Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Mower stuck in gear
If I push on the forward or back pedal it will whine. It will not disengage the transmission with the pin in the back that usually put the mower in free wheel
    New Friend:
  • 73 Answers
I would say you have a problem in the hydrastatic transmission itself,and that could be a number of different things and hard for you to fix yourself,it would be best to have professionally checked out.
Posted on Apr 03, 2014
  • 32 Answers
SOURCE: I have a 20hp turbo twin cylinder, 42
I think that it is not imposible to switch gears it is just very hard. i had that problem once too!
Posted on Jun 21, 2009
  • 245 Answers
SOURCE: Tractor will not go in forward gear, only reverse.
Try rocking the mower forward and backward while you try to shift it.
Posted on Aug 22, 2009
  • 33 Answers
SOURCE: I have craftsman 17.5 HP 42
Check for a broken or dislodged belt
Posted on Sep 20, 2009
  • 81 Answers
SOURCE: Craftsman LT2000 transmission won't engage
Sounds like you either lost a bearing inside the transmission or that something in the linkage system has come loose and shifted. easiest way is to jack the unit up and visually follow the shifting hardware, while having someone trying to engage it with unit shut off and see is you can visually find where the shaft is slipping or failing to move. Hope This Helps Don
Posted on Nov 10, 2009
  • 8 Answers
SOURCE: lt1000 hydrostatic drive stuck - will not engauge or disengauge
Does the tractor try to move or **** in any direction, if so you may want to check to see if the disk that controls the brakes is stuck, I've seen this many times.
Posted on May 18, 2010
Why isn't something engaging when accelerator pressed?
It would help to know more information about the mower in question. Walk behind push mower? walk behind self-propelled mower/ Riding lawn mower? Lawn tractor? Or goat...just kidding...lol. The engine horse -power or cc's and make of the mower and engine. Anything happen before the problem or was it straight out of storage. Does the gas pedal feel normal? Could you be talking about the forward/ reverse pedal? These types don't engage by depressing them, they engage by releasing the pedal.
I'm going to guess you have a riding lawn mower or lawn tractor. The pedal for those types of mowers controls the transaxle ( rear wheels, transmission and differential basically). If the pedal move properly and it was working ok when it was stored, then check to see if you can push it with little effort. On most transaxles there is a disconnect rod to disengage the transaxle for towing the mower without damaging it. Pulled out for disengaged and in for engage. If that all checks out it could be very low on transmission fluid or the drive belt might be off or broken depending on which type you have. If it is low on fluid, you have a leak. Hope this helps.
Mar 11, 2016 | Garden
Pto works engine starts but when i push pedal tractor will not move
Transmission disengage pin is pulled out to the NoGo position.
Push it back in, located behind the seat on the vertical frame plate (black)
Oct 03, 2014 | Husqvarna Garden
Pedal is free- mover does not move
Two possibilities to look for.1. The linkage may have lost a connecting pin. Follow active rods from pedal to control arm on transmission. 2. There is a disengage rod to allow the machine to be pushed without the engine running. If this is in the disengaged position the transmission will not drive. Look at the rear and low down for a lever or rod which is connected to the transmission.
Sep 28, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Brand new cub cadet zero turn mower will turn on but not engage wheels to move forward or back
There are two transmission pins that engage and disengage transmissions so you can drive it or push it around. Usually around the rear of the mower by the tires.
May 23, 2014 | Garden
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
I changed the back tire on my craftsman riding lawn mower and now it will not go forward or backward. It runs fine.
There is a lever between the back tires which disengages the transmission so the mower can be pushed when not running. Chances are you must have disengaged this lever maybe by accident. If you push it back in, the transmission will work right again. Usually it is a wire with a loop on the end.
Aug 06, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Noisy Transmission getting worse.
Does it still move? Make sure you don't have a stick or something stuck in the transmissions pulley/fan. Check idler pulley's too.
What kind of noise?
Sep 03, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
My riding mower is stuck in gear. I can shift
If the wheels aren't facing straight forward you may have broken an axle.
May 18, 2009 | Garden
Rear wheels will not turn. Worked fine when stored for the winter
Craftsman-Husky...same tractors-built in the same factory. I also had a problem with the hydrostatic transmission not providing power to the rear wheels. Here's what Sears told me:
(1) Check to make sure the drive belt is tight both under the engine-and the tranny.
(2) Air can get into the hydrostatic transmissions-especially during shipping (new mower) and storage.
So.....
Pull your freewheel pin out to disengage the tranny-then push the mower both forward and then backwards for 50' or so. Then push the freewheel pin back in and start the mower. If the transmission then works-drive forward-then backward-then forward repeating the cycle about 4 times. Drive about 50' in each direction. This should purge the air from the treansmission.
Mar 20, 2009 | Craftsman Garden
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
76 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
