Question about Casio Ctk-3200 61-key Touch Sensitive Keyboard
Clicking noise My keyboard makes a clicking sound when it's not powered on or plugged in. I thought i was going crazy until i found this forum. Can anyone tell me if this is normal? I don't hear the clicking sound when i am playing it.. i only notice it when the room is quiet. It's very random and sometimes clicks in double or triple time. Quite annoying! Help!
poolseman
  • 206 Answers
SOURCE: My daughter drop the Camera Casio Exilim EX-S600
Lens or lens gearbox damaged that is why camera switches off automatically to prevent additional damage. You should send camera in for a quote because replacing impacted lens can be v. expensive. If you are lucky it is the gear box and that does not cost so much to fix.
Posted on Sep 02, 2007
  • 374 Answers
SOURCE: My Casio EX-600 makes clicking noises when the lens comesout.
Lens error. send into casio repairs and they will fix it for you.
Posted on Nov 26, 2007
  • 34 Answers
SOURCE: CLICKING NOISE
The clicking noise is the internal focus lens. The S500 and S600 are very succeptible to debris getting in the lens. Or, the focus lens was knocked out of alignment.
Posted on Jan 25, 2008
  • 5603 Answers
SOURCE: i have a casio keyboard that i've had for awhile.
If it runs on a wall wart transformer, the transformer rectifier in it may have failed. Try a new one of the same rating. It is also possible that the input filter cap in the keyboard has failed resulting in un-pure DC voltage to the keyboard.
Posted on Aug 27, 2009
  • 54 Answers
SOURCE: The lens will not go in or out and makes a
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
Posted on Nov 16, 2009
Pa800 no sound
I'm not sure, but I believe this has a small sound card inside like in a pc and later model guitar amps. This card runs reverb and things like that and it also may have a small power plug going to it. I have found on many guitar amps that when this plug gets dirty, or possibly just a weak connection, they usually create static noises and then it echoes that noise. I hope this helps you.
Mar 04, 2014 | Music
Weird Noise!!
Did anyone check the shields for the exhaust ?
Jul 03, 2013 | 2005 Chevrolet Tahoe
How can I turn off the sounds the keyboard makes when you hit certain keys...for instance the caps button makes a loud beep..I thought I remember when i set this keyboard I had the option of having the...
Try this Go to start click control panel and then click sounds and audio devices and click the tab named sounds and in the sound scheme click the drop down menu and select no sounds and then click on apply and click ok ..Check whether it works
Mar 08, 2011 | Gear Head WIRELESS keyboard/Mouse
Aspire 5100 and aspire 9100
I'm not sure I understand completely the problem you are having with your Aspire. However, it seems you are having problems with keyboard, touchpad etc.
One thing I realized a few months ago, mine started going crazy. I searched the web all over and found that REMOVING the battery completely solved the problems with the keyboard and touchpad problems.
I have to use mine without the battery in. Only plugged in.
Try removing the battery, leaving it out, plugging in the power supply and see if that does not fix the craziness of the touchpad and keyboard.
Dec 11, 2008 | Computers & Internet
Loud clicking
You're going to have to narrow it down by removing components. Start by removing the hard drive, if the clicking stops then you know that it's a component that needs or uses the operating system. If it stops then put the hard drive back and remove other components, CD drive, keyboard, etc... until you can either locate exactly where it's coming from or it stops. The CD drive could be the culprit, and removing the keyboard will expose some of the inner workings so you can hear it better and possibly find what it is. This isn't a simple fix, it will take a little effort, but I believe you will find the problem, this is the exact same way that I would do it if you were to bring the computer to my shop.
Jul 24, 2008 | Toshiba Satellite Pro 4600 Notebook
Funny noise on drivers side and loss of power during acceleration
ok its a thought off my head that i can think of right off
the brake on drivers side is binding and the squiller pin i call it is rubbing on rotor you probably need a brake inspection there free at brake masters
May 30, 2008 | 1998 Kia Sephia
NT1A no signal in sequencer
try cleaning your plugs before inserting them into the machine. a dry clothe will do nicely. polishing the plug heads in a twisting motion.
Sep 13, 2007 | Rode NT1A Professional Microphone
Humming noise on HP Pavilion dv9000
I have a dv6000 and its makes a insect tlike noise. i returned it and  got another one but that one also made the same noise. so i contacted hp and they told me that the sound is coming from the USB ports, i thought wierd but here is the solution to your problem. go to computer managment (start>right click my computer> manage), click on device manager, select the universal serial bus contollers ( there should be a few roots files that open up), right click a usb root hub and select properties, click the power managment tab, and uncheck "allow the computer to turn off this device to save power". do this for every USB root hub that you have, and the problem should go away. FYI these instructions are for windows XP.
Aug 04, 2007 | HP Pavilion dv9000z Notebook
Clicking as soon as plug in
I found this on another forum - testing it now expect something in several hours Praise th' lawd for this forum!!! I bought my ts360 from a neighbor on craigslist (he even gave me all the extra stuff I didn't need: standard rec., dish, mounts, rf remote and sensor, etc...anybody need any of these things?) so I could use strictly as an OTA receiver. After taking my time hooking up all the connections (suuucks), then plugging in the receiver only to hear the constant, loud clicking sound, I knew it was over. But being as stubborn as I am, I researched the prob Google-style and prayed that there was a solution. Sure enough, after reading and re-reading these posts (a godsend!), I had a plan. When I had time, I plugged the receiver into an outlet and let it tick away (in my office!) After about 2 hours, the clicking slowed, becoming unsteady. I thought it would kill over with no response. It stopped, then 'voila'!!! It came to life; went into standby mode. I pressed the standby button, then I saw the dreaded "boot fail" on the display. Noooo! When I had time later, I researched that problem. Found some entries (thanks, Google! (another godsend)) and answers to solve it. Got the receiver home, plugged it in (this time it only took 15 minutes to stop the clicking sound, got the "boot fail" message, then selected 'no dish' from the menu; receiver reset, then all is good!!! In a nutshell (for others with the same problem), I: made my connections (dvi cable, audio cables) Plugged the receiver into the outlet (didn't have to connect phone line or dish!!) Waited until the ticking stopped See the "boot fail" message on the display On the tv screen, tells you to press 'select' Press 'select', then, at 'dish type', select 'No Dish' Receiver tells you it will reset for the changes to take effect After it powers on, it's all good. You may have to do a OTA antenna scan on yours. The guy I bought mine from already had the local channels in memory. Pretty much the same scenario as Wingryder, and like Sprocto4 said, the initial problem (the clicking sound for eternity) is due to a "lack of power up." This forum saved my ts360 from the junkyard. That night I stayed up late to watch all the hd I could.
Nov 19, 2006 | Samsung SIR-TS360 DirecTV DTV Receiver
Casio Ctk-3200 61-key Touch Sensitive Keyboard Logo
16 people viewed this question
Top Casio Audio Players & Recorders Experts
Greg Cann
Greg Cann
David Payne
David Payne
Danny Kuhlmann
Are you a Casio Audio Player and Recorder Expert? Answer questions, earn points and help others
