Question about Peavey XR1212 12 Channel Powered Mixer
Hooking up other external systems
How do you hook up external pwr amp and connect to a gemini dj mixer?
    Genius:
  • 1,114 Answers
Peavey XR 1212 You may find helpful info from the Peavey site. I'm not sure how you want to configure your setup, but the tape out may be able to feed the power amp.
Posted on Mar 24, 2014
How do I open my mixer to repair the mic input jack
Gemini mixers are a hassle. You should take out all the phillips screws on the front, see if there4 are any on the side panels, and then see if it comes apart. If not, go for the screws on the back panel (the side and front /back ones). Be careful not to take out the one for the transformer (usually a big one or a nut). Peace.
Jun 09, 2015 | Gemini DJ Gemini MM-2400 4-Channel Stereo...
Help with hooking up a compressor for vocals.
The compressor is a really good idea and should be connected between your mixer and your amplifiers. Your "integrated" mixer/amp is a bit tricky in that you will have to "insert" the compressor in the signal path.
If you have the "console" model....
1. "Main 1 Out" left and right to the input of your compressor and the output of the compressor connected to the "PWR Amp Insert."
2. What is known as Tip, Ring, Sleeve patch cable and plug connected ONLY to the "PWR Amp Insert." This type connection breaks out into a "Input" and "Output" using a single 1/4 stereo plug.
If you have the "square box with knobs on front" model
1. "Main Output" to input of comressor and compressor outputs to "Input to Main" (aka "AUX IN").
Check your owners manual for hookup details or suggestions and remember, all outputs feed inputs and all inputs feed outputs.
Oct 29, 2012 | Behringer Music
How to hook up a gemini amplifier?
typically (unless your useing other gear besides mixer and amp) you'd come out of the L/R outs. ( Main outs ) to the Main inputs of the power amp then out to your speakers (outs of power amp). Now the amp could be in bridge mono or other factors but typically, like i said, just
Mixer Out- Amp In- Amp Out- Speakers.
Oct 22, 2011 | Gemini Sound Products GEMINI XGA 2000 2000...
Im thinking about buying a djx750 and have rokit 5 monitors. would this work? what is the best way to connect them, to have good sound? it is just for a home dj setup, all on one desk, two cd decks,...
Here is alink to the manual:http://www.behringer.com/EN/downloads/pdf/DJX750_P0956_M_EN.pdf You should have no problems hooking them up (RCA to RCA). I've been using a Behringer XenyX1222FX board in my recording system for about 4 years now and have been quite satisfied with it's reliability. Try to find a dealer who will demo the mixer for you.
Aug 24, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Cant hear anything out of my speakers connected to djio
Are you using a Mixer as a pre-amp for this set-up? For example, I have a Numark CM200 where I have all of the inputs and outputs I need to run. DJ IO is connected to Chanel 1 and Chanel 2 Lines in my mixer. The DJ IO is conected to my computer by USB cable. In Traktor souncard settings chanel 1 is set to (3&4) Chanel 2 (2&1) also, devise set up is Numark DJ IO and in External mode. Of course the mixer is conected to my amp and speakers conected to the amp as well.
Apr 26, 2010 | Numark DJ/iO Sound Card
How do you hook up gemini xl 300 turntables to a gemini pmx 500 mixer
red n white phono leads from deck 1 to channel1phono ports on mixer
red n white phono leads from deck2 to channel2 phono ports on mixer
then output out to amp
Jul 06, 2009 | Philips gemini XL-300 Turntable
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
Apr 02, 2009 | Stanton Sa3 DJ Mixer With Eq System
STANTON SK-FIVE MIXER HOOK UP
are the gnds connected(earths) you get a buzzin noise if not earthed
May 15, 2008 | Stanton Sk2f DJ Scratch Mixer - Good...
Peavey XR1212 12 Channel Powered Mixer Logo
63 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
