Question about Craftsman Garden
917 273482 transmission will not disengage in back and will not go forward or backward when pedals are engaged.
    Genius:
  • 1,114 Answers
http://data.manualslib.com/pdf2/50/4969/496802-craftsman/917273482_owners_manual.pdf?c811e9c4ec42dd53423907ae41cf566c
First make sure the drive belt is intact(not broken) and routed as it should be. Check the idler pulley which places tension on the belt. Hopufully the link will work. Pages 24-25 show the drive belt placement and associated pulleys
Posted on Mar 24, 2014
RonInFla
  • 86 Answers
SOURCE: mower stopped dead. blades go, tractor starts and
broken drive belt
Posted on Apr 28, 2010
  • 33 Answers
SOURCE: husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
Posted on May 02, 2009
saailer
  • 1868 Answers
SOURCE: I have a Husqvarna YTH
Hello! There are two known faults with the Husqvarna YTH...# 1 is the drive belt slipping...The belts have a manufacturing defect, in that they are out of specification in length...After some usage slipping occurs...#2 is a brake recall which is described below...It refers to the 19.5 HP 42" cut but the 46" cut utilizes the same braking mechanism...Guru...saailer
Brake Recall.
http://www.usrecallnews.com/2009/07/cpsc-6146.html
Husqvarna Lawn Tractor Recall: Parking Brake Failure
July 9, 2009
NAME OF PRODUCT: CRAFTSMAN LAWN TRACTORS
UNITS: ABOUT 8,200
MANUFACTURER: HUSQVARNA CONSUMER OUTDOOR PRODUCTS N.A. INC., OF AUGUSTA, GA.
HAZARD: The tractor's parking brake may fail, which could result in a loss of control.
INCIDENTS/INJURIES: No incidents or injuries have been reported.
DESCRIPTION: The recalled Craftsman Power Lawn Tractor is gray, has a 19.5 horsepower engine, automatic drive and a 42 inch cutting deck. The model and serial numbers can be found on a plate under the tractor's seat. The following model and serial numbers are included in this Husqvarna lawn tractor recall.
MODELS CRAFTSMAN 917.289080, CRAFTSMAN 917.289081, Serial numbers, 012709A001000 THROUGH 031209D999999
SOLD BY: SEARS AND KMART STORES NATIONWIDE AND ON THE WEB AT WWW.SEARS.COM (http://WWW.SEARS.COM) FROM JANUARY 2009 THROUGH APRIL 2009 FOR ABOUT $1,200.
MANUFACTURED IN: UNITED STATES
REMEDY: CONSUMERS SHOULD STOP USING THE RECALLED TRACTORS IMMEDIATELY AND CONTACT SEARS FOR A FREE INSPECTION AT YOUR HOME AND, IF NECESSARY, A FREE REPAIR OF THE PARKING BRAKE CABLE. SEARS IS DIRECTLY CONTACTING CONSUMERS WHO PURCHASED THIS PRODUCT.
CONSUMER CONTACT: FOR ADDITIONAL INFORMATION, CONTACT SEARS AT (800) 978-7615 BETWEEN 9 A.M. AND 10 P.M. ET MONDAY THROUGH FRIDAY, OR VISIT SEAR'S WEB SITE AT WWW.SEARS.COM (http://WWW.SEARS.COM)
Posted on Dec 18, 2010
  • 3911 Answers
SOURCE: Mower will shift into forward and reverse gears
either your drive belt has failed or your transmission has failed. make sure the drive belt is snug and not broken, do not do this while the engine is running. if the belt is good, then it is new transmission time. they cost more than a good used replacement mower.
Posted on May 08, 2011
  • 2239 Answers
SOURCE: engine runs but stalls when engaged
This sounds like a micro switch, or relay issue, it is not stalling it is being switched off, if there are some relays on the back of the bulk head replace them, they are just a push fit.
Posted on Feb 27, 2012
Why isn't something engaging when accelerator pressed?
It would help to know more information about the mower in question. Walk behind push mower? walk behind self-propelled mower/ Riding lawn mower? Lawn tractor? Or goat...just kidding...lol. The engine horse -power or cc's and make of the mower and engine. Anything happen before the problem or was it straight out of storage. Does the gas pedal feel normal? Could you be talking about the forward/ reverse pedal? These types don't engage by depressing them, they engage by releasing the pedal.
I'm going to guess you have a riding lawn mower or lawn tractor. The pedal for those types of mowers controls the transaxle ( rear wheels, transmission and differential basically). If the pedal move properly and it was working ok when it was stored, then check to see if you can push it with little effort. On most transaxles there is a disconnect rod to disengage the transaxle for towing the mower without damaging it. Pulled out for disengaged and in for engage. If that all checks out it could be very low on transmission fluid or the drive belt might be off or broken depending on which type you have. If it is low on fluid, you have a leak. Hope this helps.
Mar 11, 2016 | Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
Transmission not move forward backward
Probably. There may be a solenoid not working which is keeping the transmission from engaging the forward gear train but for it not to work at all is unusual.
May 12, 2013 | Plymouth Grand Voyager Cars & Trucks
HOW DO YOU DISENGAGE 4WD 1997 PATHFINDER
Hi Diamond, These vehicles do sometimes have a problem in disengaging the 4 X 4. Start up and drive it backwards and forwards slowly (3 or 4 miles per hour will do). Gently put pressure on the lever in the direction of the 2 high and after some time it will change. (If nothing has been damaged inside the box, which is unlikely) Regards John
Aug 11, 2012 | 1997 Nissan Pathfinder
Can anyone help? My Cub Cadet LT1045 won't move (foward/backward).
Hi, check that the drive belt, pulleys and shafts are all ok and that they are actually driving the transmission, hopefully you will see the problem. If the transmission is driving ok and the fwd and reverse lever is functioning as you said, the transmission may have failed. Also check the hydro release lever is functioning. Regards Phil.
Jun 25, 2012 | Cub Cadet Garden
Bike chain skipping
Bike chains are slightly different determined by amount of cogs on rear sprocket. If you havent changed the chain, adjust the tension of chain.If tension is ok-sprocket would be damaged(teeth worn,slightly rounded)but if same prob on different gear, chain tension/incorrect size chain is problem.
Hope this has been helpful..
Jan 14, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Cadet LT 2042 worked fine changed hydro filter by lifting front with hoist to vertical. Lowered and topped off fluid. Now wont go forward or reverse. Makes no noise when pedal is engaged to move either...
You will have air in the system and will need purged. To do that you jack up the wheels to where they will turn freely then disengage the hydro and at an idle alternate forward and reverse for a for about 4 or 5 minutes. Recheck the fluid level and top off. Now engage the hydro and do the same forward and reverse for 3 or 4 minutes. You should have axle movement at this point. Hope this will help.
May 20, 2017 | Cub Cadet Street Sign- tractor lawn riding...
Replacing the clutch on a 1998 Saturn SL1 we encountered a problem after installation, The clutch would not disengage. The hydraulic clutch system and slave cylinder seemed to be working fine, we even...
It is very difficult for you to disengage the clutch by hand or with any leverage you can get outside the transmission. There is over 200 lbs of force clamping on the clutch disc.
If you replaced the clutch and took the slave cylinder out of the transmission without putting a brick under the clutch pedal or disconnecting the pivot arm from the pedal then you ruined the hydraulics. Buy a new PRE-BLED system from a local auto store. Generally this is the problem.
Either that or the clutch fork is bent or you installed the throwout bearing backwards (or simply fell off the fork which is not all that uncommon).
May 22, 2010 | 1998 Saturn SL
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
