Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
No lights come on touch pad its ot working
HOW TO CK TO SEE IF BOARD IS WORKING
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
This is a difficult task you would need the tech sheet and check the voltages on the board , compare them to the tech sheet
Posted on Mar 24, 2014
My Kitchen Aid Dishwasher is 8 years old, The light that I push to start it, does not light up, and I cannot turn it on. All other lights are on
Looks like an electronic problem. Most likely the touch pad. But sometime you may be end up changing the both touch pad and main control board. Also sometime harness between the touch pad and main control board can be the culprit. If there is dirt build up harness then user rubber eraser to clean it out. It will help.
Sep 25, 2014 | Dishwashers
Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
May 27, 2010 | GE Profile JTP56 Electric Double Oven
The fan start coming on after the oven is heated up then f10 starts flashing and the oven starts beeping on my kenmore elite convection oven
the only codes ifind for the f 10 is defective touch pad.. ck the glass alligament /ribbonconnector / replace touch pad if necessary / . this may be a thermadore buit unit / there f10 states also to replace the contr board .. hope this helped **** ..
Dec 04, 2009 | Kenmore 47783 Electric Single Oven
My touch pad will not work thus rendering the oven useless. It will not respond to touch. Is there anything I can do sans a new processor pad?
HI. Unfortunately, the touch/key pad is not repairable. Once the circuitry is damaged, the entire board must be replaced. Most units will have an Incorporated control board, that will have the touch/key pad integrated into the main board assembly. If this is the case, simply replace the entire oven control board. If the touch pad is separate from the main control board, replace the touch pad board.
NOTE_ This may be a simple control fault. In this case, simply unplug the unit, or shut down the appropriate circuit breaker for five minutes. This will reset the control. If the issue's persist, replace the failed component.
Dec 03, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
Jun 03, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Touch pad doesn't work
ut the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved!
Mar 15, 2009 | GE Profile Spacemaker Over-the-Range...
Touch pad does not work
If it stopped working after you dropped it, try this:
Hold the Zen in your hand, and with your thumb, press down on the face board as hard as you can. Use your other hand's finger to scroll up or down on the touch pad. Press down different areas of the face board until you find a spot that, when pressed, causes the touch pad to work. Then, using both of your thumbs, press that spot VERY hard until the touch pad works without pressing.
Sep 29, 2008 | Creative Labs Zen Touch MP3 Player
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
90 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
