Question about Top-O-Matic Topomatic Cigarette Rolling Machine Top-o-Matic
The handle sticks when crank to push tobacco throuh
Handle sticks when try to turn
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 29 Answers
Clean it with alcohol. Wipe it down , it removes tar and sticky residue without getting it soaking wet. Alcohol works great on ashtrays also !
Posted on May 23, 2015
The injector shaft will not push the tobacco into the tube, it seems to be jammed, how can I fix this?
Make sure your tobacco doesn't have too much moisture in it to start with then try using less tobacco. Too much tobacco will cause the plunger to halt when it is only partially deployed.
Dec 07, 2016 | Cooking
The machine got jammed and I heard it snap so I know it broke. this is the 2nd machine I have bought in 2yrs. I try not to put too much tobacco in there but it snapped. How can this be repaired?
you are loading way too tightly, do not force when pushing the handle down, if you have too you are over packing. I have loaded 200 cartons of cigs on these machines and never broken a thing
Oct 04, 2016 | Powermatic 2 Electric Cigarette Injector...
My crank wont move
are you loading it too tightly? w/o tobacco will it move? Take the rubber bottom off and inspect a touch of oil on rubbing parts
Jan 19, 2016 | Top-O-Matic Topomatic Cigarette Rolling...
that is typically a moisture level issue or too much tobacco loaded. clean it out, use the tools provided or a thin rod to clear the tube, inspect and retry.
Oct 14, 2015 | Powermatic 2 Electric Cigarette Injector...
Tobacco only goes half way down thetube
inspect that the rubber piece that holds the tube.Chance's are that it is worn and needs to be replaced. it wont hold the tube all the way if it is worn. A quick fix is to cut a piece of eraser of a pencil and glue it to the holder.
Oct 10, 2014 | Powermatic 2 Electric Cigarette Injector...
Tube does not fill down by filter
Trick i have learned is to put a small amount of tobbaco in the chamber now move it side to side with your finger tips. Now add more tobbaco to the chamber as you normaly would.It will fill the tube better If that does not work out for you try virginia blend tobbaco it will work better in any machine.
Apr 08, 2014 | Powermatic 2 Electric Cigarette Injector...
Electric Starter Sticking I have a 2000 Kawasaki Ultra 150. I just changed that battery and was going to make sure that it started before tomorrow. When I first pushed the start button, it didn't do...
Sounds like a stuck starter solenoid,if you can get to the solenoid tap it with the handle of a screw driver,might take a sharp rap if it quits cranking then you will need to replace it...
May 27, 2010 | 2000 kawasaki VN 800 Vulcan Classic
Top o matic cigarette injector is only filling the cig half way
Hi Mindy,
Make sure that your tobacco is not too wet. Set some tobacco out (about the amount you plan to roll) and let it air dry for about 5 - 15 minutes. You'll have to figure out how long to let it dry as your home temperature is different than mine. Don't let it dry too much though. Give this a try. It works for me.
Take care,
Dennis Mason
Jun 17, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Door window handle
There is a butterfly clip that sits in a set of notches on the actual crank handle. you will need something small and long enough., like a mini flat head srewdriver. Push the door surface and turn the crank until you can see the ends of the clip. Now, use your screwdriver to push the clip off the crank handle. It will shoot off so keep an eye on the ground when you get it off. Hope that helps.
Jul 28, 2008 | 1999 Pontiac Sunfire
Top-O-Matic Topomatic Cigarette Rolling Machine Top-o-Matic Logo
186 people viewed this question
Top Top-O-Matic Cooking Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Top-O-Matic Cooking Expert? Answer questions, earn points and help others
