Question about Boss AUDIO SYSTEMS BV7300 Car DVD Player
Additional av connections
Does the boss DVD player have additional av outputs to add screens?
My dvd player is hooked up to t.v. but only plays movies in black/white
How is the DVD player connected to the TV? If you are using component video, check that the cables are connected correctly.
If you switch the order on two of the cables, the black and white result is common. So double-check that the red, blue and green connections (RPbPy) have been connected to both devices in the same order. Next try a different set of component video cables, in case one of the wires is damaged.
If possible, try a different type of connection to rule out a damaged input/output. Connect the TV to a different DVD player or the DVD player to another TV, if possible, to rule out similar damage.
Please add a comment with the connection type for additional support. I hope this helps.
Oct 07, 2012 | Vizio L37 Television
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
What wires are what?!
The device has several sets of wires for different functions explained briefly.
1. The first bundle of wires make connectivity to the vehicle possible. For example, the bundle of wires are recogniseable by the color demarkation explained. The Red & yellow cable provide power requiring conection to the vehicle;s electrical system, batteries or alternator cables found in engine or under dashboard.b. The black wire is a supply current output requird to dispense an overflow of electrical charges from the battery setup process and is always connected to the botton framework of the vehicle. Every additional wires belonging to the first bundle being discussed are audio video connectivity wires. for example, depending on the number of speaker outputs on the vehicle out require connectivity with attempt to distribute sounds througout the audio speakers located along the doors and at back passenger area of the vehicle.
2. The audio system would have an additional bundle of wires similar as the power supply bundle aready provided to make possible current flow from vehicle battery to audio device. The second bundle of wires are called RCA adator cable kits that only would be required in the situation where the vehicle is required to be installed with additional features of amplifiers,, woofers and radio communication systems. The RCA bundle of cables are simple wrapped up by electrical scotch tape and snapped in safe place after installing the music system requiring least functionality than radio and CD player mode.
3. the additional bundles of cables/RCA becomes handy and by connectivity is as simples as inserting a cable into a similar receiver cable from provided with the new device to be acquire separaly.
4. Remember; RCA cables are symbolised for functiona s well, where red and yellow cables are video signals and white and several other coloured wires are audio and sound connectability cables to another device acquired later.
Important notes
Connecting the audio system is all performed by snapping open the radio video area of the dashboard area for access to the aready installed vehicle wiring kits.
All multi colored wires on the power supply kit are electrical
All additional wires are audio and video output and input connection capable
DVD player installation diagnostics are accheivable by refering to the user guide package,
also,
Dec 02, 2010 | Boss AUDIO SYSTEMS BV7300 Car DVD Player
Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
May 05, 2010 | Toshiba SDV395 DVD Player/VCR
Diagram to set up the Panasonic DMR EZ47V DVD/Video recorder
Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the LCD . Connect the AV output of the Sky box to the AV input of the Panasonic combo.
Hope it will cover the matter
good luck
Jan 29, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I want to output blu ray dvd output in zone 2. Denon AV 4308
correct. in order to enjoy your digital sources in any zone2 configuration, an additional connection has to be made to the analog input from and for each of these devices.
some receivers wont allow internal xm, sirius and ipods to work in zone2 because they are input to the digital board and thats what your stuck with.
Nov 01, 2009 | Audio Players & Recorders
Problem adding dvd to digital converter box/tv mix
tengo un control remoto universal sony RM-v210
por favor si save como progamarlo escribeme a rical2903@hotmail.com
gracias anticipada.....
Aug 02, 2009 | GPX D1816 DVD Player
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Mintek dvd player, model mdp-1030
Mintek MDP-1030 DVD Player Description:Mintek is one the largest suppliers of DVD players in the global marketplace today. Mintek has taken the next natural step in the evolution of the company's product line combining leading DVD technology with state-of-the-art LCD technology.PRODUCT FEATURES:
Versatile playback formats;
Anti-shock function - mobile or pedestrian;
Built-in stereo speakers;
Auto power off for saving energy;
Quick connect to TV;
Digital Coaxial Output;
AV input/output;
Brightness/Color/Display mode adjustment;
High capacity rechargeable Lithium-ion battery pack;
Full function remote control.
Product Specification: DVD Player DVD Type DVD player Media Supported Kodak Picture CD, CD Portable Yes Form Factor Portable Remote Control Remote control Additional Features Auto power off Audio Features Audio Output Stereo MP3 Support Yes Connectors Composite Video Outputs 2 x headphones ( mini-phone stereo 3.5 mm ) 1 x digital audio output (coaxial) 1 x composite video/audio input 1 x composite video/audio output Power Battery Type 1 x DVD player battery - rechargeable - lithium ion General Product Info Weight 4.6 lbs Also known as Mintek MDP-1030, Mintek Manufacturer Part No. MDP-1030 Company Info Mintek Dimension 1.6 in x 10.1 in x 6.6 in (HxWxD) Model DBMDP-1030
Aug 17, 2008 | Compaq Presario Notebook
Extra screens
Target sells an item which should work. It's the Kawasai AVM678 or the Audiovox AVM6781 (http://www.target.com/gp/detail.html/sr=1-1/qid=1187573577/ref=sr_1_1/602-4888693-8663026?ie=UTF8&asin=B000I5IYAA). It's a universal extra screen. Otherwise, visit the official customer service website for this product at http://www.1800customersupport.com/kawasaki or or call them at 1-877-252-6873. They can probably sell you a splitter or additional screens.
Aug 18, 2007 | kawasaki PVS1965 Portable DVD Player
Boss AUDIO SYSTEMS BV7300 Car DVD Player Logo
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
