5700 stapler handle will not go down when pressed no staples in gun i removed the bolt and nut then the slide handle still doesn't move
If the handle of your 5700 stapler does not go down when pressed, even after removing the bolt and nut and the slide handle, it suggests there may be an issue with the internal mechanism. Here are a few steps you can take to troubleshoot the problem:
Check for jammed staples: Even if there are no staples visible in the stapler, it's possible that a staple may be jammed inside the stapling mechanism. Try using a pair of tweezers or small pliers to carefully inspect and remove any debris or jammed staples that may be obstructing the movement of the handle.
Lubricate the stapler mechanism: Apply a small amount of lubricating oil or silicone spray to the moving parts of the stapler mechanism. This can help loosen any stuck components and improve the smoothness of the handle's movement. Be sure to use a lubricant suitable for mechanical devices.
Clean the stapler: If the stapler has been used in dusty or dirty conditions, debris may have accumulated inside, affecting its operation. Use compressed air or a soft brush to remove any dirt or debris that may be hindering the movement of the handle.
Inspect for broken or worn parts: Carefully examine the internal components of the stapler, such as springs, levers, and pins, for any signs of damage, breakage, or excessive wear. If you notice any broken or worn parts, it may be necessary to replace them to restore the stapler's functionality.
