Question about Panasonic MJ- 66PR Juice Extractor
Top part where you put the vegies in missing
Lid of extractor to be replaced please
We're can I get a replacement lid for my Bella Sendio juice extractor model 13694a
Fixya does not sell replacement lids and cannot advise sources.
Aug 05, 2017 | Juicers
Opening lid to add fruits
The Manual for the Acme 5001 Supreme Juicerator can be downloaded from the following link:
http://www.everythingkitchens.com/PDFfiles/6001.pdf
Items to be juiced must be cut to size and fed through the feed chute. The machine will not operate if the cover is not properly in place.
Jul 23, 2012 | Acme 5001 Supreme Juicerator Juice...
Model 6001, when I used it to make orange juice, it shook so much the top lid became loose. Why?
Not designed to juice oranges, but if you must, feed it real slow. Your juicer went out of
balance that's why the extreme vibration.
Apr 04, 2011 | Acme 6001 Juice Extractor
My lid doesn't seem to fit properly. When I put the top on to cover the screen, it doesn't seem to fit together properly-- the bottom of the chute that you throw the fruit and veggies down butts right up...
Is this a new cover? There is an adjustment. On the bottom of the machine, dead center,
there is an adjustment screw with a locking nut. Unlock the nut and the turn the screw
counter clockwise, this will lower the motor shaft and consequently the blade. Once you
have clearance and install the cover, turn the screw clockwise until the blade contacts the
chute, back it off a half turn and lock her down. This will establish the correct gap between
the chute and blade. Also if your chute is ever chipped or scored by the blade because
of excessive vibration, you can file the chute level and readjust the gap.
Mar 13, 2011 | Omega 1000 Juice Extractor
I have the beaumark juice extractor BM-473 it worked then i washed the removable parts now it wont work
the first solution is half right ... there are 2 hidden switches on the machine which are activated by shafts on the pulp container and on the top lid .if either is not on then machine will not work. possibly broke plunger on the pulp container ....or broken clip that holds the container in place
Jan 04, 2011 | Champion G5NG853S Household Juice...
Hi I have an older acme supreme juicerator, model # 11je23. Do the newer baskets & lids fit this older model? Or can a guy get original parts?
Believe the basket is the same. The newer lids have a flange
around them which can be filed down. Takes time, but file away
tapering it until it fits in the juice bowl. With a new lid you may
have to adjust the chute to blade gap. On bottom loosen center
locking nut and turn adjusting screw clockwise until chute contacts
blade, then back it off a half turn and lock it down. A few older lids
are around, but it's hit and miss.
Nov 05, 2010 | Acme 6001 Juice Extractor
I have a Krups Vitamight model 294 juice extractor. My son used it and now I can't get the pulp container off. I have never used it and the the manual is gone.
i was having the same problem and couldn't find it anywhere... finally figured out that you twist the top off. place the unit with front towards you.
pull/twist the right side (pulp catcher) towards you about a quarter turn and the entire top comes off including the sieve.
Nov 20, 2009 | Krups Juice Extractor
Looking for downloadable juice extractor book
BOOK CALLED "JUICING FOR LIFE" AT AMAZON.
TRY 2 CARROTS, 1 APPLE, 2 CELERY STALKS
AND A HALF LEMON. ALSO IF JUICER BREAKS,
GO FOR SOMETHING BETTER LIKE AN ACME.
HAVE ONE SINCE 1990.
Nov 26, 2008 | Jack Lalanne KN2047 Juicer
Waring Pro Juice Extractor model #WE100PC - WILL NOT POWER ON!
check bottom of the basket and see if piece is missing or broke.
Sep 04, 2008 | Waring Pro¿ PJC Series PJC11 Juice...
Panasonic MJ- 66PR Juice Extractor Logo
21 people viewed this question
Top Panasonic Juicers Experts
David Payne
David Payne
Tom Chichester
Are you a Panasonic Juicer Expert? Answer questions, earn points and help others
