Question about Goulds Pumps Plumbing
Gould water pump
Pump just humming a few secs and cuts off
2 Suggested Answers
  • 12650 Answers
SOURCE: My jrs5 Gould's pump is making a humming noise as if it trying to build the pressure but nothings happening after that. Just that constant humming. It was working fine up to this morning.
check capacitor look and check pump not binding
Posted on Jul 29, 2016
Testimonial: "Thank you guys so very much!!! U guys are heroes!!! I can bathe now!!! Lol"
When H2O runs pump keeps cycling every 15 to 20 sec. H2O drops to 30psi and pump stays on until 60psi. Then a couple of seconds does again until H2O is shut off. Pump runs for around 30 seconds.
If you've got the water turned all the way on, it sounds like your setup is operating normal. If the pump where turning of and on say every 5 seconds or so I would say to check the air pressure in the water holding tank that it's at the correct pressure.
Mar 01, 2015 | Goulds Pumps Goulds J5S Jet Pump Shallow...
My water pump is only humming not working
the humming means the power is getting to it, but for some reason it is not spinning, if it ran dry too long the impeller may have melted.
Dec 26, 2014 | Goulds Pumps Pump Centrifugal 1/2hp
How do i prime a gould j5 pump
to make it easy to prime a pump I put a "T" piece in the suction line close to the pump. When it needs priming I take out the plug and put water in the line until the pump is full
Oct 17, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Pump will not build enough pressure to shut off. New Bladder Tank set at 38 PSI. New switch set to cut on at 40-42 Psi. New Foot Valve, New Tank, New Pump. Blew line to well water a few days ago. Pump
check the water level in the well as it may be too deep for the pump to lift the water and maintain the pressure. Are you using a straight pump or an injection pump that helps lift the water to the pump. remember that centrifugal pumps only supply a vacuum in the suction line and atmospheric pressure on the water does the rest. when the weight of the water is equal to the pressure of the air the pump will not lift any more
Oct 05, 2014 | Goulds Pumps Goulds gt10 1 1 Phase...
Why dont i have water pressure after my pump cycles off
Make sure your tank is well pressurized and not water logged.Is there a significant difference between your cut in and cut off pressure.Check for leaks -water or air.
Sep 07, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Gould water pump
I service all sorts of Goulds water pumps for a living but will need some more info to troubleshoot your problem. For starters would need to know what voltage feeds it, single or three phase, horsepower, type of controller (pressure switch, Variable Frequency Drive, Three phase across the line start etc.), what you are doing with it, pump model number, motor frame number, etc. etc.
May 12, 2013 | Cars & Trucks
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
Won't pump water but can hear it humming?
could be something plugging the impeller,theres I think 3 screws to remove the bottom check if some small stones are plugging it up.that pump should be installed off the bottom of the pit like on a patio block or the like.unplug the cord before messing with it.
Feb 22, 2011 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Plumbing Logo
Top Goulds Pumps Plumbing Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
ray gallant
Are you a Goulds Pumps Plumbing Expert? Answer questions, earn points and help others
