Question about ASUS TF600T-B1-GR - Replaced by TF600TC1GR
Asus ghost screen
Ghost touch
I have an android micromax yu4711 Recently my mobile doing ghost touches ,after some observation I found
Hi abhiyewale. Does the problem occurs when you first bought the device? If so, this might be a factory defect and must be handled by the seller, where you have bought your device, if under warranty.
If this was a user issue, the problem might caused by a software bug or a faulty touch screen.
Try resseting your device and see if the problem exist.
If so, send your device to the nearest technician for diagnosis.
-josh
Apr 22, 2017 | Android Cell Phones
I have an ASUS laptop with Windows 10 and my touchscreen has stopped working. I reloaded windows as I found the HDI driver for the touchscreen was ghosted-no luck. Still no driver for the touchscreen
device manager does not uninstall programs
you have to go to control panel select programs , select uninstall and then highlight program to be uninstalled the click on uninstall.
try to find the touch screen and then click on properties , find the driver tab and click on upgrade driver .
you could always go google and type in --user manual for asus touchscreen laptop--- and down load the pdf version
what you want may be included in the manual
Dec 29, 2016 | ASUS Computers & Internet
My touch screen is all wonky its not responding to anything I'm trying to do with it and its doing things that I'm not doing it's basically made my phone useless at this point
Tf810c Touch screen wont work ' TabletPCReview.com - Tablet PC ...
forum.tabletpcreview.com > Forums > Windows Tablet PCs > Asus
Feb 24, 2013 - 10 posts - ‎4 authors
If it's greyed out, there is no data to reset, and it's not that causing the issue. ... wentall wonky, swipe for charms wont work, can select anything ... I tried the hard reset and low and behold my touchscreen started working again.
Nexus 7 (2013) erratic touchscreen & keyboard - Google Product Forums
productforums.google.com/d/topic/nexus/W0Hfkq8hf-c
GoogleJul 30, 2013 - I've used some touchscreen test apps and "ghost" touches would ... Myoriginal Nexus 7 (2012) didn't do this, nor did my Gnex or any of ... If it's software, I don't mind hanging onto it until a fix is released. ...... I can't believe no one has saidanything about the touchscreen not responding at all to touches I've ...
XPS 9530 touch screen stops responding (how to fix) - General ...
en.community.dell.com/support-forums/laptop/f/3518/t/19534511
Dell
Dec 1, 2013 - 15 posts - ‎7 authors
Dec 16, 2015 | Cell Phones
ASUS VT207 Touch Screen Monitor - Touch is not functioning properly
install your monitor drivers and update the windows it will works
Apr 20, 2015 | ASUS Computers & Internet
I have a problem with the Asus tablet. After a period of about 1/2 hour the tablet is hot in the bottom right hand corner at the back in landscape mode. There is then a ghost finger mark on the screen in...
This is a safety issue and even if its out of warranty Asus should fix it i have provided a link.If you experiance problems with Fix/replace by them let me know i can talk to them for you.Or you may call me @ 225-290-5733.
24 7 Support for Asus PC 1 855 698 3243
Apr 10, 2014 | ASUS Computers & Internet
Touch screen not working
pls check touch pad settings or reconfigure your touch screen.
Feb 10, 2014 | ASUS Computers & Internet
Touch screen
Asus does not have a model named 501J. If you mean k50IJ, it is not a touch screen.
Jul 13, 2013 | ASUS Computers & Internet
I have just bought an ASUS VW246H - has slight ghosting
I have just bought an ASUS VW246H - has slight ghosting? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
5E 0NC02 001 4H 0NC02 A01 ASUS 5E 0NC02 001 Power Supply Backlight...
Jun 16, 2009 | ASUS Computers & Internet
   That's the main problem with most of the touch screen.
In case, if it's not working, you need to replace that ( In case, you are sure you haven't played with settings )...
Reset the phone - Factory settings.
In case if the issue would be there, confirmed faulty touch screen. If under warranty, get that exchanged unless buy a new touch screen.
Go for original touch screen setting unless might cause this issue again.
Thanks for using Fixya.
Apr 23, 2009 | ASUS P527 Smartphone
ASUS TF600T-B1-GR - Replaced by TF600TC1GR Logo
128 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
