Question about Vizio L37 Television
Digital changeover I followed the directions in the manual. The rescan seems to have saved the channels we watch. But I still get no signal. We do not have cable, and I am using the antenna.
  • leemort2 Jun 15, 2009
    I may not have been clear enough in my question. I have a Vizio DTV. Because I don't have cable, I user a Radio Shack indoor/outdoor HDTV antenna. So, I don't use (or need) a converter box. I thought my DTV would just "roll over" to digital on June 12. I set the tuner mode on Antenna. I went through the rescan procedure and the digital channels we watch seem to have been saved. But I get no signal. Any ideas about what's wrong? Thanks.
  • Vizio Master
  • 5,568 Answers
You need to set both the converter (I assume you are using one) and TV to the same (analog) channel (3 or 4). Remember, the analog channels from 2-14 exist no more; they are inactive (as of 12 June, 2009) and will be reassigned to other services. BTW, your former VHF antenna is useless; all of the new digital channels are UHF only.
Posted on Jun 14, 2009
  • Steve Allison
    Steve Allison Jun 15, 2009
    Thanks for clarifying; If I had been observant, I would have noted the set make that has always been digital I believe.
    If you have gone through your setup thoroughly, even though you probably had digital reception before the 12th, the ATSC tuner section may have failed; this is the critical part of any digital set.
    Since modern sets are stuffed with complex circuits, something may have locked up.
    The only thing I can still suggest is that you pull the AC plug and let the set stew without power overnight but you may have already tried that route.
Set up indoor antenna
Plug antenna cable directly into antenna input on tv. Place antenna where you believe you will get a signal (don't know where you live but you can look up site map for optimum direction). Go into tv menu set tv to air and auto scan air channels. Your set will receive and memorize available channels. In your sets menu you should have a strength meter. You can use this to tune in the strongest possible signal. You may have to go back and rescan the channels because if you improve the antennas position you might pick up more channels and they won't just come in automatically. Once you've scanned and received maximum number of channels there will be no need to rescan again. If you do you run the risk of losing some channels and only a rescan under optimum conditions with regards to antenna position and environmental conditions will gain those back. Keep in mind some fringe channels may come and go. Hope this helps.
Feb 01, 2015 | Televison & Video
My model 22729 GE Smart Digital Converter Box is starting to lose channels even after a re-scan. Is there a master reset button for it?
The instructions for digital converter boxes recommend periodic rescanning because, in practice, channels tend to come and go depending upon signal strength, weather conditions, etc. The only way to accomplish a "reset" would be to turn off the power and start all over again but you would end up doing a complete channel scan anyway. Oh, and yes, I have had channels disappear even after a rescan has indicated they have been saved
Dec 26, 2012 | Audio Players & Recorders
Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
Dec 17, 2012 | Vizio RazorLED M260VA 26" LED-LCD TV -...
Some of my channels were lost after I TRIED RESCANNING I I LOST
Check your antenna direction (antennaweb.org or tvfool.com are good sources for signal direction). When I lose channels, it's a digital signal that came in with "bad signal" strength and my external antenna has rotated in the wind. (Oddly another TV in the house doesn't seem to lose the signal as easily even though they share an antenna.)
Also check the weather conditions and time of day. I've gained distant channels when scanning near sunrise or sunset and lost others during thunderstorms.
I hope this helps.
Jun 07, 2010 | Vizio L32 32 in. LCD HDTV
My pacific freeview box isnt picking up any channels
U have an out door antena?Rescan channels in the menu?Buy a digital antena get better signal,but still must rescan channels to get every channels.
Oct 22, 2009 | Televison & Video
The words "weak signal" flashes on screen at different places and do not receive a picture.
seems like you are using an "off the air antenna" that receives weak signal, you may be too far from the station, go get a roof top amplifier antenna or subscribe to digital service from cable, satellite or at&t uverse. If you think your antenna is getting good signal, try to rescan your tv for available channel. Make sure your TV set up is correct, if you are using Off the air signal, your setting should be set at "Antenna or off the air", then rescan your TV. Normally on Satellite or cable box, you just watch it on video channel or component input, if you are using HDMI then tune to HDMI channel.
Check your connection to make sure they are making good contact. If you can post your set up, I can better solve your problem.
For a resource on "off the air" antenna, go to www.antennaweb.org for help.
Aug 16, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
WHY MUST I RESCAN ALL THE TIME?
You may have several problems. If you are using a indoor antenna, upgrade to a outdoor antenna. The indoor antenna has to be adjusted every time you change a channel. If you plan to sit in a chair and never move when watching tv, you may be able to pick up a channel or two. Get a UHF/VHF antenna from a home improvement store. The big box electronic stores are selling a digital antenna. There is no such thing. The antenna doesn't know if the signal is digital or analog, it just picks up uhf and vhf signals. The other problem could be that the box is bad if it is not saving the scan. I would check the antenna first from what you said though.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
I have 50" PF9966 flat TV , not sure if is HD ready ? 2006 model how do i find out , nothing showing in guide
There are a few things to consider here. First, if you are using cable or satelite, the changeover has no effect on you anyway. If you are using an antenna, the changeover to a digital broadcast signal has already been in place for a while. The set should be able to auto-detect these signals. I believe that most of the models from 2005 on had digital signal tuners available. This is not the same as a "digital" tuner. A digital tuner only means that the stations are tuned digitally but are still analog signals. The changeover will be to change the analog signals to digital ones that require a smaller frequesny band for broadcast thus opening up more space for additional channels.
Hope this helps,
Dan
Jan 05, 2009 | Televison & Video
Cannot keep all channels on tv
When you say you "lose" channels, you probably mean there's no signal there anymore but they are still in the channel memory. This is normal if you have a rotatable antenna. You need to mark the rotator (or just keep a chart nearby) with the heading for each channel.
If you mean you're losing channels from memory when rescanning after turning the antenna, the only solution I can offer is to record the channels found (and their signal levels) after scanning a direction. Then change directions and rescan. See what new channels have been found, what have been lost, or how signal level has changed on common channels. Then you can manually add whatever you need, and you'll know what direction is best for each. It's tedious, but you should only need to do it once.
Nov 24, 2008 | Insignia Digital-to-Analog Converter for...
Vizio L37 Television Logo
281 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
