Question about LG 55LH55 55 in. HDTV LCD TV
Adjust vertical height kg 55lh55
  • JimRob Porter
    JimRob Porter Mar 24, 2014
    I did try all of the on-screen menus for picture aspect and settings.
    Top Expert:
  • LG Master
  • 74,482 Answers
To adjust the height of the picture, you have to enter its service mode option, and should adjust the vertical amplitude data value, accordingly. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Mar 24, 2014
Trayl bike owners manual. or how do I adjust the height of the handle bars?
Your bike has a modern "threadless headset" which usually allows very little vertical adjustment. See this page for an explanation of how to change height on that style:
How to adjust handlebar height BikeRadar
If you can't adjust enough that way you can try buying a shorter stem or one with a steeper angle,. The final option is to buy a "stem riser" - Google the term for more info - needs to have correct dimensions for your bike
It's best to get advice at a bike shop as to what option is best for you..
Jun 04, 2017 | TRAYL Cycling
Do you know the tare weight of a 2004 mazda bravo 4 x 4 single cab manual tray back?
Dimensions
Kerb Weight (kg) 1499
Towing Not Braked (kg) 700
Gross Combination Mass (kg) 4677
Wheel Base (mm) 3000
Gross Vehicle Mass (kg) 2877
Height (mm) 1760
Pay Load (kg) 1378
Track Front (mm) 1475
Towing Braked (kg) 1900
Track Rear (mm) 1470
Hope this helps buddy
Jun 26, 2016 | Mazda Cars & Trucks
Im34 years old and my height is 5'8" puertorican man what is my corect weight
Check an online weight versus height calculator, and they say that you are ideal at 73 kg, for a large frame, 68 kg for a medium frame, or 64 kg for a small frame. Check for your ideal frame size. Your age has nothing to do with ideal weight.
Feb 01, 2015 | Miscellaneous
Cant see the bottom of the tv screen
The vertical height of picture to your TV is more than normal now. When adjust the vertical height, the vertical lenearity also should be adjusted. There is no preset controls for this purpose in new generation televisions. You have to enter its service mode option and make data value adjustments. This is a skilled work, and only one who know better to adjust these values could rectify this fault. Entering in to its service mode, and adjusting data values there, without proper knowledge might make the TV irrepairable and irresposive to commands by both remote control and its front panel keyboard.
So it will be best for you to contact any experienced service technician to do this work.
Jul 09, 2012 | Sanyo Televison & Video
Top of screen disappeared...cant see score of game
The Height adjustment is off... look in the back of the TV set, it has some knobs in the back, one should be vert.lin for Vertical Linearity adjustment, and there is another call Vert.Hgt. for Vertical Height adjustment. try adjusting the Vertical Height first with someone watching in the front of the big TV to see if the top comes back into view, you might have to adjust the knob very slowly one way then the other way, to make this adjustment. If it doesnot adjust take it to a TV shop to get it repaired.
Good Luck.
Nov 11, 2010 | Hitachi 57F500 57" Rear Projection...
How do you adjust a headlight from pointing up to the right height
VERTICAL AIM ADJUSTMENT
1. Park the vehicle on a level surface approximately 7.6 meters (25 feet)
from a vertical wall or screen directly in front of it.
2. Measure the height from the
center of your headlamp to the
ground and mark a 2.4 meter (8
foot) horizontal reference line on
the vertical wall or screen at this
height (a piece of masking tape
works well). The center of the lamp
is marked by a 3.0 mm circle on the
headlamp lens.
3. Turn on the low beam headlamps to illuminate the wall or screen and
open the hood.
4. On the wall or screen you will
observe a light pattern with a
distinct horizontal edge of high
intensity light with a slight angle
towards the right. If this edge is not
at the horizontal reference line, the
beam will need to be adjusted.
5. Locate the vertical adjuster on
each headlamp, then use a 4 mm
socket/wrench to turn the adjuster
either counterclockwise (to adjust
down) or clockwise (to adjust up)
aligning the upper edge of the light
pattern up to the horizontal line
6. HORIZONTAL AIM IS NOT
REQUIRED FOR THIS VEHICLE
AND IS NON-ADJUSTABLE.
Mar 09, 2010 | 2002 Ford Explorer
I need the following info for my 1999 Audi S3 in relation to the tailgate dimensions: Height.......cm; Length........cm; width.........cm; wight.........kg
Exterior Dimensions
Wheelbase
2519 mm
Front Track
1527 mm
Rear Track
1503 mm
Overall length
4159 mm
Overall Width
1763 mm
Height (unloaded)
1415 mm
Ground clearance
n
Unladen weight in kg / gross weight limit in kg
1375 kg / 1935 kg
Nov 05, 2008 | 2005 Audi A3
Adjusting vertical height
I looked for info for your the Mct-2051 & imagine my surprise that Magnasonic not only doesn't have a manual for your model they don't recognize the model #. Excuse my sarcasm.
If MCT-2051 is not a typo, then the closest I could find was an MCT-2053 & there was no mention of a vertical height adjustment by software control. From my past experience this adjustment can only be performed by a TV tech because you need to access the inside of the TV.
The fact the picture has shrunk this much means that the vertical height driver is failing & eventually you will see nothing but a vertical line, stretched across the screen. Which will mean, that do to Magnasonics' lack of support, you'll be out of luck.
When shopping in the future for a TV try to stay with name brands who will support their products.
By the way, where did you hear that you could adjust the VH utilizing the remote? That could possibly be a function of digital device like a computer monitor, not an analog device like your TV.
Feb 25, 2008 | Televison & Video
Vertical height adjustment on Magnavox 19 inch LCD HDTV
try to adjust at the vertical section.hope this will help
Feb 01, 2008 | Philips 19MF337B/27 19 in. LCD Television
Vert hight adjustment
How do I adjust the vertical hight of a SANYO 36" TV. vertical height can adjusted by height conrol that is inside tv in your case you can also adjust by remote control. for that you will have to open menu by giving service code. regards thanks
Sep 10, 2007 | Sanyo AVM-3659S 36" TV
LG 55LH55 55 in. HDTV LCD TV Logo
90 people viewed this question
Computer Repairing
Computer Repairing
