Question about Nikon Coolpix S6300 Hd Digital Camera
Getting only the fast flashing green light when trying to charge
I have tried changing the order of camera, USB, AC adapter, power outlet but I cannot get the slow flashing green light to come up. I have had this problem before and it is usually fixed by turning it all off and starting again , or by changing the order. Please help. Janice
    Top Expert:
  • Nikon Master
  • 43,901 Answers
The battery may have to be replaced.
Posted on Mar 24, 2014
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
Battery charging shows quick green light
Ill try to help you, I think the slow flashing green lite is when you first plug it in the longer its on it will flash quickly when almost finished mine blinks untill full then stays on try to wear your battery all the way down then try to charge again good luck
Mar 24, 2014 | Nikon COOLPIX L19 Digital Camera
Nikon coolpix s205My camera wont charge any more. I had it stored for about 6 months and when I plug in the charger the light pulses with a green light then a solid green light for a couple seconds th
The manual says, when the light is flashing green:
The USB cable or Charging AC Adapter is not properly connected, or there is a problem with the battery. Disconnect the USB cable or unplug the Charging AC Adapter and correctly connect it again, or change the battery.
So make sure you are using a good USB cable, the cable is put in correct. (far enough and straight) And I hope you did not put in the battery the wrong way around, because that could cause damage to the camera and battery.
Make sure the battery and the camera do have clean and shiny contacts. Only to clean with a dry cloth.
And if the problem stays, perhaps you should accept the battery is dead.
You could try to charge it on an external charger, if you have one. And start and stop charging, if you think it is not yet charging.
But if after just a few attempts nothing changes, I think you should buy a new battery.
Jan 22, 2014 | Cameras
I have the charger, but lost the book with how to recharge. Please help Thank you.
There is an error in the instructions provided in the User's Manual and Quick Start Guide for the Coolpix S3000 and S4000. The information contained in the manual and guide instruct the user to plug the UC-E6 USB cable into the camera first before plugging into the AC power supply. This process will not switch the camera power on automatically.
Please follow the steps below in this order only * :
1 - Connect the USB cable UC-E6 to the Charging AC Adapter EH-68P.
2 - Plug the Charging AC Adapter into an electrical outlet.
vinayak_nair_4.jpg3 - Be sure that the camera is turned off and then connect the USB cable UC-E6 to the camera.
vinayak_nair_5.jpgWhen the green LED starts blinking slowly after a few seconds, charging has begun. When the LED goes off, charging is complete.
* If the charging light fails to come on at all, please sure to follow the steps in the correct order detailed above. Connecting with the incorrect order may result in a "no led light" situation.
Jan 17, 2011 | Nikon Coolpix S4000 Digital Camera
It looks like the battery it is not getting charged, even after several hours connect to the outlet. The led on the side turns fast from green to red and vice versa.
Could be the issue with AC adapter pin or with the jack of the notebook where you connect the charger. So once wiggle and hold the connector until you get the blue light.
Check whether the AC adapter brick is getting warm or not.
If it is not getting warm replace the ac adapter.
If it is getting warm wiggle the charger at the port and if you are able to charge then send the notebook for service to replace the DC jack .
If all the components ( ac adapter pin, mother board jack) change the battery and check with another laptop.
Mar 29, 2010 | SmartDisk PhotoBank PB40 40 GB USB 2.0...
My camera cannot turn on or off is only 3 months old tried what might be the problem? i tried to charge the battery nothing happened i tried to take the battery out and back on still it did not work. i...
1. Remove the batteries from the camera and the memory card
2. Batteries should be Li-Ion Rechargeable Digital Camera Battery KLIC-7001 3. Verify batteries are inserted correctly
4. Place the camera in Auto Mode (Its green camera icon on the dialing mode)
5. Turn on the camera (if it failed try charging the camera)
6. Plug the USB AC adapter into a working power outlet.
7. Connect the USB cable to your camera and to the USB AC adapter.
a. If lights on battery charging light [solid green]
>charge the camera until light turns off or (up to 3hours)
b. If lights on battery charging light [red or flashing red]
>camera batteries are weak; replace with recommended batteries
c. If lights on battery charging light has [NO light]
>Try new set of supported batteries to test the camera one last time
>If already tested with a new set of batteries, set up the camera for repair
8. After all the step still camera will not work contact Kodak support line at 1 800 235 6325 (23KODAK) ** since the camera is less than a year it can be sent for repair in warranty. To receive warranty entitlement, you need to include a photocopy of the receipt or proof of purchase
NOTE: If Kodak repair center finds out customer induce damage, you will pay for the repair cost
Nov 19, 2009 | Kodak EASYSHARE M1063 Digital Camera
When I turn on my EasyShare M863, it turns off again. I have tried to change the battery, etc. But nothing has helped. I was going to send it in for help, but cannot locate an address. I received this...
1. Remove the batteries from the camera then clean the battery contacts
2. Remove the memory card
3. Insert the battery back on the camera in correct position
4. Place the camera in Auto Mode (auto mode is the green camera icon on the dialing mode)
5. Try to turn it ON (if still doesn't turn ON)
6. Charge the camera plug the USB AC adapter into a working power outlet.
8. Camera will charge until light turns off or (up to 3hours) then test the camera if it will turn ON
9. You can also check http://www.kodak.com/go/usbcharging
10.You can also follow the steps on this website www.kodak.com/go/stepbystep
**Contact Kodak support line 1 800 235 6325 (23KODAK)
kodak camera warranty is one year from the date of purchase or from the manufacturing date which ever is longer
Nov 16, 2009 | Kodak EasyShare M1033 Digital Camera
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Asus ac adapter will not wrk green light on adapter
First check the wall socket make sure you are getting power, plug a lamp into it for instance. If there is no green light on the adapter then it is bad and you will need to order a new one from your computer manufactor.
rate with 4 diamonds
Mar 02, 2009 | ASUS AC Adapter- Universal Notebook AC...
Nikon Coolpix S6300 Hd Digital Camera Logo
155 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
