Question about Fisher SLIM-1500 CD Shelf System
How to set alarm
Dont know what buttons to use to set the alarm. would like to be walked through the steps please
Anyone knows how to turn off the hourly chime and alarm on Skmei S-Shock watch, please?
depending on your watching you will have two different methods that will allow you to operate the setting built into your watch. some you press and the you alternate to the next button and so fourth until your specific request is completed. others you will have to hold down a button until a specific mode is enabled then once enabled you may start to adjust the settings. the watch that you have also came with a user manual that you can reference to so you have a step by step walk through of how the process works.cheers!
Nov 04, 2015 | Watches
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    Our 2001 Winnebago Ultimate Advantage Motor Home has a The MindReader Auto Security System by SCS. I need to know how to access the reset button or how to reset in order to reprogram the keyless entry key...
    Easy way is to Disconnect the main vehicle battery for a few minutes. When you hok it back up the alarm will start beeping every 5 seconds or so and this means it is in the "programming" mode. You can program up to 5 buttons at this time. SO press each one on each of your remotes one time and the alarm will respond with a loud BEEP. if you only have one remote to program just keep pressing the same 2 buttons till ou reach the 5 limit. Then it will stop beeping and you are set up.
    There is an additional way to do it through the programming option of the alarm but you really need a manual to walk through those steps.
    Good Luck
    Steve@capriceshop.com
    Dec 03, 2009 | Astra Ast200 Auto Security 4-channel Alarm...
    Turning alarm on and off
    I'm afraid I don't have a manual, but I could walk you through the steps...
    1. Press the clock/sleep/timer button twice.
    2. Press enter button.
    3. Turn dial to set hour for alarm to start.
    4. Press enter button.
    5. Turn dial to set minute for alarm to start.
    6. Press enter button.
    7. Turn dial to set hour for alarm auto-shut off.
    8. Press enter button.
    9. Turn dial to set minute for alarm auto-shut off.
    10. Press enter button.
    11. Turn dial to select either Radio or CD alarm setting.
    12. Press enter button.
    13. Turn dial to adjust volume of alarm.
    14. Press enter button.
    15. Press standby button. Alarm is set.
    I hope this helps! Best of luck finding a manual if you still need one. :)
    Jun 03, 2009 | Sony PSYC CFD-E90 Radio/Cassette/CD...
    Braun cleaner for shaver
    Here's a link to download the manual. Good luck!
    http://www.manualnguide.com/manual-get/3308/
    Jun 02, 2009 | Braun 8585 Electric Shaver
    Don't know how to shut alarm off of my sportline walking shop
    Press the middle button to get to the alarm button. Press the far left button, then press the middle button again to take the bars on the top of the alarm time go away.
    If that doesn't work, go to Sportline.com and read the manual.
    Mar 23, 2009 | Sportline Stopwatch
    The alarm isnt working... car wont start, buttons wont work!
    Just a possibility, but a discharged battery could be the culprit. Do the headlights come on brightly? Will the horn blow normally? A 'dead' battery will usually have enough power to illuminate LED warning lights, while not having enough current to operate the starter/door solenoids, etc. Have somebody test the battery voltage to be sure.
    Mar 14, 2017 | Toyota Corolla Cars & Trucks
    I need a manuel for a go walking stopwatch by sportline the stopwatch is an 2006 model # 2832
    First, press the mode button (the one in the middle) until either the alarm set screen or the time screen shows. Second, while in the alarm set or time screen, simultaneously press the split/reset select button and the start/stop set button (the two outer buttons). The alarm symbol should go away (this is normally in the upper right corner of the screen).
    Nov 25, 2008 | Sportline 345 Electronic Pedometer
    Watch isn't recognised by computer
    Hi Hoffman518,
    To set the alarm on your Timex Ironman, please follow the steps below.
    1. Begin by pressing the "mode" button until the alarm screen appears.
    2. Press the "set" button and use the "advance" button to set the hour for your alarm.
    3. Repeat the same procedure to set minutes and seconds for your alarm.
    4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
    5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
    Hope it helps.
    Thank you for using FixYa.
    Aug 08, 2007 | Timex Ironman 53151 Wrist Watch
    Fisher SLIM-1500 CD Shelf System Logo
    37 people viewed this question
    Top Fisher Audio Players & Recorders Experts
    Henry  Thomas
    Henry Thomas
    SHARCNET-USA
    SHARCNET-USA
    Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
