Question about Boating
Carburetor diagrams in what order do diaphram gaskets go in a mercarb one barrel carb
    Champion:
  • 231 Answers
Good Morning Hue,
Please Send Serial No Of Engine,Then I should Be Able To assist You.
Cheers Gordon
Posted on May 11, 2014
I need a diagram or manual for a four barrel Hitache carburetor that came on Mazda RX4 and RX5
You going to have to find that on the internet
from a place that rebuilds those type
Have them fax you or E.Mail you a diagram
In my 50 years, the only carb diagram I ever saw,
came in a carb kit or factory manuals
I own all the factory manuals for my vehicles,
but used the carb kits ones in the 1960 & 70's
Nov 24, 2014 | Mazda RX4 Cars & Trucks
Which is the correct way to fit diaphrams on stilh 450 carburators
Chainsaw carbs have two working sides, the pump side and the metering side, the pump side will have a diaphram and a gasket, the diaphram will have two small non return flap valves on it , it must fit against the carb body followed by the gasket, on the metering side the diaphram has a metal disc and a gasket, on this side the gasket goes against the carb body followed by the diaphram ( the gasket is used as a spacer )
Jan 15, 2014 | Garden
Correct way that carb. kit parts [gaskets,diaphram] are installed on craftsman 24cc gas leaf blower?
The side with the Gas regulator ( round metal disk in middle of diaphragm) Gasket on carburetor then that disc diaphragm then cover plate.
The other side that has the diaphragm with the cutouts go on different. That cutout thing ( Reeds) go up against the carburetor then the gasket then the cover.
Oct 19, 2013 | Craftsman 358797290
57 chevy pickup, 6 cyl.. Rochester one barreled carburetor rebuild instr. Thank you
Instructions and an exploded, numbered diagram will be included with a carburetor rebuild kit. You take it apart by the numbered diagram, clean everything with carb cleaner, make sure all passages are clear and not blocked, then put it back together by the numbered diagram in exact reverse of disassembly. Make all adjustments as you go along as the instructions dictate (like float level). When done, a new base gasket, torque down the mounting nuts, and make final adjustments.
Aug 28, 2013 | Cars & Trucks
Where does the spring go on the carburater
If this is a Briggs engine then the gasket between the carb and the tank has a diaphram built into it. The spring goes betwen the carb and gasket.
May 27, 2012 | Garden
Makita gas saw has too much gas entering the carburetor
The fuel inlet needle in the carb is leaking, replace the needle with a new one, the needle is rubber tipped and will wear espesially on a power cutter due to dust in the fuel tank, when replacing the diaphram make sure the gasket goes to the carb first followed by the diaphram and cover, the gasket is used as a spacer, so if the diaphram goes on first it will be too close to the metering lever and will leak.
Jan 11, 2012 | Makita Saws
Trying to rebuild a WT 185 carb for a weedeater. I have the kit. Need a diagram, PLEASE.
hi there drainmasters
here is web site link to help with intstructions
http://www.ehow.com/how_4869458_rebuild-walbro-carburetor.html
your carb kit would be a k20-wat
be sure to get everything in the correct order
ie fuel pump is the side with 1 large screw ,fit the fuel inlet screen fit the diaphram 1st then the gasket and cover
the other side is the metering diaphram , make sure the metering lever is set flush with chamber floor and then fit gasket , then diaphram then the cover
make sure the hi and low needles are back where they came from and set lo and hi to a base setting of 1- 1/4 turns out from lightly seated
check out the web site it will help
cheers pauly46
Jun 02, 2011 | Garden
Carburettor letting to much fuel through.may be gaskets replace in wrong position
If you have dissmantled the carb and fitted new diaphrams, it is very important to re assemble in the correct order, starting with the pump side ( the diaphram without the disc in the middle ) the diaphram goes against the pump body, followed by the gasket, followed by the cover and securing screws, the metering side is the opposite, so the gasket goes against the carb body followed by the diaphram, followed by the cover and securing screws, the metering lever should be set level with either the sides of the carb body or the base of the carb body dependent on what brand of carb we are talking about, to service the carb correctly yoy should do a final pressure test with a bulb tester, the carb needle should hold a continual 2 psi pressure.
Mar 01, 2011 | Garden
Craftsman 25cc weed eater carburetor need order of gasket and diaphram from the push bulb down
You just need your model # . You don't have to buy the diaghragm kit you need from Sears. You will need to know the manufacturer of the caburetor. Then, the model # of the carb. Then you will have all you need to order a diaghram kit, and they are not expensive. They normally don't include the bulb, but it can be purchased separately. Or you CAN go the Sears route if you like. Go to www.searspartsdirect.com and type in your info to see if they have the carb kit and part you want.
Oct 01, 2010 | Craftsman 25cc Gas Line Trimmer
I am looking for a diagram for a tillotson carb and the only numbers on it are OM10A
Diaphram, or gasket? The Tillotson OM10A is a float-type carburetor, with a small accelerator pump. Which part is it that is bad?
Jul 07, 2009 | Sport & Outdoor - Others
Boating Logo
41 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
