Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman 917273482 will not shift into gear, and I can't push it because it won't disengage
Transmission will not engage in gear and it will not disengage so I can push it
  • 3 more comments
  • L&D Small Engine Repair
    First, look for a release/disengage levr on rear o mower to disengauge trans and pull it out. See if you can now push or pull unit. Net, check shifter and follow shifter linkage to trans. There should be a pin holding this in place. I suspect your pin s missing, f not you will have to take nit to a qualified mechanic. Good luck.
    Forgive my spelling, still on my first cup of coffee this morning.
  • Dennis Key
    Dennis Key Mar 24, 2014
    This is what I do. Not right,but jerking lever when moving. I think the problem is clutch needs adjusted.
  • Dennis Key
  • Dennis Key
    Problem Solver:
  • 20 Answers
If there is too much play in the drive belt due to belt stretch or linkage wear, the belt will be too loose to drive the tranny but still cause the tranny input shaft to rotate preventing it from being put into gear.
Do the gears grind when trying to put into gear? With engine off you should still be able to push the machine if you put it in neutral. Unless, of course it is a hydrostatic transmission, in which case there should be a lever to push/pull which will put the hydrostat in neutral. This is all assuming that it is a hydro and while running the machine won't move when putting the drive lever into forward or reverse.
Posted on Apr 15, 2014
SOURCE: Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Posted on Mar 24, 2009
  • 86 Answers
SOURCE: Craftsman lt1000 with manual transmission,
The detent Shaft inside transmission lost its ball and spring if its working outside transmission,could be other damage .
Posted on May 09, 2009
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
  • 32 Answers
SOURCE: Mower will not move.
It is very likely that your belt is not on right. Check your manual to see it it is on right.
Posted on Jun 13, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
Craftsman tractor won't go into gear; had flat tire, got it fixed and remounted, now tractor won't go into gear
Not much info here on model and type. However, my Craftsman Tractor 46", 971.288520 with automatic transmission. On all these similar models, on the rear of the mower and the rear axle level, a small key-hole type opening exists that has a small diameter wire protruding with a 90 degree bend at the end. If you pull on this wire, it disengages the transmission so you can push the mower around for loading or other reasons. To reengage, just push the wire back in and transmission will again work. Only moves about an inch each way when pulled and pushed. This may have been hit while working on tire. Can also be use to prevent driving by others who do not know about the release. Another possibility that happens quite frequently with this model mower, especially when jacked up to replace wheels, tires or bearings, is the drive belt will drop down off of the drive pulley under the engine. Belt is loose when drive is not engaged. That is how the design keeps the mower from moving when you are "out of gear." So, loose is fine, but not up and around the pulley is not. The belt is held in place by a couple of "keepers" on each side so that it does not completely fall off. I have even had this happen when I stopped mower in yard, disengaged transmission to get off and pick something up. Kind of a goofy design, but cheap way to solve the disengage drive issue.
Oct 17, 2016 | Craftsman Garden
Why the transmissiom won' engage in any gear
Transmission won't engage Drive or Reverse - EricTheCarGuy
www.ericthecarguy.com/.../53999-transmission-won-t-engage-drive-or-r...
This transmission shifted smooth and strong through all gears until today when it stopped all of ... Any idea on where we should start tackling this issue? .... Also, make sure that the pressure tester is not leaking or you will run the tranny dry(use ...
Gear shifter goes from park to drive with no effect. Won't ...
Nov 26, 2015 | Cars & Trucks
Manual transmission
The short answer, yes. M46 models with the type J or P overdrive (depending on year and market) require a certain level of oil in the overdrive. Additionally, the overdrive is a lot like a standard automatic transmission with one gear range in theory of operation. Therefore, the hydraulic properties of said transmission do come into play here, line pressure, shifting pressure, accumulator and piston function all work together to engage or disengage the unit. Always ensure the unit is disengaged before downshifting and of course, shifting into low reverse.
Feb 07, 2014 | 1988 Volvo 740
Transmission
Sounds like this car was submerged in water sometime in its life.
What is your specific question ?
May 04, 2017 | 1997 Audi A6
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
sounds like its time for a new mower
Apr 24, 2012 | John Deere Garden
The tranny on my 883xl will shift through the gears but it won't engage. It will go into neutral. I don't have to engage the clutch to get it to shift through but even with the clutch it wont...
Sounds like your final drive belt is broke. Put the transmission in low gear with the engine off and try pushing the bike. If you can push the bike with the transmission in gear and the belt is not broke, it could be the front belt pulley is stripped in splined area where it goes on the countershaft. to check that take the rear master cylinder loose and remove the front pulley cover. Put the transmission in low gear with the engine off and push the bike. If the front pulley turns and the countershaft does not, the pulley is stripped.
Good Luck
Steve
Jun 18, 2011 | 2004 Harley Davidson XL 883 Sportster
My 2 year old Craftsman lawn tractor will no longer go in forward or reverse. It has the hydra static gear shift. All the belts look intact. Mower blades will engage. It is a 24 horsepower. Any...
There is a lever in the rear of the rider that allows you to disengage the transmission. It is intended to make the rider easy to push around. Make sure that hasn't gotten activated. The lever is usually located just above and to the right of the hitch plate (where a trailer would attatch). Sometimes it is located under the seat near the seat hinge. Hope this helps.
Good luck.
Sep 02, 2010 | Craftsman Professional 24 hp 42" Yard...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
216 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
