Question about Samsung ES90 Digital Camera
Flash did not work
Camera flash doesnt work
My sony w370's flash doesnt work...i mean the flash does work bt only smtyms.....wen it is kept for a few weeks without being used...........then it work and after clicking 15-20 images it again doesnt...
Be aware your camera is not a professional DSLR with external flash lights.
Most camera's will get warm or even hot when you take several pictures with the flash on in a short time. Most manuals do have a warning about using the flash. Sometimes the camera is only allowed to take a picture with the flash on, once a minute or even once in a couple of minutes. When the camera becomes hot, it will prevent itself against overheating, by not charging the flash again.
Still it can be possible something els is wrong with your camera, but try to shoot with the flash, with greater intervals and look if you can use the flash any longer. Also when the battery is drained, the flash won't charge. When shooting continuously, you will drain your battery much quicker.
Jan 19, 2014 | Sony Cybershot DSCW370 Digital Camera
My camera doesnt' work indoors. i try to take a picture and it doesnt' take when I'm in AUTO mode. However, when I'm in LANDSCAPE mode the pic will take. it seems like the flash isn't active in AUTO...
You must have a software glitch because the flash is supposed to be in the auto mode when the selector is in auto, unless you manually turn the flash off and the flash should go back to auto every time the camera is turned off and back on. Here's a work around. Turn the dial to indoor and use the flash button on the ring to set the flash to auto. In the indoor setting you can set the flash to on, off, or auto.
Dec 19, 2010 | Canon PowerShot A720 IS Digital Camera
I have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing...
i have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing its takin pictures as normal just without the flash it wont let me change the settings of the flash at all
Jun 14, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
K800i came flash not working
check your camera settings and flash settings. i it doesnt then go to nearby ressel and get the work done. I advice go to sony ericsson service centre .
Apr 30, 2010 | Sony Ericsson K800i Cellular Phone
My camera doesnt take pics @ night Maybe flash
First make sure that the camera has fresh batteries. Then see that the flash setting is either 'on' or 'auto' or any graphic mode like a lightning bolt.
If this doesn't help, the flash might be damaged. Any camera shop can check this quickly.
Nov 26, 2009 | Moultrie Cameras
Flash isnt working finepix s5700
try to pull it up to get it out and then choose the lightning button to activate flash....
Nov 11, 2008 | Fuji FinePix S5700 Digital Camera
Flash on cybershot dsc-t33 doesnt work
Please check Flash Bulb, is it broken or not. if its broken you need to replace it and this requires solder work.
Let me know out come to guide you further.
Be Careful while touching Flash Circuit as it has Very High Voltages and will give SHOCK if capacitor is not discharged properly.
Oct 25, 2008 | Sony Cyber-Shot DSC-T33 Digital Camera
A550 powershot flash not working
we all need new flashes it costs 90 bucks to replace it
Mar 06, 2008 | Canon PowerShot A550 Digital Camera
A drop image on screen
hi i have panasonic NV DS 65 initially when i power on the cam it started then after 5 to 10 sec the power light automatically flashes and the buttons on camera doesnt work any more. but now the problem has got worsend the powen light keeps on flashing and no buttons work moreover a drop image is flashed on the screen.
plz have me solve my problem
sam_rav
Jan 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
Samsung ES90 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
