 2300dl tells me my drum is low. do I need toner? Where do I go to get toner?
If it tells you the DRUM is low it has nothing to do with toner, it probably meens you need to replace the DRUM unit (aluminium blue/green cylinder in the device) dont forget to reset the timer after replacement
3helpful
When i turn on my printer theres a message appear toner low
in your cartage have green cheap or fuse these are reseter. the are aviable in market .change it . then your printer can work. when are u getting tonner low. recently u shuld fill cartage. i think you get empty message. just reseting cartage by new reseter than u can change old reseter. u can 100% solve your problem thanks
6helpful
Light on. Exclamation mark within a triangle. Printing fine and clear. What does tis symbol mean?
This light is indeed designed to indicate a low toner condition. Its coming on is triggered not by the actual level of toner in the cartridge, but by a software process that estimates toner use. If you are inclined to refill your own cartridges, you can use install a glass fuse in the little clip on the back of the toner cartridge that will reset the counter, and turn out the light, otherwise the light will stay on. The reset process will blow the fuse, so a new fuse is needed each time a cartridge is refilled. Leaving the light lit does not hinder the operation of the printer, so as long as there is still sufficient toner to print, the printer will operate normally.
1helpful
Installing Epson TO88120 on Epson NX1000
On the LCD display choose the 'Reset Menu'Then within that menu keep going through the (many) options 'till you get to 'Change Toner K' (K for black, C for Cyan, M for magenta,Y for yellow).
Once you select the appropriate Toner it will rotate to offer the toner for replacing.
Open up the cover at the front, reach inside and change the position of the coloured part of the toner cartridge on the R/H side to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out slightly ahead of the other side.
Put the new toner cartridge in and turn the coloured part to the locked symbol and close up.
Please take a moment to rate this solution, thanks.
2answers
Hp laser 4500 says toner is low or out even after new cartridge
There is a toner sensor in this printer that shoots a beam of light through the toner cartridge. As long as the toner is full and blocks the light, it sees it as being full. If it were the sensor, it would tell you this for all the toners, though. The printer also calculates how much toner may have been used and gives warnings based on that. It could be that this isn't getting reset after you change toner. You can reset the toner gage by going into the reset menu and selecting "New xxxx cartridge" and changing it to YES.
Not printing..
The symbol on top that looks like a beaker full of marbles is the symbol for the toner cartridge (notice the same symbol is found on the button that opens the toner cartridge door). If this light is on, either the toner cartridge is getting low, or the cartridge needs replaced.
We re-filled the toner cartridge and re-installed it, but the red light indicating toner low keeps blinking, also the computor is telling us toner is low
Just refilling the cartridge may not resolve the low toner message. Many cartridges have a sensor chip that must be reset to clear the message. Due to this, many people opt to buy replacements or refurbished cartridges that have had the sensor chip reset.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
